Win CE boot files
By tacomaboy · Aug 28, 2008in Hacks/Mods💬 142 posts👁️ 103,393 views
Page 6 of 6
Posted Oct 13, 2009 · 01:20 UTC#126
im trying to do the software bypass and i donloaded the 2 files u posted to download inorder to load up the windows on the avic. when i insert the memory card and turn the ignition on it loads up and goes to its original menu. i've done the software bypass in the pass and it worked but like a month ago my avic got messed up and sent it to pionner because my screen wouldnt turn on and show my splash screen but once it would load up to show the menu or play music it would show down on me. i also installed the 2.0 software on my old one and it wourked perfectly. now it doesnt. i looked up to see what version it has now that i recieved it back from pioneer and it says 2.006000. what can i do now> any suggestions?
Posted Jun 23, 2012 · 15:28 UTC#127
Ok I have the
AVIC X710BT and I have tried booting into CE with nothing appearing different at all. Followed and downloaded the Test mode and the other file I have the update all three as directed, I also switched SD cards to make sure it was not the problem...Radio just boots up like normal....What can I do to get into the CE ???
I already had 3.020100 update...HELP
Posted Jul 08, 2012 · 03:57 UTC#128
You need testmode_v2.3 inside this need to copy and past folder labeled testmode to root of SD
Posted Jan 20, 2013 · 10:46 UTC#129
Hi,
I've read every post in this topic amongst various others.
I can't get into Test Mode.
  • I have a F9310BT (EU)
  • I formatted my MicroSD card (FAT32)
  • Downloaded TestMode.ZIP from the first post in this thread
  • Extracted the files
  • Copied both 'MiTACAP' & 'Testmode' folders to the root of the MicroSD card.
Go to my car, insert MicroSD card turn on engine, Stereo boots up as normal, no test mode.
In various instructions it says to turn the unit off and then back on, however there doesn't really seem to be a way to turn the F9310BT off (it just state's OFF but the unit is still on).
I'm using a Mac, however with the same SD card, i managed to install the RadioRecepton Firmware update, I do this simply by inserting the MicroSD card whilst the unit is on.
What am I doing wrong, I know it's not the SD card.
Posted Jan 20, 2013 · 14:34 UTC#130
reserves, F9310BT = F930BT. Not same as F900/F910 series - uses different testmodes.
Testmode for your unit does not have TESTMODE folder, but TESTMODE.KEY file on SD card.
Also, why do you want to get into testmode? I would recommend staying out of it unless you know what you want to do.
Posted Jan 21, 2013 · 09:22 UTC#131
Thanks, that makes sense.
One of the reasons that I chose this unit as I like to mess around and hack.
I'm aware of the risks, first task would be to back up, then software bypass.
Posted Jan 24, 2013 · 08:03 UTC#132
Do I only need the TESTMODE.KEY file, or the MiTACAP folder too?
Posted Jan 24, 2013 · 20:26 UTC#133
if you want to be able to access the file manager in testmode (aka file maintenance menu, to copy/replace files) - then you just need the "super" testmode.key on an sd card. I dont know what mitacap folder is or does, but not needed for testmode on f9310bt.
Posted Feb 18, 2013 · 13:34 UTC#134
Hi!
For avic D3 exist solution for enter testmode?
Not have sd card!
Thanx!
Posted Apr 18, 2013 · 04:19 UTC#135
Could some provide download information  for the testmode for the SPH -DA02
Posted Apr 18, 2013 · 11:58 UTC#136
Any any info regarding downloading the testmode package for the SPH-DO2?
Thank you in advance.
Posted Jul 29, 2013 · 16:09 UTC#137
As long as I backup my units files and store it in a safe place, I can always reload the unit, right? It seems like (again, as long as I have a backup), I could unbrick my system should I brick it, right?
My system is the AVH-P8400BH btw.
Edited Jul 29, 2013 by Rev2Red
Posted Dec 03, 2013 · 20:10 UTC#138
Hello,
This F9310BT runing to Windows CE ? What muss i do to install Garmin on a my radio ?
Thnx,
MFG
Posted Dec 24, 2013 · 12:43 UTC#139
  Hi all,
First, mery christmas for everybody.
I have an f9310bt and supertestmode key works
fine.
I want to put speedcameras inside.My questions :
- What kind of file for speedcam : txt, upd, ect..
- What folder to put this file ? User, Ndata ?
Thanks for your answer and sorry for my poor
english.
Regards
Posted Jan 18, 2014 · 05:33 UTC#140
Can someone tell me where to find the "super" testmode.key
Posted Jan 19, 2014 · 15:22 UTC#141
Never mind I found it.
Posted Jul 17, 2015 · 08:02 UTC#142
Is there a way to mod the AVIC-F70DAB?
Thank you.
Page 6 of 6
