Anyone ever get radio working? Any chances that it will come ?
LeetLauncher v3.0!!!
I second that, especially an update to the media player and the garmin which is full of bugs and does not save settings.
I'm not talking about an physical update, i'm just talking about him letting us know how progress is coming on geting the bugs worked out (as in radio working, ipod, etc.) I want him to take his timegetting this right, but some communication would be nice.
Sorry if you guys are expecting an update. I am busy with other projects too so I have to balance out my work load. I will release an update once I get a chance, my priority is to get Audio Video of the stock pioneer to work with the leetlauncher. If you guys can compile me a list of bugs in the meantime that would be a great. I will work on fixing these bugs once I dedicate my time to working on the pioneer unit again.
Hi nice mode, i have a question..
The Tomtom function is that tomtom installed and it it inside this mode, or something i need to buy, or is it just igo thats have a tomtom layout !?
the tomtom app is in the program, BUT its up to you to "find" the maps, poi, and other files it needs. Do you have to pay for them? Well that depends on if you know how to find them.
How to bind zoom in/out in iGO?
I know that I need to change keybind.txt from DATA.ZIP/config.
Who know UP/DOWN key codes?
And what I need to change? "[default]" key binding?
Ok IF i find the map, what folder do i then need to copy/past and where to in the mode file !?
All those instructions should be part of the TOM TOM download. As in other GPS software. the maps would go to a specific folder in the TOM TOM folder. There are several places you can find that info much more easily.
the filesDONT go into the tomtom folder from what others have posted on here, I think they have said that those files need to go onto the root of the sd card just just like the tomtom folder is, but you might want to read the first post in the thread to see for sure (he has it posted there i believe
thanks leet, 500bt hung on igo until I tried new maps and now it's great.
Everything is beautiful and functional, I can't wait for you to break through that wall your chipping at and get full access to stock features.
My one questions is this, and it's for anyone that knows...
How would I get the album preview window in the bottom right corner while in igo 8.3? Is there a skin that does this or do I have to close down igo and go back to leetlauncher to change music?
Hello. I installed Leetlauncher 3.0 and it works fine but when you start to make a flickering 5 seconds, the menu of original Pioneer appears and returns the Leetlauncher. Is this normal?
Otherwise. Tom Tom is working correctly, but does not start Igo. It gives me a Fatal Error: Initialization error: LoadLanguange failed, and I can not continue. What can I do?
Thank you very much for your great work.
Album preview on the bottom right corner does not work with LeetLauncher at this time. You have to go back to LeetLauncher to change the Music.
Hello. I installed Leetlauncher 3.0 and it works fine but when you start to make a flickering 5 seconds, the menu of original Pioneer appears and returns the Leetlauncher. Is this normal?Otherwise. Tom Tom is working correctly, but does not start Igo. It gives me a Fatal Error: Initialization error: LoadLanguange failed, and I can not continue. What can I do?
My first response is LL3.0 is not working fine if there is flickering right? LOL
How are you starting LeetLauncher program? What changes if any have you made to the program, added etc? You should be starting the pioneer unit, then inserting the card and waiting for it to detect the .mp3 you have on the card. Once that is done, you should turn the car off, then back on to cycle the Pioneer power and then it boots up into LL only. Is this part working ok?
I tried in every way, (it's an F500). Rebooting, starting usually, with the first Avic with mp3 ... It does not work.
I reinstalled Leetlauncher as it is in the forum, without maps or anything, either.
Tom Tom, I have managed to function well.
Garmin never stored language preference (I'm Spanish ) and the program suddenly quits and goes to Windows.
Garmin does not really concern me, but I need it to work Igo, is a good navigator.
I will keep trying to see what I can do.
Hi,
Does anyone knows why iGo 8 shutdowns randomly, sometimes it says shuting down in 10 seconds and at 7 will turn off.. Also, this shutdown happens mostly when I'm on the "2nd trip computer" screen. Thanks.
I got it work successfully with the downloaded files from
http://igo8.gpssoftware.us/igo8.3.htm
Since igo8.3.2 has no media player, I tried to get back to leetlaucher to use the coreplayer. But the only way to do that right now is to explicitly EXIT the navigation software. I tried to press Menu key to get back to LeetLaucher and it doesn't. May be it is one of the bug?
Also, as someone has mentioned, the dial key right now does no function at all.
I want to call your attention to the Gurjon Skin as it is really well designed and functional. It has very clear visibility and (what is more important on this forum) allow to call third programs without exiting iG08.3
You can see any from this skin at http://www.gurjon.com dowmload the 800x480 version.
I got it work successfully with the downloaded files fromhttp://igo8.gpssoftware.us/igo8.3.htm
are the files on that page the only files i need to download and put on the sd card (the map and poi) or am i missing a step. also where exactly do i put them on the card
The SD card should have the LL program and the entire IGO8.x folder with the contents to work correctly
ok got it but one last question i figured that im suppose to put the file under igo8/content/maps or poi but what is the dem folder and where do i get those files
The site mentioned has all the files you need including the DEM files. That is the terrain file if you want to see hills, mountains etc in IGO
Since this really is just a computer it would be soo awsome if we had a developer community so we can get awsome things like bluetooth internet from the cell phones pull rss feed data to our cars, and or use usb bluetooth dongles. this unit rocks! nice work leet dude
ok i ran into another problem. i downloaded the virginia maps and poi and i put the zip file that was downloaded into the map and poi folders but i get an error saying it cant read the maps. do i need to unzip the file before i put it on the card or what. and do i need to do the same with all of them(dem and poi)
Guys... i am sorry but i could not find maps for IGO8,TOMTOM,and GARMIN XT.... can anybody put these in a place so that i can try leetlauncher !!
Hi, one question i just tried this on mi 700 and works fine, i didnt put the maps i just wanted to try it but, is there a way to control the ipod using this mod??
