Turning off iPod VR Catalog Mode...
By josche · Jun 23, 2008in Pre-Release Archive💬 51 posts👁️ 13,593 views
Page 2 of 3
Posted Jun 24, 2008 · 20:15 UTC#26
Phonebook is only updated when you initiate a "phonebook transfer."
You can change every contact in your phone and the f-series won't know until you manually update the contacts in it. Found that out already.
Posted Jun 24, 2008 · 20:19 UTC#27
but everytime you tranfer does it overwrite the old phone book or after a while will u end up with liek 10 of the same john smiths, because it jus re-adds ur PB?
Posted Jun 24, 2008 · 20:22 UTC#28
That I don't know. I updated my contacts in my phone after realizing I had a few bogus numbers for folks. I just clearded all the contacts in the stereo and re-did it fresh from scratch.
Posted Jun 24, 2008 · 20:23 UTC#29
It would be perfect if you only had to run VR Catalog once. However, I let it scan once, and then turn it off, the voice activation forgets everything. For now, I think you have to leave VR Catalog on if you want control of ipod voice controls. Hopefully a firmware update fixes this issue.
Posted Jun 24, 2008 · 20:27 UTC#30
it would be perfect but wouldnt make sense....how would u expect it to kno the new awrtists u put on if the deck didnt satalogue them.
an ideal method for it would be to have it scan ur ipod in like 5 seconds to chec for any new material and if it finds something, THEN catalogue. but if theres nothing new why hafta memorize everything again, its just a waste of precious time u can use saying "play artist whitney houston" (and no i dont listen to whitney houston, full metalhead right here \m/ >.< \m/ )
Posted Jun 24, 2008 · 21:03 UTC#31
Yeah true, didn't think about just checking for new music. I guess I dont update my ipod that often and just leave it plugged in all the time. :) I like ur method better
Posted Jun 25, 2008 · 01:54 UTC#32
so, today ive discovered something...i got out of work, got in my car, and started the car... got situtated a bit, lit up my post work ciggy, and then i plugged my iPod in. it finished the catalog in 15 seconds and flawlessly...i thought wow that was weird, but whatever, play artist godsmack!! i got home, left the iPod in the car, got ready for my lil cousins bday party, started up, the thing took 7 minutes to tell me the VR wasnt completed correctly. i was like wtf mate!! u jus worked! so i unplugged the iPod and put it bak in, AGAIN 15 seconds and it did it.....some one try this to confirm it. start your car first and THEN put ur iPod in.
Posted Jun 25, 2008 · 02:39 UTC#33
Most likely because it's trying to catalog it during startup. It probably runs a shitload faster when all that other stuff isn't going on at the same time. Just one more thing Pioneer could fix pretty easily.
Posted Jun 25, 2008 · 02:42 UTC#34
u kno what, that is an excellent point. i didnt even think of that. i figured it was a glitch that it only moved its ass when something was added in, but didnt when it was already in there upon startup
Posted Jun 25, 2008 · 05:10 UTC#35
Well I got home tonight and I had a AVIC-F900BT waiting for me. I got it all installed and with 17,000 songs on my iPod, it takes 13 minutes to sync the VR...
AND that is everytime you start the unit.
So that answers that one. :?
Posted Jun 25, 2008 · 05:19 UTC#36
Try what he did. Unhook the ipod, power up the unit and let it finish the boot up sequence. THEN connect the ipod and see how long the VR cataloging takes to complete. It would be nice as a comparison, and to see if more than one person has that result.
Posted Jun 25, 2008 · 05:21 UTC#37
I will try it out tomorrow and let ya know. If that is the case, that would be cool.
Posted Jun 25, 2008 · 19:58 UTC#38
So as long as I keep the iPod connected, it wont have to catalog each time I turn on my truck... it will retain the VR catalog...
Is that correct? :?
I think the original post was pretty clear in stating that you will have to catalog each time you turn on your truck or else you will not have VR control of your iPod.
I was looking for more folks to confirm this, but mostly this thread has been people discussing off-topic issues.
Posted Jun 25, 2008 · 20:54 UTC#39
From my experience, I've had to leave VR catalog on all the time. It does not retain the info if you do it once and turn it off (leaving the ipod plugged in all the time). It's getting faster though. It now only takes about 5 minutes to fully load every time I turn on my car.
Posted Jun 25, 2008 · 23:17 UTC#40
my f700bt did the same thing. I leave VR on and ipod connected. My total start up time is 2:45 but i only have 2000 songs. Weirdly i just sent the unit back cause J&R has the 900bt for $830 and when i was going to get the unit taken out the audio dies on me.
Posted Jun 26, 2008 · 00:57 UTC#41
Is that correct? :?
CONFIRMED! the deck will automatically catalog whenever it turns on and the mode is on. and there all talking about the same thing so how do u figure theyre off topic...
Posted Jun 26, 2008 · 01:29 UTC#42
heres what was accomplished in this thread:
-VR Catalog must be on to use ipod voice commands
-the F will catalog EVERY TIME your unit is turned on and the ipod is attached
- the length of the process depends on the amount of data it has to go through.
-if you cancel the mode while its in progress, or you get an incomplete message, it will not work.
- you can still use other audio voice commands while you cant use ipod commands
- if you plug your ipod in after the startup is complete, the catalog completes in under a minute (a valid point by HiFiSi has led me to believe that this will work on all F series units.. but still waiting on confirmation from other members)
another thing i discovered today, the F reconizes workds based on how the word is spelt, not by how the artist pronounces their name. ie, Cascada is pronounced 'Cascodda', but i had to say 'CascAda' for it to reconize. and 311, i couldnt say 'three eleven', i had to say '3-1-1'
Posted Jun 26, 2008 · 03:46 UTC#43
My fully loaded ipod (74 gigs of music and movies) took 3 minutes to update the VR catalog today, when I plugged it in AFTER the F90 had booted up. I don't know how long it would have taken when updating the VR catalog during startup as it wasn't done by the time I finished my 12 minute drive to work and had to turn off the car. :lol:
Posted Jun 26, 2008 · 04:13 UTC#44
theres the confirmation! so note to everyone else, its a pain in the ass till the FW update is out but plug in ur pod after it boots up.
Posted Jun 26, 2008 · 05:10 UTC#45
I too tested this and mine will boot up in 4 minutes with 17,000 songs. Its a bit annoying since I have to reach over into the glovebox and make sure its un-connected from that last power off.
I found that if you don't care about the VR, then shut it off and use it like on the D3, then boot time is about 2 minutes for the whole deck.
Posted Jun 26, 2008 · 12:11 UTC#46
oh without a doubt its annoying but if you really want to use the VR (like jason said, its alot easier when driving stick) it takes a fraction of the time to plug it in after startup
Posted Jul 12, 2008 · 18:40 UTC#47
So, will the F900bt unit be able to boot up faster if I turn the VR catalog off?
What else can I do to make the unit faster?
Posted Jul 12, 2008 · 23:01 UTC#48
the vr catalog is only for the ipod to memorize your music. turning it off will allow u to use the functions sooner but it wont effect the overall startup time
Posted Jul 14, 2008 · 18:54 UTC#49
Anyone have a problem with the unit getting stuck in the cataloging mode? When I first installed it I had the same issues everyone else does (long catalog period if connected from the start, shorter if connected after booting).
Now it just sits in the "iPod control may be limited" mode for as long as I keep the iPod connected. I've tried a reset, and that didn't do anything. I've tried two 2G iPhones and my 3G and they all have the same problem, so I'm pretty sure it's my F700.
Posted Jul 14, 2008 · 19:03 UTC#50
Have you tried turning on the unit without the ipod plugged in, and then plugging in the ipod once the unit is finished booting up?
Page 2 of 3
