Ok, after what seems like an endless amount of searching, I can't find a stereo place that will help me install my in-dash navigation for cheap.
So...time to DIY.
Perhaps you guys can help me out here.
My Vehicle: 2008 Scion xB
Current Headunit: Factory
Future Headunit: Avic F90BT
Information that I have researched and gathered here:
Here's a PDF on how to install the factory navigation (if I had bought it with my car)
Here's a PDF on how to install the F90BT
Information about my wiring that I found here on this forum:
#513391: 2008 SCION XB 4DR SUV Audio/Mobile Video WIRE COLOR POLARITY LOCATION Battery LIGHT GREEN (+) RADIO HARNESS Accesory GRAY (+) RADIO HARNESS Ground BROWN (-) RADIO HARNESS Illumination GREEN (+) AT RADIO HARNESS Power Antenna ORANGE (+) RADIO HARNESS LF Speaker (+) PINK LF Speaker (-) VIOLET RF Speaker (+) LIGHT GREEN RF Speaker (-) BLUE LR Speaker (+) BLACK LR Speaker (-) YELLOW RR Speaker (+) RED RR Speaker (-) WHITE Speed Sense VIOLET (AC) AT RADIO HARNESS ALSO AT ECU MODULE PIN A8 Speed Sense purple ac radio harness Reverse Lights RED (+) AT INTERIOR FUSE BOX - TOP LEFT CORNER Reverse Light red + fuse box, top L, 30 pin plug, pin 30 "VSS Wire Behind Radio 20 pin plug PURPLE wire Pin 3"
Accessories that I'm going to buy/bought already:
Double DINN In-Dash Reciever (because according to research the F90BT is not wide enough to fit)
http://www.crutchfield.com/p_120958202/ ... r-Kit.html
Receiver Wire Harness
http://www.crutchfield.com/p_120701761/ ... rness.html
I've read the bypass threads: here, here, here, and here
Ok, please, I have no experience in installing anything electrical...so...
1st. what's my first step? I don't know how to crimp OR solder wires....which of these products should I buy?
I think these POSI-PRODUCTS (halfway down the site) listed here:
http://www.crutchfield.com/g_820/Instal ... tml?tp=990
will help an amateur like me, but which one do i buy? I don't know what guage wire sizes i'm looking for to buy the right set. I also don't know how many I need.
2nd. I'm pretty sure i'm going to do the software bypass, the software bypass has very detailed answers about what to do with those files in the SD card and yada yada
BUT
There isn't much information along with PICTURES that tell me what to do with a light green parking wire that everyone mentions very vaguely before going on about the software side of the bypass again.
What is going on with it? Please refer back to the top of the post and check out the PDF I've posted about installing the factory navigation. Is there something about the parking wire that I missed that I was supposed to do?
3rd. VSS wire, this is the information i've located about it:
Is this wire supposed to be crimped/solder onto something else? I thought the wiring harness I'm buying would have taken care of everything. Where does this wire go in relation to the harness? Does it plug directly into a headunit?
4th. Reverse wire. Same question as the VSS Wire
You can tell I've been researching everything, and I've provided as much information as I could, is there anything else I'm missing before I finish purchasing everything? Sadly, this will be the first time I've taken a car apart to install something, but I figured I'll learn from this experience.
