First of all you shouldn't be copying a branding "folder". Dont unzip the file, it needs to be copied to the unit as a zip file. And there is nothing as far as that file is concerned that should affect your GPS reception. I think that is just coincidental and for whatever reason the signal just isn't getting to your unit right now. It most likely will correct itself.
Ok so I just need to copy the "Branding" folder zipped. I will try that tomorrow.
Yeah, that's why I was confused. The gps was picking up signal just fine before doing this and I lost signal right after I copied the icons so I freaked out. Just weird that the gps wasn't picking up a signal cuz I usually get "High" reception.
