You could simply apply files that are changed for speedcams (one line in SYS.TXT, not strictly necessary), speedcamXXX.ui, and placeXXX.ui on top of Mav's mods. I do not think his change any of these files...
Speedcam and Place UI files, and not setting and place ones? That might be why I had the problem. Any new BMPs that need to be moved over as well?
I am asking because your zip had the latter 2 and not the speedcam one in it.
Ceger
I made more changes than just speedcams in mine. Settings could be used too, but they mostly let you turn cams on and off, if you turn them on in SYS.TXT they will just stay like that...
Is that why you said that the debug addition for speedcam enablement in the SYS.TXT file was unnecessary? Also, did you mean to include the SpeedCam UI's file in your zip then, as opposed to Setting UI's?
Just trying to sort this out, otherwise I will just have to find the time to integrate the Mav mods into this DATA.zip file.
Ceger
