F-series bluetooth compatibility topic
By HiFiSi · Jun 24, 2008in General💬 86 posts👁️ 28,711 views
Page 3 of 4
Posted Nov 12, 2008 · 00:33 UTC#51
F-series model: 900
Phone make/model: RAZR V3xx
Ease of connection: Easy
Phone book transfer: Transferred Fine as a group but not one by one
Sound quality: Ok, but at times, Avic (Pre-update 2.0) will change the volume in the middle of the call
Comments: Same other issues as mentioned everywhere.
Posted Jan 08, 2009 · 21:23 UTC#52
F-series model: F-90BT version 2.0 from factory
Phone make/model: Sharp Sidekick LX
Phone book transfer: One at a time manual marking contact with vcardand sending via BT.
Sound quality: Ok, Both ways. Mic installed by the rearview mirror
Comments: Works great no complaints.
Posted Jan 09, 2009 · 09:16 UTC#53
^^^so you have to send every contact thru v card? how?
Posted Jan 10, 2009 · 04:43 UTC#54
F-series model: F-700BT version 2.0 from factory
Phone make/model: Blackberry Storm
Ease of connection: Easy, no problems
Phone book transfer: Worked flawlessly
Sound quality: Pretty good, no real complaints.
Posted Jan 12, 2009 · 03:12 UTC#55
F-series model: F90BT
Phone make/model: LG Dare
Ease of connection: No Problems
Phone book transfer: No Problems
Sound quality: Good on my end. On the other end, people have said I am "muffled" or can't hear me at times, but this is on rare occasions.
Comments: Sound quality issues could be due to my mic placement since I have stuck it on the side of my steering column.
Posted Jan 13, 2009 · 06:08 UTC#56
Phone make/model: LG VX8350
Ease of connection: Easy connection
Phone book transfer: Good contacts transfer, but askes for "Bluetooth PBAP Requested by Pioneer Nav. Accept?" every time you connect. If you do not open your phone and accept this the connection does not function properly (it took me a while to figure this out). So if you don't mind opening your phone and pushing a button every time you get in the car, this phone works well. Otherwise, not so much....
Sound quality: Seems fine.
Comments: The specific problem only happens after the first outgoing phone call. The first Phone call works fine, but if you haven't accepted the PBAP request then all subsequent phone have no sound through the car speakers. If you accepth the PBAP request, then all is well.
Posted Jan 14, 2009 · 06:35 UTC#58
Of course I figured it out. I had to good sense to ask you! Just like the guys at work.....
Posted Jan 15, 2009 · 00:50 UTC#59
Phone make/model: BlackBerry Curve 8310
Works pretty good, but have to two minor issues.
First: I don't like that it puts your contact multiple time in the contact list. It should have the contact and all the numbers associated with the contact. Also would like to be able to put my own picture for my contact
Second: Freeze after I hang up every once in a while
Posted Jan 17, 2009 · 20:15 UTC#60
F-series model: F90bt
Phone make/model: Verizon LG Voyager(VX10000)
Ease of connection: Easy. Set F90 to search, and made the voyager "visible" to it.
Phone book transfer: Fast. Probably about 45 seconds, and I have well over 100 contacts with multiple numbers for each.
Sound quality: I can hear people i call very well, and they can hear me very well. Even did a three-way conference call, and it was crystal clear to everyone!(We all had verizon, and the friend i called did the conference from his phone)
Comments: Doesn't seem like the F90 supports the voyager's text seeing as i don't get notified of a text when they come in. Unless one of my settings is wrong in the f90... but i don't think that's it.
Posted Jan 17, 2009 · 20:36 UTC#61
F-series model: 700BT
Phone make/model: Sony Ericsson W760a (AT&T, debranded to W760i)
Ease of connection: Painlessly quick
Phone book transfer: Ditto
Sound quality: Very good
Comments: Only other BT devices that have been used in my truck (2008 Chevy Colorado Extended Cab) have been a Samsung WEP200 and a Garmin Nuvi 660. Never a sound issue with the WEP, but always complaints from those on the other end about echoing when using the Garmin. Didn't matter if it was through the Garmin speakers or the vehicle speakers. Have had no complaints at all since I started using the AVIC.
Posted Jan 19, 2009 · 06:50 UTC#62
Phone make/model: BlackBerry Storm 9530
Ease of connection: Easy as most Bluetooth pairings
Phone book transfer: Doesn't want to work.
Sound quality: Too loud/Over modulate even when volume on unit turned down. It's almost like it's coming from the phone too loud, but volume on phone does nothing to adjust.
Comments: Really wish it didn't seem like it was forcing the phone to full volume. Makes certain callers hard to understand. My voice sounds clear to the caller, however...most never even realize I'm in my car.
Posted Jan 22, 2009 · 05:21 UTC#63
F-series model: 900
Phone make/model: Sony Ericsson W910i (unlocked)
Ease of connection: fast and easy
Phone book transfer: easy
Sound quality: Good but volume is way too loud at first. Voice is clear on both ends and conversation is natural and flows (no repeating or talking loud into the mike, etc...)
Comments: Connection is easy but it seems to take a moment to make a call sometimes or the call wont even go though. Maybe I'm being picky. Dropped a call on me once but hasn't since.
Update: Ok, I got a phone call on the way home from work this morning and the HU would not answer the call. I had to hit talk on my phone BUT the music still muted and it would not come back on after the call ended. :x My phone has been acting a little retarded lately though but who knows....
Posted Jan 24, 2009 · 03:27 UTC#64
F-series model: 700
Phone make/model: palm treo 750 - old one (2 years old) Cingular/AT&T
Ease of connection: somewhat complicated on phone function
Phone book transfer: only did 8 out of 150
Sound quality: everyone says it sounds great and the caller sounds good
note - very little, but still some (barely audible) electro-static noise is present. when i tried to transfer phone book, the send buisness card function is not on early treos i guess, so it only took 8 of my contacts, the ones on the speed dial oddly enough. anyone else do this with a treo?
**update**
-I found this thread - http://avic411.com/forum/viewtopic.php? ... ook+editor - and within the thread is someone who uses a treo phone, and i used his advice and... vuala! all contacts transfered! still kind of a pain in the arse, but it worked!
Posted Jan 24, 2009 · 21:59 UTC#65
F-series model: 900
Phone make/model: Nokia 6110 Navigator
Ease of connection: easy
Phone book transfer: Too long to upload
Sound quality: Sucks! Didn't work before 3.30 upgrade at all. Now it works. I can hear people fine they all say my sound is bad and it gets interrupted frquently.
Comments: Needs another good update.
Posted Jan 27, 2009 · 18:29 UTC#66
F-series model:F900BT
Phone make/model:Palm Treo verizon
Ease of connection: Good
Phone book transfer: OK
Sound quality:good
Comments: Purchased a program from Jetware to transfer phone book and other options
Posted Mar 16, 2009 · 15:32 UTC#67
F-series model: F700BT
Phone make/model: Verizon (Casio) G'Z one Type S PTT NO Camera
Phone book transfer: Not supported
Sound quality: Excellent
Comments: Everything works great including voice dailing :D . Just does not support phone book transfer :( .
Posted Mar 20, 2009 · 14:13 UTC#68
Phone make/model: LG vx9600 (Versa)
Phone book transfer: Complete*
Comments: * Edited phonebook entries using Verizon's Backup Assistant to remove illegal characters. Tried disconnecting the phone and then marking and sending all contacts to the F700bt; the phone said they all went, but less than 10% showed up in the contact list. Reconnected the phone, then tried to pull from the F700bt using the "Phone book transfer" button, which worked completely. There was no indication during the process, neither on the phone nor the nav unit, that anything was happening, other than the "Cancel" button on screen. Patience and faith in science and technology proved virtuous again! :mrgreen:
Posted Mar 30, 2009 · 18:14 UTC#69
F/series model: 700BT
Phone make-model: RIM Blackberry Storm 9500
Ease of Conenction: swift
Phone book transfer: sometimes smooth, sometimes refuses
Sound quality: Very very bad!
On the other end all is fine, on my end heavily overmodulated sound. Cannot be adjusted. Also lowering the volume does not improve quality.
Posted Apr 07, 2009 · 19:45 UTC#70
Phone make-model: Hacked AT&T Tilt (running RomEos latest ROM)
Ease of Conenction: easy
Phone book transfer: no problems at all
Sound quality: not bad, just like a speakerphone at home
I'm also coming from a DEH-700bt single din unit in my Jeep that had no issues with this phone, so I might be used to the sound quality.
Posted Apr 08, 2009 · 20:06 UTC#71
F-series model: F700bt
Phone make/model: T-Mobile G1
Ease of connection: Really easy as long as G1 is set to discoverable in bluetooth options
Phone book transfer: Sort of works but does not transfer entire phonebook **Edit, works perfect now
Sound quality: Good
Comments: Not sure why it won't transfer the entire phonebook, I have maybe 75 contacts in there and it won't even transfer half of them. When I tell it to transfer the contacts it seems to work correctly, tells me its done downloading, but not all the contacts show up. I am going to try rebuilding my contact list from scratch in the phone since I transfered it from a sim card from a wm6.1 phone before that had some weird data issues.
Oh and I am us the JF1.42 build of RC33 on the G1 and my F700bt is pretty much stock 2.0 except a few tweaks to try to improve performance that I found on this forum.
**What Alphaman wrote made me really question what would be considered illegal characters. Well it turns out that the comma is an illegal character and I had most of my contacts written up with last name, first name. All the contacts like that wouldn't transfer. Once the comma was removed, it transfered perfect.
Posted Apr 09, 2009 · 17:40 UTC#72
Phone make/model: LG CU515
Ease of connection: Quick, always connects
Phone book transfer: Only one "Contact" per send from the phone - Phone does not send the whole Contact List
Sound quality: Loud on my end through the car speakers. A little low on the receive end.
Comments: No omplaints about sound quality and a few calls did not know I was on a cell when I make a
call while parked.
Posted Apr 15, 2009 · 04:38 UTC#73
Phone make/model: Nokia N95
Phone book transfer: Default from phone is to send one contact at a time. Downloaded the Nokia_810_Contacts_Download_S60_3rd.sis program from europe.nokia.com and installed it on my phone, and was able to transfer entire phone book at once.
Sound quality: Good sound quality, not great, but good.
Comments: Works very well.
Posted Apr 17, 2009 · 01:27 UTC#75
F90BT
Nokia E51 with latest firmware
Full transfer of contacts from SIM card and memory
Painless, easy bluetooth and phonebook transfer. No good differentiation between cell and home numbers, though that could just the the F90BT.
Tim
Page 3 of 4
