cntrylvr79 said:
Ok try this.
Step 1. Remove ALL of the stupid plastic taps and properly splice the wires together.
Step 2. Check the pin that you added to the avic harness. Make sure it's seated properly and doesn't push itself out when you plug it into the avic.
Step 3. Plug the harness back into the car and into the avic.
Step 4. Turn the ignition on.
Step 5. Grab a ballpoint pen, paperclip, or some other small object and push and hold the reset button for at least 5 seconds.
Here's a pic to help. The reset button is circled in yellow.
alrighty, tried your suggestions and still no go...
I looked under the settings menu => hardware info => connection status, and while the car is stationary, the parking break status says "ok". once I start driving, it changes to "off". really strange...
