HOW TO: Replace Red Arrow With Car Image
By skicrave · Aug 26, 2008in Hacks/Mods💬 228 posts👁️ 74,054 views
Page 8 of 10
Posted Apr 28, 2009 · 22:41 UTC#176
idt believe me that I have read and tried to do it, but cannot do it, I refer to 3d car
Thank you
Posted Apr 28, 2009 · 23:05 UTC#177
Thank you
here's the link to the process http://avic411.com/forum/viewtopic.php?f=34&t=17490&start=45#p116696,
personally i don't like the BMP pasted on the top of the arrow , i don't know if anyone has encounterd slow drawing time of the map and lagging issue when i used a bmp for the 3D vieew,
Posted Apr 29, 2009 · 01:24 UTC#178
So are you a 350 owner too? or just fancy something different to the boring triangle?
doh sorry, missed this post earlier. :oops: Not quite a 350, its a 150 :P . F-150. :mrgreen: Yea just trying to replace the boring arrow. I tried it once but the image wouldnt appear. Not sure I understand the hole alpha mask/layer stuff.
Posted May 02, 2009 · 00:37 UTC#179
Is there anybody who can double check my work (see a couple posts up). I tried creating a new .bmp file thinking that the file may be corrupt and wasn't able to make any progress. I then tried Steph's .bmp file and had the same problem... "System startup in progress. Please wait." Several minutes later the system reboots.
Thanks for the help!!!
Posted May 02, 2009 · 01:17 UTC#180
woa... got it! sheesh, only took a couple weeks!
Posted May 02, 2009 · 03:08 UTC#181
Hey I pm'd you back.
I had the reboot problem too. I think it has to do with the way I zipped the file back. I never did find the Proper way to zip the data file backup. I tried 7-zip and windows default zip and basically had the same issue as you. Maybe someone can go over the proper way to zip things up such as compression ratio.
Anyways, congrats on getting it to work.
Posted May 03, 2009 · 00:58 UTC#182
Thx for the reply, appreciate the help. Next two items are getting the alerts working for my cameras and then changing theme colors. I haven't yet given the alerts a shot but the colors seem oddly difficult for me. lol
Posted May 11, 2009 · 20:16 UTC#183
Here is probably an easy one for someone... I now have the picture of my truck working but there are two problems.
1) when I hit my clock it brings up the address/house numbers under the truck... the truck is sitting too "low" and needs to be raised some so that the numbers appear under it
2) when I drive across a street it is crossing the road at the front of my truck (where the point of the arrow used to be).
Basically, I'd like to raise the truck by the width of my house numbers. Which value to I raise? I noticed something different in the navigate.ui file from the 800x480.ui file.
Thx.
Posted May 12, 2009 · 02:52 UTC#184
I would guess this one
Step 5: Edit data.zip\ui_pioneer\800_480\ui\navigatemap_800_480.ui to add the following lines in the very first layer section:
My guess it would be the y axis, just decrease the value by something like 20
Posted May 15, 2009 · 13:06 UTC#185
Using the instructiopns in this post exactly, I made my car. It looks great. BUT - my car is grey... and because of the alpha channel, my car is opaque! I can see through it to the road below...
How do I add the alpha channel to allow for the transparency, but make my car solid and not see through? Does the car have to not be grey? How do I make just the background clear?
Posted Jun 28, 2009 · 01:09 UTC#186
Ok guys, I'm a little confused about something here. I've read this thread a hundred times and still can't quit figure this out. I am using IDT's latest killer mod. I have replaced the little red car with a picture of my own which is gray, BTW, and is semi-transparent here too. Anyways, no problem there. But in this mod, with the horizon tilted, 2d looks like 3d and 3d looks like 2d. So, the little car image appears on the straight down, 3d view, but the top of this thread talks about adding the car to the 2d view. I have a picture of the rear of my car I'd like to show up on my tilted 2d screen but according to this thread it should be there already. I hope this makes sense. What am I missing here.
Posted Jun 28, 2009 · 06:47 UTC#187
you got it all all wrong, the "tilted 2D" that you're talking about is the actual 3D,
Posted Jun 29, 2009 · 01:53 UTC#188
Well, that explains it! I was under the impression that I was in tilted 2d mode because of the North up dilemma or some such thing. Apparently, I got my thinking backwards. Thanks, IDT.
Posted Jun 29, 2009 · 16:38 UTC#189
no prob
Posted Jul 07, 2009 · 20:54 UTC#190
Does nightcarghost.bmp has to be totally back?
I'm working on mine at the moment and want to check with the gurus :D:mrgreen:
Cheers,
Stan
Posted Jul 08, 2009 · 17:36 UTC#191
I followed the steps here with my F7010BT (same as F700BT), using the arrow in the post:
viewtopic.php?f=34&t=17490&start=30#p116640
Copied to Data\ui_pioneer\common inside my data.zip file as there is not a folder in my Data.zip file called "DATA/pioneer_ui/common/"
I renamed the images as instructed:
Confirmed they are in the Data.zip file and it is compressed.
everything works perfectly except the arrow is not changed....
Any hints on what I am doing wrong?
Posted Jul 08, 2009 · 19:31 UTC#192
BUMP... anyone?
Posted Jul 08, 2009 · 21:43 UTC#193
Could someone please make an image below to daycar and nightcar for me(not 3d)???
I tried myself and as soon when the system loads and I press map the unit reboots each time :cry:
Its a photoshop file with daycar and nightcar layers that I would like to use :mrgreen: .
If anyone could do it for me it would be awesome! 8)
Thanks in advance,
Stan
MyArrow.zip
Posted Jul 09, 2009 · 04:22 UTC#194
Thanks in advance,
Stan
ok try this, let me know how it goes, probably post a pic of it
car.zip
Posted Jul 09, 2009 · 06:07 UTC#195
Nice IDT, I will test it in the next 20mins or so :D .Will post back asap!
Cheers,
Stan
Posted Jul 09, 2009 · 15:39 UTC#196
anyone had success changing the arrows on F700BT model OR after updating to 2.006? If so please reply with how you did it... See my posts above.
Posted Jul 09, 2009 · 18:30 UTC#197
Had a test run and it works perfect, but its kinda too bright imo. I couldnt take a pic because my camera died on me :(.
As soon as I get a chance I will snap few of them :)
How did you manage to get em done IDT?
I tried with white background, black, none neither worked :(
Cheers,
Stan
Posted Jul 09, 2009 · 19:44 UTC#198
Cheers,
Stan
i just used PS
Posted Jul 09, 2009 · 19:45 UTC#199
Cheers,
Stan
I cannot figure out why mine wont display the daycar.bmp or nightcar.bmp I inserted in them. They are in the right folder, etc. Mind letting me take a look at your data.zip file to compare? I have also attached the BMP files, would be INCREDIBLE if anyone could see if there is a problem with or point me in the right direction..
daycar-nightcar.zip
Posted Jul 09, 2009 · 20:46 UTC#200
If IDT managed to do it I must get it too :)
I'm sure I am making a mistake somewhere.
Do you have to save them as 16bit 24bit 32bit?
I only tried 24bit in mine. Also do you have to leave transparent background?
Cheers,
stm
Page 8 of 10
