LeetLauncher v3.0!!!
By leetcoder · Oct 11, 2008in Completed Mods/Themes💬 844 posts👁️ 380,404 views
Page 25 of 34
Posted May 25, 2009 · 00:36 UTC#601
Im having a bit of trouble with my GPS when I click IGo initializing warning data and just stays there. I know its probably a simple thing im doing wrong.
Posted May 25, 2009 · 00:48 UTC#602
i think you have to wait for a while on that screen
Posted May 25, 2009 · 02:07 UTC#603
I dont know how all this stuff works but I did everything on the directions on the first page. Nothing changed though.
I have a 700bt and a 8gb sd card. I need step by step instructions and i dont know where to get maps or even how to install them. Thanks and yes i read almost all the pages but i dont understand half the stuff you guys are talkin about lol.
Posted May 25, 2009 · 21:39 UTC#604
If you have put a speedcam text file in the speedcam folder and its the entire US or EURO it will take about 7 mins to load up. It sounds like that is what is going on. Remove that file if you don't want speedcam/redlight warnings and it will then boot right up.
Posted May 26, 2009 · 00:33 UTC#605
Ahhh wicked!!! I just wanted to see if I liked igo better then tom tom but couldnt get it to load up, thanks alot for your help!
Posted May 26, 2009 · 00:42 UTC#606
I said it once ill say it again this is amazing!!!
Now leetcoder you asked for bugs or suggestions so if you dont mind Ill give you my input.
- right now my steering wheel controls dont work, this would be a bonus if they did but if its too hard muah ill live without
- Memory would be sweet, so when I shut the car off it would remember what song was playing so I dont have to go through it all over again
- The "OK" button on the media player needs to be bigger, I usually get a annoying keyboard when I hit it and is a pain to get rid of it.
- I donno how hard it would be to make a cool visualization like winamp does (when you click the eq bars on winamp you can have cool effects)
- FM, AM, and Ipod would be a must
- this thing is wicked!
As soon as I get a bit of cash im sending it your way because this looks promising! I just cant believe how pioneer had a team of people designing and working on this and one man out did them
Brad :)
Posted May 26, 2009 · 00:50 UTC#607
Brad :)
For the OK button, re-calibrate your unit, I had the same problemm, when I did that I never got the keyboard again.
Posted May 26, 2009 · 01:02 UTC#608
Brad :)
what do you mean re calibrate? what do i need to re calibrate
thank
Posted May 26, 2009 · 02:34 UTC#609
Brad :)
thank
Re-Calibrate your Avic screen.
Posted May 26, 2009 · 18:46 UTC#610
Do I have to put the SD card with Leetlauncher in everytime - or does it copy the files to the GPS unit
Posted May 26, 2009 · 19:35 UTC#611
SD card stays in the unit and it reads from it each time. If you take it out you have to follow the steps again to get the audio to play from the SD card. Nothing gets copied to your system.
Posted May 28, 2009 · 18:34 UTC#612
Hi, i'm Andrea from Italy.
I have downlaoded the leet launcher v3 and copy it on a sd card (before formate)
I copied it on with one mp3 file and the radio found it!!!
I turned the car off and on but it do not start??
Start it on his selve or do I have to do something on the radio to start it???
Please help me i habe not found any in the leet launcher tread. I'm desperate!
Thank you!!!!!!!!!!
Posted May 28, 2009 · 20:02 UTC#613
I am a newbie here. I just bought my f700BT and it has not been installed yet.
But none the less, I have a few questions.
1) What is LeetLauncher?
2) what does it offer the the original O.S. does not?
3) If I don't like it, how do I go back to the original O.S. that was on my F700bt?
Thank you
Posted May 28, 2009 · 20:14 UTC#614
Thank you!!!!!!!!!!
Hey Andrea,
I formatted my card but make sure your card looks like this:
And not starting with the 3.0 directory
This would probably be the problem
Posted May 28, 2009 · 20:20 UTC#615
Thank you
This is pretty much all explained on the first page
"What it do?
This launcher will boot up before the main AVIC kiosk is launch. This is the new Front end in progress, however it is no where near done. It is in its very early stage so don't expect too much out of it."
So if your sick of the boring crappy pioneer "program" this is a temp replacement.
Well its not exactly replacing the operating system, the s is windows but it replaces the "program" it uses to do everything on. I use it for the better GPS and because I got sick of the old boring screen, others for the nicer music program, everyone has a different reason.
This program is currently not copied to the actual unit. You copy it to the SD card and it boots off the SD card. So when you dont want leetleacher anymore you take out the SD card and reboot your unit and its back to original
Brad :)
Posted May 28, 2009 · 21:28 UTC#616
Guys Please tell me where do i find Garmin and tom tom maps.....
Posted May 29, 2009 · 04:04 UTC#617
Hi leet was wondering if you got the launcher to work with the pioneer kiosk was looking around nothing real specific only thing i got todo is launch garmin or igo and switch between the leet launcher and what ever gps im ysing at the time thanks
Posted May 29, 2009 · 04:11 UTC#618
im sorry but another question is can somebody help me hoe make the speed cams work on igo keep trying but it doesnt work or not coming up will appreciate it and for the guy with map needs try this just gotta look.
http://forum.gsmhosting.com/vbb/forumdisplay.php?f=491
Posted May 29, 2009 · 05:18 UTC#619
SORRY LAST QUESTION IS HOW DO I KNOW WHICH IS THE IGO OR Igo basically which are the windows ce ,ppc versions of map or poi dem i find them but people dont really specify thanks
Posted May 29, 2009 · 17:20 UTC#620
1st page is pretty specific, you only get music from SD, USB, CD, the Pioneer radio and such is not working.
Posted May 29, 2009 · 17:21 UTC#621
As far as I know depending on where you get your IGO, they are dual mode and will work either CE or PPC.
Posted May 29, 2009 · 17:22 UTC#622
you need to copy the .txt file for speedcam in to the content/speedcam folder during startup it will hang from 3-7 mins to load up the speedcams. its pretty simple.
Posted May 29, 2009 · 17:59 UTC#623
Someone can help me how put the IGO8 in AVIC D3....the D3 don't have SD card slot or USB port...please...how can i put igo inside the D3...please...help me! :cry:
Thanks in advance
Posted May 29, 2009 · 18:16 UTC#624
Thanks in advance
Is D3 even Windows-based?
Posted May 29, 2009 · 18:50 UTC#625
I don't know....it's a first time i had one of those...i has been changed one GPS by Nokia..portable one....and it's works perfect....but...i don't know how i will put de IGO8 inside the D3....because the D3 don't even have a SD/USB slots....i think try to change the iso of DVD they came with the D3....the OEM ones....but i don't know...if will work....because the D3 gps maps works on TOM-TOM data base....im from Brazil and i don't know how can i get the Brazil's maps by TOM TOM......But otherwise, the igo8 it's the best gps software i even work on.... :lol:
Thanks in advance for anyones can help me....
my Messenger is [email protected] if anyone want to a send a note about this
Page 25 of 34
