Sound cutting out left to right
By bluesti · Jul 05, 2008in Problems/Troubleshooting💬 45 posts👁️ 7,146 views
Page 2 of 2
Posted Aug 02, 2008 · 19:02 UTC#26
Going to pick up a new cable today. I'll let you all know how it goes.
Posted Aug 02, 2008 · 19:09 UTC#27
i had the same thing weh i put the xm in my car turned out to be a bad cable from the box..i had a tv tuner that i wasnt using anymore used that cord and all is well..have poping noise speakers sound like they are shifting sounds just sounded like shit..but all is well now..
Posted Aug 02, 2008 · 19:26 UTC#28
mine gives that "white noise" sound every once in awhile...so this was just another thing that i thought could contribute to a bad cable...if this happens again...i'm just gonna take my unit up to the dealer i got it from....
Posted Aug 04, 2008 · 01:01 UTC#29
My f700 does the exact same thing.... driver side is way lower than right side. I cranked the balance full left...something is jacked up. All other sources are fine.
Ipod touch v1.14
pioneer ipod cable
f700 w/ latest firmware upgrade.
Posted Aug 04, 2008 · 02:24 UTC#30
i have had a similar problem with an ipod, the cable is faulty or there are loose pins in it, on the one i had i reset the loose pins and then dropped in a little hot glue to keep them all steady.problem solved!!
Posted Aug 04, 2008 · 02:27 UTC#31
Posted Aug 04, 2008 · 12:32 UTC#32
Can you take a picture of what you've done? I'm having problems visualising it.
Posted Aug 04, 2008 · 15:48 UTC#33
yo probally dont want to use glue cause u will never be able to take the connector off the unit again.. or when the glue hardens wil not be able to plug it in
Posted Aug 04, 2008 · 15:50 UTC#34
you probally dont want to use glue cause u will never be able to take the connector off the unit again.. or when the glue hardens wil not be able to plug it in..if u have a multi meter then do a resistance check on each end of the plug to see if u have broken or high resistance in the wire each should read the same
Posted Aug 04, 2008 · 23:45 UTC#35
no you dont glue the unit and plug together i mean you drop some hot glue into the back of the plug where the pins slide into the grooves, of the i pod cable
Posted Aug 11, 2008 · 07:46 UTC#36
OK folks my issues must have been the pioneer ipod cable after all. I've had my new cable in for 4 days now and everything works perfect.
Posted Aug 12, 2008 · 10:15 UTC#37
Looks like I'll be going to get a cable! :)
Posted Aug 14, 2008 · 17:13 UTC#38
I'm having the same problem with the new iPhone 3G. If a lot of people are having the same problem how will getting a new cable fix the problem? Can you use something other then the Pioneer cable?
Posted Aug 15, 2008 · 06:56 UTC#39
I think Apple makes a cable that should work just the same as the Pioneer and I think the Apple Cable is a little cheaper believe it or not.
Posted Sep 09, 2008 · 21:02 UTC#40
Are people still having good luck after replacing the cable? I'm having mine replaced next week so I hope that fixes the problem.
Posted Sep 09, 2008 · 23:24 UTC#41
Mine works fine after replacing the cable. Yours should too.
Posted Sep 11, 2008 · 16:11 UTC#42
I had a similar problem. The negative pin broke on the front left RCA input at the white harness on the back of the deck.
http://avic411.com/forum/viewtopic.php?t=17786
Posted Oct 08, 2008 · 12:53 UTC#43
Yep... replaced the ipod cable, and it's been fine for about a month now! :)
Posted Oct 24, 2008 · 02:25 UTC#44
can anyone else confirm this is the ipod cable and not the ground wire(s) on the white plug?
Posted Oct 30, 2008 · 02:47 UTC#45
Is the cable warrantied by Pioneer? This cord costs $50!
Page 2 of 2
