post update bypass for f900
By radar007 · Aug 04, 2008in Hacks/Mods💬 13 posts👁️ 2,817 views
Posted Aug 04, 2008 · 17:34 UTC#1
I spotted an f-series bypass post dated-6/9. Is this the same way to bypass after the firmware update?? I have the f900 and it has been updated a week ago. Are there new bypass instructions ??. I am referring to not being able to watch the dvd while drivin at highway speeds. i am nu to the site so i will apologize to you vets i advance if this post is in the wrong place. please help
Posted Aug 04, 2008 · 17:43 UTC#2
It's the same. Nothing has changed. They would have to physically change the unit for the bypass to stop working, IIRC... and all that has been done to the new units is a firmware update.
Posted Aug 07, 2008 · 21:55 UTC#3
Thanx for your help. I f the bypass was not affected by the firmware update,is it poss. than what could be the reasons why my new 900 isnt working?? (I initially had a 700) I will just take it bak to the installer and have him look at it?? Thanx again
Posted Jun 04, 2009 · 16:10 UTC#4
CAN YOU PLEASE HELP ME?
I just purchased the F900 and it came with the 2.0 update.
I want to be able to play DVD's for my son while driving.
Can someone please give me some good directions on how to bypass this?
Please help.
Thanks,
KidFresh1
Posted Jun 05, 2009 · 20:03 UTC#6
dianebrat or anyone else who can help.
These updates for the bypass of the F900 to play DVD's while driving are all old instructions from 2007 and 2008.
Does anyone have any recent instructions on how to bypass?
I am just afraid that with the 2.0 update things might have changed.
I also heard that once you do the bypass you will have issues with any updates that Pioneer provides. Is that true?
Thanks so much if you guys can help.
Posted Jun 05, 2009 · 20:25 UTC#7
no, nothings changed. its 1 variable. just follow the directions. i wrote my own step-by step if you cant find any of the other numerous posts talking about how to bypass.
viewtopic.php?f=34&t=15663&start=210
Posted Jun 05, 2009 · 20:59 UTC#8
Thanks for that info.
But does anyone have instructions on how to do the bypass via hardware?
I heard the software bypass eventually will ruin your system.
Anyone have instructions on how to bypass the F900 to play DVD's via hardware?
Posted Jun 05, 2009 · 21:16 UTC#9
ruin your system? that is completely false. if you want the hardware bypass, just do some searching. its been answered a billion times. moev the mute wire from 4 to 1, or 1 to 4. cant remember. go search for 2 minutes and you'll find quite a few threads and hundreds of posts about it.
Posted Jun 05, 2009 · 21:39 UTC#10
I found a thread.
Is this correct?
From WIRE SIDE of small white plug
Mute wire (YEL/BLK) is in upper row, left pin
Move this wire to lower row, 4th pin from the left (empty pin between 2 black wires)
the pin directly below the mute wire does not work
Ground YEL/BLK & LT GRN and you're good to go
Posted Jun 05, 2009 · 21:45 UTC#11
sounds about right, tho i didnt do the hardware bypass. software was much easier for me to do. couldnt be bothered pulling the unit out of the dash and splicing wires.
the lt green to parking brake was enough for me.
Posted Jun 05, 2009 · 21:56 UTC#12
Cool. Hopes this works.
Posted Jun 08, 2009 · 20:31 UTC#13
simply connect the handbrake wire to the black wire and everything works, easy as that!
