Thanks i will give it a go. To bad the readme is also russian. me and babbelfish will be spending some time together this weekend. Also if that is the guy putting out the hack it says on the information page the are putting development on hold.
You're welcome.
Actually Gurjon is sitll producing skins pretty actively, they are just trying to deal with NavNGo releasing multiple 8.3.x releases that break existing skins, and AVIC patch is by someone else.
I can translate the readme easily. Actually, here it is (adapted for us a bit):
Speed Camera Pathc 3.9
Supports iGO 6 and Ultra skin voices
Do not use for skins with voiced radars.
Installation:
1. If there are no other patches, extract with the same structure
2.
Voices:
1. iGO 6 voices go into root of AUDIO folder inside main iGO folder
2. Ultra voices go into AUDIO folder as follows:
Riussian - Audio\RU\voice_male (and voice_female)
English - AUDIO\EN\voice_male (and voice_female)
American - AUDIO\US\voice_male (and voice_female)
...same for others...
Settings in voice_var.ini
1. Visibility flag in islider - for both voices
;US English Male - (0- hidden, 1 - visible)
2. Pauses before second part of the phrase (speed limit) - only for Ultra voices
; US English Male
vSoundDelay0.set 10
vSoundDelay1.set 30
vSoundDelay2.set 70
vSoundDelay3.set 190
These values can be any positive number multiple of ten.
Missing languages turned off.
Camera overspeed warning signal
1. You can choose from 6 stock sounds and 4 user sounds (the later needs to be called the same as button and placed in AUDIO).
2. To turn off stock overspeed warning, add to SYS.TXT or SISTEM.INI
[warning]
overspeed_sound=1
