LeetLauncher v3.0!!!
By leetcoder · Oct 11, 2008in Completed Mods/Themes💬 844 posts👁️ 380,404 views
Page 7 of 34
Posted Oct 31, 2008 · 05:08 UTC#151
Leet,
Can you let the LeetTTnavigator.exe be replaced by the TomTomNavigator.exe
I downloaded this TT 7.20 and I tried on a Pocket PC. I looks really good also with the black screen.
http://www.demonoid.com/files/details/1644362/1235614/
If I replaced your .exe the application will not work and displays a message "not enough memory"
Posted Oct 31, 2008 · 05:45 UTC#152
I upgraded to the newest firmware and now when I try to select the IGO8 in the launcher, I get a "Failed To Reserve Virtual Address Space" error.
What does that mean? Any ideas how make it reserve that space?
Thanks.
Posted Oct 31, 2008 · 22:01 UTC#153
how about a navigon gps option? They have great navigation and graphics
+1
Posted Oct 31, 2008 · 22:03 UTC#154
Navigon would be nice, although interestingly enough, people in the Navigon thread over at GPS Passion are busy getting iGO on their devices... :)
Posted Oct 31, 2008 · 23:31 UTC#155
I like iGo8, I use it as my primary Nav System, I think the interface is great, I would like to have version 8.5 with those 3D buildings. Does iGo8 offer lane assistance like TomTom? Anyway... I think leet had done a great job with that launcher.
Thanks man...
Posted Nov 01, 2008 · 04:03 UTC#156
iGO 8.0 already has both 3D buildings and lane assistance. Lane assistance works pretty well here, although may be not quite as fancy as latest Navigon software. For 3D buildings you need to have 3D files, and Pioneer did not include them... :(
8.5 is very long ways off. Latest current is 8.3 and the only real improvement it seems to add is track-up in 2D mode...
Posted Nov 01, 2008 · 04:28 UTC#157
Anyone having problems running igo8 and avi together? After upgrading to 2.0 everything was fine but then I upgrade the bluetooth software and was unable to run AVIC and IGO together.
If I run only Igo it runs smooth....but when I try to run AVIC and then Igo I gives me an error.....Very strange.....anyone that hasn't done the bluetooth upgrade can try to reproduce this???
Will do some research in the weekend.
GUGA
Posted Nov 01, 2008 · 07:02 UTC#158
I will be looking into some of the problem soon. Been busy couple of the last few days from work. I need to look into the version 2 firmware. However, so far the launcher should still work with IGO8 and TOMTOM. As of right now running AVIC and IGO8 will cause problem. This has always been buggy from the start so I dont advise running AVIC with the launcher.
Posted Nov 02, 2008 · 13:23 UTC#159
So this can be run off a SD card? That would be great, so no changes would be made to the stock system.
Also I'm assuming XM won't work?
Posted Nov 03, 2008 · 08:11 UTC#160
how did you get your old ipod to work? my gen 4 does not work when the usb is attached... And when the audio is coming out, no volume control is available...
Posted Nov 03, 2008 · 13:40 UTC#161
im not sure if im doing this wrong so im just gonna go step by step of what i did. i downloaded the launcher.zip then i extracted the files in the zip to my SD card i then took the SD card and inserted it into my unit. everything starts up fine. i know with tomtom i need to add the files myself and that will be my next step but i wanted to test everything else first. when the launcher screen loads up every button i click it takes me to the ppod i then reset my unit and let it start up again i was able to click on the avic and it took me to th pioneer but after that i clicked menu again and it took me back to the launcher but when i clicked on IGO the screen comes up but then i get a fatal message
Posted Nov 03, 2008 · 21:46 UTC#162
Launcher 1.5 currently have alot of bugs, it is not intended to use for integration with the AVIC software. However, Launcher 2.0 will be out shortly, it will fix a few bugs and partially working with the AVIC software. Also Garmin XT is coming along the way with version 2.
Posted Nov 04, 2008 · 02:17 UTC#163
sounds good keep up the good work.
another question im trying to get tomtom 7 to work with it right now and i have the whole program. i know you said that we should put the map folder on the root of the SD card so thats what i did i put the north america 720.1803 folder that i have in the root and is this all i need from the tomtom program in order for it to work on the launcher
Posted Nov 04, 2008 · 04:52 UTC#164
LeetLauncher version 2.0 is released. Please read carefully before using. Go to page 1 for download.
Posted Nov 04, 2008 · 06:49 UTC#165
thanks again for the goodwork man. I will try it today and report back soon.
Posted Nov 04, 2008 · 09:36 UTC#166
Hi Leetcoder,
Thanks for all of this.
Is it possible to add GPSDash to the launcher?
So I can use this in rally's.
Keep up the good work!
Kind regards,
Pagi
Posted Nov 04, 2008 · 13:30 UTC#167
i tried the leetlauncher 2.0,here are my first impressions;
-The new intreface is good. Also presing the directional down button easily minimizes and pressing again birngs back the menu now.
-If you try to first run Avic System, then trying to run igo8 is unsuccessful because it gives an error that it can not allocate memory space or something.
-Also if i first run igo,then run Pioneer Avic System,it can not connect to mobile phone via bluetooth.
-Tomtom works nicely.
-Garmin asked some licence code so i did not deal with it yet but i think it is mobile xt version.
Posted Nov 04, 2008 · 13:51 UTC#168
im using the north america 720.1803 folder for tomtom and its telling me its the wrong north america maps which ones do i need
Posted Nov 04, 2008 · 15:49 UTC#170
So all this does is allow us to use different navigation systems instead of the built in one? Are they that much better?
Posted Nov 04, 2008 · 18:48 UTC#171
For now apparently, yes. However, from previous posts, it seems like Leet is also trying to incorporate a media player that will play off a HDD via USB. LeetLaucher is great and simple to use. Why not give it a try and see if you like the different options... if not stick with stock.
Personally, I like the look and feel of Igo8 much more and am glad that the option is there for me.
Posted Nov 05, 2008 · 01:23 UTC#172
What size SD card do you need to fit all these maps and apps? Where do you find these working maps? I've tried a few and can't get them to work. Only one I got working is IGO8.
Posted Nov 05, 2008 · 08:37 UTC#173
Hi Leetcoder,
Kind regards,
Pagi
Possible, but not right now I have other things to take care of. I can add a section for apps request later for those that want to run certain ppc apps. Also you can always try to see if it runs first without modification, I know that some of the ppc apps actually run without changes. The Launcher is modifiable, modify it and add another icons linking to that application.
Posted Nov 05, 2008 · 08:40 UTC#174
Preferably a 4GB card to 8GB. On average North America maps are usually 1-2GB. SD cards nowadays are cheap just get 8GB :)
Posted Nov 05, 2008 · 12:58 UTC#175
will it cause any problem if i keep my music on the same SD card that i have the launcher on and will it play when im in the launcher?
Page 7 of 34
