AVIC "F" Series Bypass
By chrisbulla · Jun 09, 2008in Hacks/Mods💬 276 posts👁️ 137,620 views
Page 11 of 12
Posted May 13, 2009 · 17:15 UTC#251
Yes if this method of relocating the mute wire in between the two black wires and then ground the yellow/black and light green wire will work. Did it yesterday and works flawless.
Posted May 16, 2009 · 20:45 UTC#252
:D This was very helpfull Thanks to every ones input.
Posted May 31, 2009 · 18:31 UTC#253
Hi there:
found this thread thanks to google and thanks to you guys i will be able to bypass my AVIC-F700BT
Long story short.. i have a 2005 Bonneville GXP with onstar
i wanna bypass my headunit but i was wondering about something..
for the bypass i have to move the black/yellow MUTE wire to the forth pin and then ground it with the parking break wire.. which is no problem... but my car uses that MUTE wire to mute the system whenever i use onstar..
so my question is:
Is it okay to keep the mute wire on the pin its on and ground it with the parking break and also ground PIN 4? or can i just leave the mute wire the way it is ungrounded and ground pin 4?
thanks
samz
Posted May 31, 2009 · 22:27 UTC#254
Sounds like you just need to leave the mute wire the way it is currently wired, but ground the pin you would have moved it to if you'd followed these directions.
Posted May 31, 2009 · 22:34 UTC#255
you just have to ground pin 4. they all say to use the mute wire since most people dont use it. its alot easier...
Posted Jun 01, 2009 · 06:17 UTC#256
k ill try that tomorrow and ill let you guys now
much appreciated
Posted Aug 19, 2009 · 00:51 UTC#257
Let me start by saying this is my first post. I just read all 18 pages of this thread and my head hurts. BUT it was VERY informative. According to UPS, my 90bt is going to come tomorrow and I will be ready and equipped with all the knowledge I learned. For those of you too lazy to read all 18 pages, and have just skipped to the end and found this post, I HIGHLY recommend reading all of them. It may take a while but it will probably be worth it. The most common question on here was "I did exactly what the instructions said but it didn't work. Why?" and almost ALWAYS the answer was "Re-check your wiring."
With that said, it literally seems to be as easy as moving the mute wire from its original location in the corner to the 4th slot on the opposing side and then grounding both the mute and parking break wire. THATS IT! To remove the wire shouldn't require much force. Lift of the white tab that is keeping it in place and gently slide it out. If its not going, then you havent lifted the tab enough. When placing it into the new slot, do the same thing.You should have to force it in there either.
Posted Sep 24, 2009 · 04:39 UTC#258
Hi,
I've read all 18 pages as well, so I know every possible aspect of this mod has been covered at least once in this thread alone, though I seem to have a slightly odd setup that has me stumped.
I have a F7010BT that came factory installed in my car (09 Scion xD rs2). The black wiring plug is physically the same as the pictures I've seen posted here, but I have no light green wire on side with the clip, just a dark green wire next to where it should be.
From the picture Vorian posted on page 6 from top left to right:
Grey/GreyBlack/White/WhiteBlack/lightGreen/PurpleWhite/Blue/Black
Mine from top left to right:
Grey/GreyBlack/White/WhiteBlack/RedWhite/darkGreen/Blue/Black
I moved the pin as instructed down between the 2 black wires as a test, and then connected them together and grounded them to the frame, but no dice.
I've triple checked my wiring; all connections seem as snug as can be.
I only really need to bypass the parking break, as I've already done the Software Bypass for the other half.
Any thoughts, perhaps I missed something?
Posted Sep 25, 2009 · 05:46 UTC#259
I found the solution to my question with the help of some of the guys over at scionlife.com
In the picture I posted, the light green parking brake wire on the Pioneer harness is physically connecting to the same pin as the Red/white wire on the harness in my xD.
So I called Pioneer and (carefully) worded my situation just to see what they'd say. The guy sounded surprised that the harness wires were colored differently than normal, but confirmed that the pinout on the actual navi would still have to be the same, regardless of being factory installed by Scion, which is logical.
I tried grounding this wire instead, and sure enough it worked.
There is another gotcha too: If you simply ground this wire as it sits, the vehicle then thinks the parking brake is on and beeps and flashes constantly. I had to snip the Red/white wire so it no longer tied in with the parking brake wire the car sensors use, and only ground the one from the stereo, which is simple enough but I found easy to overlook.
I am really curious now to know if anyone else with a Scion factory installed F7010BT has the Pioneer harness or the same harness as me. I hope this helps anyone with a xD that may run into this situation.
Posted Dec 05, 2009 · 08:21 UTC#260
i just bought the f90bt unit that was previously installed in a tacoma or something (i forgot). i have an acura but there doesn't seem to be a mute wire (yellow/black). There is a yellow wire though but all the slots are already used by a diff wire except for one, which is at a corner. so i'm pretty much at a loss on how to bypass it.
here are two pics to show you what i mean.
Posted Jan 20, 2010 · 23:57 UTC#261
Greetings from the UK !
I know a little late, but just bought the 900BT and fittng it tomorow.
I have read all through this hack, and as above, picked us some good instructions.
I have prepared the wiring loom for the unit following the hack - grounding the moved mute cable, along withthe handbrake cable so all should be good!
BUT ! I have never switched this unit on before and its brand new. I have read mention of a "reset required", since its new - will it need one, and if so how do I do it?
many thanks to all those who have contributed to this thread so far
Jon
Posted Jan 21, 2010 · 00:59 UTC#262
Its in the manual.
Posted Jan 21, 2010 · 01:00 UTC#263
I have an acura but there doesn't seem to be a mute wire (yellow/black). There is a yellow wire though but all the slots are already used by a diff wire except for one, which is at a corner. so i'm pretty much at a loss on how to bypass it.
Your looking at the wrong harness. The mute wire is on the RCA harness.
Posted Jan 21, 2010 · 01:02 UTC#264
The reason yours is different is because the factory installed units don't have an RCA harness for aftermarket amps. The mute wire on aftermarket units is on the RCA harness. So the question to your answer should be yes, everyone that has a factory installed unit should be identical to yours.
Posted Aug 26, 2010 · 22:32 UTC#265
I just did the bypass and all seems to be ok except I have an airbag light that keeps flashing now. I moved the mute wire and the grounded it. I then grounded the mint green wire. The mint green wire was spliced into a wire that looks like the installer added. I have a 2006 nissan frontier, any help would be appreciated.
Posted Aug 27, 2010 · 21:35 UTC#266
i bought a f700bt online from a guy who bought a lot of them from some electronics store but it only came with the other harness not the rca one. i did my own bypass by grounding a miss marked wire and everything works great but am i missing out by not hooking it up via the rca harness?
Posted Aug 27, 2010 · 22:27 UTC#267
The bypass will fail without the wire on the RCA harness. You will need to acquire that harness and perform the bypass as instructed in this thread.
Posted Aug 29, 2010 · 03:34 UTC#268
I have it bypassed and i am able to access all the menus, what does bypassing with the rca harness do different?
Posted Aug 29, 2010 · 13:43 UTC#269
You can't be fully bypassed unless you have done one of the two following actions:
1: Performed the mute wire bypass/hack
2: Done the software bypass
If you did the software bypass you do not need to do the mute wire bypass.
Posted Oct 17, 2010 · 07:57 UTC#270
Scratch that. I am lame and I suck :)
I went and checked again because I couldn't accept it not working. I didn't get the white plug back into the radio fully. All good and bypassed now!
Making progress. Now just need a firmware update and I will be happy.
The bypass does work on the F90bt. I will be doing the one in my wife's car shortly.
Mine still stops working after 10 mph. My connection is good. Should I ground the parking brake, mute, and ground cable seperately?? Please help.
Posted Oct 17, 2010 · 13:13 UTC#271
It means the relocated mute wire part of the bypass isn't done correctly
Posted Oct 21, 2010 · 07:48 UTC#272
I have a 700bt that was supposedly bypassed by the installers. They added a switch that was supposed to bypass the parking break and allow me to watch video, access navi, phone...Anyhow, I relocated the mute wire and grounded to factory ground wire location, but left the parking brake wire alone. I figured they already grounded it with a switch. I played video off of my ipod and the bypass worked fine. Drove past 15mph...worked fine. Phone dial pad worked, navi worked...I thought everything was going good. Then all of a sudden, the whole radio shut off. Turned the radio back on, ipod wasn't recognized, so i unplugged the ipod and plugged back in. Then ipod started working again and I played the video again. Worked fine, but a couple of minutes later...same thing...radio shut off. Repeated the same steps, same result. Radio even shuts off when I'm parked watching video w/ parking brake down. Any thoughts on what could be going wrong? The bypass "switch" is in the position to simulate ground(I think this is what the switch is supposed to do). Why would it work fine, and then after a while not work at all? Should I try resetting the unit? Thanks in advance for any insight into my problem!
Update: I grounded both the relocated mute wire and parking brake wire. Video will play from the ipod for about 10-15 minutes before the whole unit shuts off. I was able to play video off of the SD card and from a flash drive with no problems. So the problem occurs only when playing video from the ipod.
Edited Oct 23, 2010 by Element1208
Posted Dec 02, 2010 · 13:41 UTC#273
does the vss wire still have to be connected for this bypass to work. Please give a full description of what needs to be connect beside the obvious bypass!!!!!
Posted Dec 02, 2010 · 17:28 UTC#274
The VSS has nothing to do with the bypass.
Posted Dec 29, 2010 · 06:11 UTC#275
When I got the unit, the guy told me to ground the yellow wire along with the obvious ground wire.
Maybe he didn't move it?
Or I probably wired it wrong.
I'm going to look tomorrow.
Can anyone post pictures of before or after?
Edited Dec 29, 2010 by casemods
Page 11 of 12
