Is there any reason you would know of for the route info button not moving to where I specify? Since I am using a modified version of the original file in the first post, I tried moving the icon to y=190, but it looks like it remains in its older position while all other icons move to where I assign on the y coordinate. And yes, I updated all three entries in that location to the same y coordinate.
Bizarre!
Ceger
Isn't that the button that is also being moveв around by script code? Search for the name of the button across script files (ones in common directory) and you should find where its location is being updated...
Got it, thanks. It was the common/ui files for navigatemap and start.
If anyone is interested, I modified the blank screen BMP file so that it has an alpha channel through where the clock is on the screen. This is only for IF YOU HAVE INTEGRATED THE LATEST VERSION POSTED BY mikegedge IN THE ORIGINAL POST OF THIS THREAD.
Download the attached BMP file and drop it into the ui_pioneer\800_480 folder. Then edit your ui_pioneer\800_480\ui\navigatemap_800_480.ui file where it calls 746_32K_MN-000_24b.bmp, and replace the name with 746_32K_MN-000_24b_alt.bmp.
It will now keep the clock visible, and to return to regular screen view, you just touch anywhere in the black part of the screen.
Enjoy.
Ceger
