You can use those, but sometimes they don't cut into the wire enough to make a good connection. There's a few different ways to make connections, just soldering is by far the best way to establish a scure and clean connection.
X2...
most of us who have installed for a living would tell you that those connectors work great... but only about 1/2 the time
I avoid em at all costs.
There is another crimp type connector that has a female spade terminal inside it and attach your new wire with a male spade terminal and then just slide it in... it's removable and they usually have a better connection, but I STILL don't like those as much as I like cutting, splicing and soldering with heat shrink... Sure, it takes longer, but it's pretty much a bulletproof way to do it.
