AVIC "F" Series Bypass (Picture Guide)
By Wizzard005 · Aug 07, 2008in Hacks/Mods💬 336 posts👁️ 357,899 views
Page 13 of 14
Posted Jul 19, 2010 · 15:20 UTC#301
Another success story, all worked perfectly :D
THANKS.
Posted Jul 31, 2010 · 17:05 UTC#302
thanks, worked with no problems grounding to the chassis and not the radio ground.
Posted Aug 03, 2010 · 06:50 UTC#303
For what is a good this bypass ??????
I have F900 and picture from dvd i have normal too wheen i drive ??? I have every times conectend wire cable from parking to the +, is enything iferent wheen i have nect every time parking wire or wheen i have bypass on the audiocables ?????
what is better and why ???
Thank you
Posted Aug 03, 2010 · 07:06 UTC#304
You are clearly not in the US so this doesn't apply to you.
Posted Aug 07, 2010 · 05:49 UTC#305
i just purchased a x7115bt, I am interested in having the mod done. Is there a place I could take it to in washington or a member that has done it that could assist?
Posted Sep 11, 2010 · 23:23 UTC#306
I heard this works for the X920 also, or am I mistaken. I thought the bypass for the x920 was to move the wire one spot over, this one is one down 3 to the right. im confused. Thanks for any info...
Posted Sep 11, 2010 · 23:54 UTC#307
Its true for the previous X series only. Not the 920.
Posted Oct 12, 2010 · 18:45 UTC#308
Hi ,
every one he has Pioneer Avic F500bt
i have Bypassed mijn after along time of searching in the internet I was sad that i can't find the way
but after i read the Bypass for Avic F700bt and the speaking about breaking park speed and cutting wires
i went to my car i toke my avic out and all cables then i found the breaking park wire witch has this lable
" breaking park "
****** Conect this wire to the Ground wire ********
That's it .......Done
Now I have fully control of my avic
playing video while driving
using all settings
full control of my Nav
full control
I hope that i did something makes the owners of the avic F500bt happy
if some one else found this way and post it here and i did not see it before sorry for this because i was tired form long searching and i did not find it before
Posted Oct 12, 2010 · 18:54 UTC#309
This wont work for US units.
Posted Oct 13, 2010 · 00:44 UTC#310
i did try in my avic f500bt here in belgium and its working fine
Posted Oct 13, 2010 · 01:34 UTC#311
That has always been the bypass proceeded for non US units.
Posted Dec 02, 2010 · 13:42 UTC#312
does the vss wire still have to be connected for this bypass to work. Please give a full description of what needs to be connect beside the obvious bypass!!!!!
Posted Jan 26, 2011 · 21:09 UTC#313
Hello everyone, I have an AVIC-X9115BT
Do both methods of bypass (hardware and software) work well for this AVIC?
Edited Jan 26, 2011 by Kraftwerk
Posted Jan 26, 2011 · 22:12 UTC#314
Yes they do, I would prefer the Hardware bypass though, it is not hard to do and it works 100%!
Edited Jan 26, 2011 by abb1
Posted Jun 23, 2011 · 18:04 UTC#315
Edited Jun 25, 2011 by nhat
Posted Jun 26, 2011 · 00:15 UTC#316
From the "men of few words" dept? :blink:
Posted Aug 24, 2011 · 03:42 UTC#317
:rolleyes:
Edited Aug 25, 2011 by Pogigreg
Posted Oct 11, 2011 · 04:37 UTC#318
Hi
I just bought a AVIC-F30BT, how do I bypass it?
My car has a can bus adaptor (Skoda SuperB)
If I look in post 1, I should move the mute wire, my problem is the myte wire in this radio is in pen 1 and not 2
and the place where it should be moved to, there is allready a wire.
And the hand brake wire goes into the canbus adaptor.
Should I cut the handbrake wire from canbus adaptor and then ground the handbrake wire from the radio?
hope you guys can help me out
Best regards
Providers
Posted Jan 29, 2013 · 19:46 UTC#319
Hi all...
i read every post about software bypass.... but i don't know how to do it.
i can get into testmode and i copied USER folder and NDATA folder to SD, i search DATA.ZIP file but i can`t find it.
Please, i need help about that.
I've got an AVIC-F840BT, fw ver 4.001.... on a Golf MKV with DSG... i can play videos without handbrake, but when the car reaches about 10km/h the warning message appears.
Thank u.
Posted Feb 23, 2013 · 11:34 UTC#320
I have the exact same problem. Can't find DATA.ZIP file in any of the folders.
I have an AVIC-F9220BT.
Posted Feb 26, 2013 · 12:46 UTC#321
hi, i'm about to receive a HU F40BT.
is this method work on it ?
i'm newbie...
thanks
Posted Feb 26, 2013 · 21:42 UTC#322
The reason why some of you (including my self) can't find the DATA.ZIP file is that it is only on units with Igo navigation.
In my case (AVIC-F9220BT) the navigation is Pioneer's own navigation software.
Posted Oct 07, 2013 · 13:12 UTC#323
Hello, I know this is an old post however, I'm a newbie to this stuff with the Pioneer head units.  I recently bought an AVIC-X4500BT.  Will moving the mute wire from row 1 and pin 1 to 2nd row, pin 4 work for this model?  also, does anyone know if there are hacks/mods i can do for this model?  i'm hearing not much for the AVIC model but just wanted to check with you all.
Posted Oct 11, 2013 · 11:51 UTC#324
Look here
Posted Nov 07, 2013 · 21:02 UTC#325
Thanks for this thread!
Page 13 of 14
