AVIC-N5
By jocooter · Sep 03, 2008in Hacks/Mods💬 45 posts👁️ 17,235 views
Page 2 of 2
Posted Oct 18, 2008 · 17:33 UTC#26
Did you set 'TV OUT' to ON?
I just thought I wwould throw in the bypass for my N5 is working just like stated for the N4. I have seen other posts stating that N5 is like the N2 bypass (soldering the jumper under label) and that method did not work for me
now if i could get the video working on my ipod classic 160 ill be happy
Posted Oct 19, 2008 · 12:45 UTC#27
So that N4 bypass still working, you have Vss wire hooked up and can drive down road watching dvd with no glitches ever??????????
Posted Oct 19, 2008 · 13:14 UTC#28
jocooter, yes vss wire hooked up, brake wire grounded and i moved an unused wire in the harness to the second hole and grounded. and yes traveling 70 on the highway while kids watched the dvd movie (not me)
Camel, yes i turned on the TV out, i have read alot where apple changed something on the newer ipods and screws it up, i also tried downgradeing ipod software to 1.0.2 and still doesnt work,
Posted Oct 19, 2008 · 13:17 UTC#29
Posted Oct 20, 2008 · 07:44 UTC#30
THAT WEBSITE SAYS NOTHING ABOUT THE VSS WIRE!
CAN SOMEONE PLEASE TELL ME WHERE EXACTLY I HOOK THE VSS WIRE UP TO??! IT IS JUST HANGING OUT THE BACK OF MY N5 & I DONT KNOW WHERE TO CONECT IT TO ON MY CAR!
ANY HELP??
Posted Oct 20, 2008 · 13:37 UTC#31
ANY HELP??
Didn't you get any instructions with your unit? You need to hook it up to the wire in your car that carries the speed signal. You may be able to look that up if you know the make, model and year of your car......
regards
~Marc
Posted Oct 23, 2008 · 00:35 UTC#32
THANKS FOR ALL YOUR GREAT EFFORT & SUPERIOR KNOW HOW PLUMMIT BUT ILL WAIT FOR A RESPONSE THAT ISNT COMPLETELY OBVIOUS!!
DOES ANYONE KNOW THE ACTUAL ANSWER TO MY PROBLEM??
ID APPRECIATE A REAL ANSWER & NOT MORE QUESTIONS!
REGUARDS
Posted Oct 23, 2008 · 02:25 UTC#33
what is the year /make and model of your car, then we most likely can help you find where to connect the vss wire
Posted Oct 23, 2008 · 06:21 UTC#34
I Have a 1999 HONDA ACCORD LX 4 Dr. 4 cyl...
Posted Oct 26, 2008 · 16:48 UTC#35
PCM connector A pin 9 is VSS out --- blue with white wire
connector A has a total of 32 spots
Posted Oct 26, 2008 · 21:09 UTC#36
What Does That Mean? In Lamens Terms? I DONT UNDERSTAND A BIT OF THAT!
Posted Oct 26, 2008 · 23:54 UTC#37
If you don't follow that, it means you should probably have a professional do it
Posted Oct 27, 2008 · 22:04 UTC#38
This Pioneer AVIC N5 bypass worked great! Thanks :D
Posted Oct 30, 2008 · 00:31 UTC#39
Is This Going to Make My Bypass INACTIVE NOW??
I MEAN IS THE BYPASS NO LONGER GOING TO WORK WHEN I HOOK THE VSS WIRE UP? OR WILL The AVIC-N5 STILL PLAY VIDEO WHILE IN MOTION WITH THE VSS WIRE HOOKED UP?
Posted Mar 28, 2009 · 02:13 UTC#40
hey did u ever find out how u see the video off ya ipod... i need that same help.... n e info will help....
Posted Sep 19, 2009 · 21:09 UTC#41
The bypass is the same as the N4, move the mute wire in the RCA harness, very easy, and works great........
DONT solder anything, or pay for anything. just go to this link.....
http://www.avic411.com/forum/viewtopic. ... 2&p=189050
..........and there are pics to show whats wire, and where to move it, VERY EASY
Posted Sep 19, 2009 · 21:21 UTC#42
the way to make the reconize the classic 160GB, plug in a 4th generation NANO, or a IPhone 3G....Not sure what makes it work, but,it made it work in mine, and let my 3rd generation NANO work.......but, it wont charge the Classic 160gb. and if it stops working....plus the nano or iphone back in...and it make it work again
and My last post for the bypass, Ive had it dont to mine for over a year, never had any issues
Posted Sep 19, 2009 · 21:22 UTC#43
and YES, Itll still play Video w/ the VSS wire hooked up..
Posted Oct 18, 2009 · 18:10 UTC#44
This forum absolutely rocks!
If you did this hack and it does not work for you....YOU DID SOMETHING WRONG! EITHER THAT OR THE CONNECTION CAME LOOSE!
It's so simple that I screwed up the first time, thinking it can't be that easy. Just like how everyone else does it, ground parking brake wire form the rca harness, move guide-on wire (yellow/blk stripe) to different location (pin is on opposite side of the nav connection <-this is where I screwed up as there are two sets of balck wires with an empty slot in the middle) and away you go. I connected the guide-on wire (after moving it) to the parking brake wire, then grounded them both to the black ground wire in the harness. Works like a charm. This was done on an N5 with a build date of Sept. 2008.
If you have problems later on, SOMETHING CAME LOOSE! The unit will NOT LEARN about the hack.
Thank you AVIC411!
If anyone is having problems, shoot me an email or pm.
Posted Oct 25, 2009 · 17:33 UTC#45
by passin the avics n-1 to n-5
Page 2 of 2
