Posted Nov 29, 2006 · 02:48 UTC#26
well thats one problem. theres another wire such as the yellow with black stripe, get that pulled out it is normally for the cell phone mute and use that in the place. you will slide it out by pushing down the little metal tab that holds it in the connector. then slightly bend it up to slide it back into the corner where you have the black wire now. then check things out.
