Awesome job, congratulations to all involved in this data file....the best I've seen so far!!! Keep up the good work!
Isn't a good ideia to implement the speedcam warnings in this DATA file too?
GUGA
GUGA
GUGA
Speedcam stuff is included in this. I think you might just have to turn in on in the navi's warning screen.
badass mod!!
Is there anyway to make the green rectangle box on top that shows mph and altitude a little smaller so we have more map space? That would be greatly appreciated!!
Thanks in advance ![]()
Would this work on EU F900BT knowing UNITS are differents and we don't have MSN ?
Answer to myself and to others : yes it does work with EU F900BT, and untis are in kmh and meters. ![]()
thanks for the data
Nice work! I have your map layout in with the 3d buildings and speedcams. I like the setup. Thanks again!
Now I just need to find a legitimate torrent of the updated maps. ![]()
i think that the hardest thing about this mod is finding the updated maps with the buildings as well! nice mod tho, my fave thus far!
Not any more....
Started a new thread on 3D Buildings as a how to with files linked.
Sys.txt and the data.zip are there as well.
Would this work on EU F900BT knowing UNITS are differents and we don't have MSN ?Answer to myself and to others : yes it does work with EU F900BT, and untis are in kmh and meters.
thanks for the data
Actually, since i've installed this data.zip on my EU Avic, i don't have any more Traffic information (RDS) (and yes, there is always traffic information in Paris !
Any idea how to correct that ??
Thanks.
is there a way to change the 3D view the same angle as when a destination is entered?
without a destination entered the angle view makes it so hard to see the next streets, i know adjusting the screen manual will do it but it can not be saved.
Any updates to the angle question?
Also...Great work! Thanks to all who have made a good Pioneer system a GREAT navigation system!
yeah i was going to ask about that, i don't think mine is showing traffic information any more either using this mod. doesn't it show traffic info even if your not currently in a route? i tried both ways and didn't notice anything either way.
GUGA
But we still need to provide the actual speedcam databases right? Either internally or on a SD? Is this the proper speedcam setup thread to use: http://avic411.com/forum/viewtopic.php?t=17945
I have MSN Direct and all my traffic works. You can go to the MSN Screen and there are two butterflies on it now. Press the one on the left and then the one on the right and you should be taken to the debug menu. might take a couple of times to get but you should see some info on last update and if you have single strength.
This is for the US version (That's all I know)
thanks mike, i'll check those butterflies out, i was in traffic today and nothing showed, also had no gas prices or any other type of data showing. i'll report back to see what is going on, also i did a "reactivation" from the MSN direct site.
EDIT: that is a good question below, does the normal traffic come from FM RDS or from msn traffic ? currently i'm getting neither.
Yeah and mine is a EU version, so there is NO msn.
Can we hope for a data.zip file that won't remove the Traffic info for the EU version ?? (where traffic info don't come from MSN but from the Radio FM RDS)
(or at least tell me how to do it ?)
Thanks for any help.
i checked the butterflies and it shows no signal and all 000's on the last time it was updated. i'm not sure what is going on. i think i might try to put back my original sys.txt to see if that works. if that doesn't i'll try to put back my last known data.zip and go from there. Any other ideas on it ? If i go to the normal msn status screen it just says connecting to msn....
It might take a day or two for the MSN info to come in. I have tuned to the strongest FM Station and left it there on my hour drive to work and by the next day all was good again.
I have had this happen many times...hope this helps.
Ok the reset button worked. I was assuming that since it stopped working right after i did this mod, that that was the cause. Thanks for the help. Hopefuly it will stay working and i wont need to reset all the time.
Yeah and mine is a EU version, so there is NO msn.Can we hope for a data.zip file that won't remove the Traffic info for the EU version ?? (where traffic info don't come from MSN but from the Radio FM RDS)
Sorry, I have no idea how to fix the EU Version. I would ask BorisM might know
Love this! It's alot easier to use and see things.
i agree it does look nice.
Question, what happened to the tilt feature in 3d mode? I applied ezrider and buildings but no tilt just zoom in and out. Im in NC.
I use 3d mode and my tilt and zoom work fine.
Tap on screen and the giant white arows pop-up. I also zoom from the volume knob. Check the Navi settings and make sure Smart zoom is where it neds to be. I think off.
This is something I would like to know how to fix. When you first enter your destination and navigation begins the navigation arrow is at the bottom of the screen in 3d mode. If your route has a long stretch the navi will switch to 2d mode, great, just as it should. The problem occurs when you are within 3km of the next turn, the system will switch back to 3d ( like it should), but the navigation arrow will now be in the center of the screen instead of at the bottom of the screen.
thanks this mod works pefectly ! even on a European F500BT ![]()
@118d What about TMC? Does it still work on your unit?
