US Speed Cameras
By BorisM · Feb 18, 2009in Hacks/Mods💬 36 posts👁️ 6,307 views
Page 1 of 2
Posted Feb 18, 2009 · 16:50 UTC#1
Another file with US (NA) speed cameras. No guarantees on accuracy, but it is pretty large...
speedcam.txt
Posted Feb 18, 2009 · 23:07 UTC#2
I assume this data to put towards the red light speed cam thread at http://www.avic411.com/forum/viewtopic.php?t=19523.
Should these values be added or overwritten to those in either the Red_Light_Camera_us.txt or Speed_Trap.txt files or both?
Thank you in advance.
Ceger
Posted Feb 18, 2009 · 23:27 UTC#3
Looking just at the size of the file, I think it supercedes previous ones. It is also dates Jan. 2009...
Posted Feb 19, 2009 · 01:15 UTC#4
So replace, but replace what? I assume that the mod for turning on the features is looking for those specific file names. And I am not sure if both files are supposed to have the same info, or what your file pertains to; red lights or speed traps (Red_Light_Camera_us.txt or Speed_Trap.txt respectively).
Ceger
Posted Feb 19, 2009 · 01:39 UTC#5
This is combined file with speed and redlight casmeras.
iGO does not care what the file is called, as long as it is a .TXT file and placed in the speedcam directory, it will process it.
It is usually recommended to delete all other files from there though...
Posted Feb 19, 2009 · 02:18 UTC#6
Good to know. But it wouldn't hurt to have it in there with the others then.
Ceger
Posted Feb 19, 2009 · 18:30 UTC#7
Ceger
Shouldn't. For what it's worth, I can see more cameras here in Chicago and they seem to be coded more correctly...
Posted Feb 19, 2009 · 20:03 UTC#8
So where are you supposed to put this file and/or load it into the unit?
Posted Feb 19, 2009 · 20:08 UTC#9
APL2/IG0/CONTENT/SPEEDCAM folder.
Ceger
Posted Feb 20, 2009 · 21:18 UTC#10
trying to download this mod and I am getting nothing but a page full of computer script. I am thinking that the link might be broken.
Posted Feb 20, 2009 · 21:39 UTC#11
Never mind had a retard moment. Just now about the speed trap info. Where to find that? I have searched and searched, found nothing. No list to add to the files
Posted Feb 20, 2009 · 22:01 UTC#12
The file in the first post _is_ the speedtrap info.
Posted Feb 20, 2009 · 22:28 UTC#13
So the speed cam info works for the speed trap info as well? Because that is what the first file of the post is, speed cam. The last thing is, how do I add this to the system file, the line should read what? Beacause I have all that for the speed cam.
Posted Feb 20, 2009 · 22:41 UTC#14
If somebody had entered speed trap info in there, then yes... There being 36537 cameras, I would think it likely...
Posted Feb 20, 2009 · 23:01 UTC#15
Is there any line that needs to added to the line script in the system files to turn this feature on?, or not?
Posted Feb 20, 2009 · 23:30 UTC#16
[debug]
speedcam_enabled=1
Posted Feb 21, 2009 · 10:59 UTC#17
thank you boris.
Posted Feb 21, 2009 · 18:45 UTC#18
dose this work in canada
Posted Feb 21, 2009 · 18:53 UTC#19
thank you boris.
You're welcome. Does it work now?
It should work in Canada, too...
Posted Feb 25, 2009 · 01:49 UTC#20
I'm not sure how accurate this file is, as far as I know Minnesota doesn't have any speed cameras but with the new file there are now four of them on my way to/from work. Also I went to my cousins the other day and ran into one on a dirt road. I do know we have some red light cameras, but I think those have recently been disabled by the courts..
Posted Feb 25, 2009 · 02:44 UTC#21
It is not just speed cameras, but speed traps, such as places marked highly likely for a cop to be waiting to nab you.
Ceger
Posted Feb 27, 2009 · 06:26 UTC#22
i am not sure what i did wrong i copied and pasted everything into a note pad and named it speed cam then added it to the speed cam folder
but now my unit just keeps rebooting
i deleted the file and the unit works
so what did i do wrong to add the file
Posted Feb 27, 2009 · 14:02 UTC#23
Just place the file as is into the IG0/Content/Speedcam directory. Did you also make sure you had speedcam_enabled = 1 in the SYS.TXT file under the [debug] section?
Ceger
Posted Feb 27, 2009 · 14:23 UTC#24
Ceger
I'm confused now. I am using mikegedge's data.zip from http://www.avic411.com/forum/viewtopic.php?t=20651 and in that thread it states that speedcam's are enabled. that line is not in its SYS.TXT file. I copied the speedcam.txt file to its proper home, and went into the avic navi settings and it shows speedcams enabled with audio and visual alerts.
So is there someplace else that speedcams can be enabled? Or are mine really not enabled? I really cant test it here as I know there are none near me, and I would prefer to have this working before I head into Chicago today where I know there are several cams!
Posted Feb 27, 2009 · 17:16 UTC#25
If DATA.ZIP lets you turn on camera warnings, that should be good enough. For a check, open up a map of Chicago, let's say Lake Shore Drive and Fullerton (or Belmont). If you see little camera icons on the map, you are fine.
Page 1 of 2
