Any help is appreciated.
I have made a theme for my AVIC-F700-BT. I followed all the instructions I found here on the website and for some reason, when I load it into the system (my system came with the Firmware 2.0 installed) I get nothing but thick lines going through the screens and the navi disclaimer overlapping all the screens. Thinking I may have my mods incorrect, I tried it with one on this page - same thing.
So here are the steps I followed - maybe someone can tell me what I am doing wrong:
1 - downloaded a theme from this thread
2 - Using 7-Zip decompressed/extracted to pc
3 - Normally my mod changes would be saved to the file at this point but for this problem I left it as is)
3 - Recompressed with 7-ZIP using the extension ".7z"
4 - Right clicked on the file and renamed the file to image.res
5 - Copied the new image.res file to my SD card with the testmode and MiTACAP files
6 - Inserted SD card into system, turned on car and entered testmode
7 - Under MyFlashDisk\APL renamed the Image.Res file to Image.Res-bak
8 - Backed out to main menu and went into storage card
8 - Under Storage card highlighted "Image.res" and then from top menu selected "edit" then "copy"
8 - Went to location on unit where the original image.res file is located "MyFlashDisk\APL"
9 - Selected from Top menu "edit" then "paste"
10 - When copy is complete - "X" out of all windows until at main screen (which looks like a pc desktop)
12 - Shut off car, removed SD card
13 - Turned on car to re-boot the system with the new file
Do I need to do something with the data.zip file too?
I think if someone can find out what I am doing wrong here, I can get a mod here from this thread to work then I can figure out why my mod will not work (or maybe it will).
