US Speed Cameras
By BorisM · Feb 18, 2009in Hacks/Mods💬 36 posts👁️ 6,307 views
Page 2 of 2
Posted Feb 27, 2009 · 17:19 UTC#26
I'm confused now. I am using mikegedge's data.zip from http://www.avic411.com/forum/viewtopic.php?t=20651 and in that thread it states that speedcam's are enabled. that line is not in its SYS.TXT file. I copied the speedcam.txt file to its proper home, and went into the avic navi settings and it shows speedcams enabled with audio and visual alerts.
So is there someplace else that speedcams can be enabled? Or are mine really not enabled? I really cant test it here as I know there are none near me, and I would prefer to have this working before I head into Chicago today where I know there are several cams!
If DATA.ZIP lets you turn on camera warnings, that should be good enough. For a check, open up a map of Chicago, let's say Lake Shore Drive and Fullerton (or Belmont). If you see little camera icons on the map, you are fine.
Funny that you suggest that area, as my girlfriend lives on Briar! And there is a nice little camera at the Belmont and Sheridon corner. I'll go look, thanks for the tip!
Posted Feb 27, 2009 · 17:22 UTC#27
I pass by that area often enough to remember that there is one there...
Posted Feb 27, 2009 · 17:33 UTC#28
Yup, cameras showed up. two of them actually. Thanks!
Posted Feb 27, 2009 · 18:59 UTC#29
Cool. Then get ready for lots of dog barking :)
Posted Feb 27, 2009 · 19:01 UTC#30
Yeah its either that or get the russian audio files from you and try and learn russian! :)
Posted Feb 27, 2009 · 20:23 UTC#31
i did everything in the post that VBLUE42 made.
and everything works fine with no problems.
but when i try to change the speed cam and traffic cam files to
the file from this post it no longer works.
when i hit download on this one i get all the info in another window
so i copied and pasted into notebook so i could add it to the speed cam folder but it no longer works.
should i not copy and paste.
sorry i know just another newb
Posted Feb 27, 2009 · 20:40 UTC#32
Or that... although as is they do not get rid of barking (camera overspeed), they just replace the warning beep with something more intelligible...
Posted Feb 27, 2009 · 20:40 UTC#33
Right-click, save as file (speedcam.txt). Delete everything in content/speedcam, copy the new file over.
Posted Feb 28, 2009 · 00:46 UTC#34
ok thank you very much
Posted Mar 06, 2009 · 20:07 UTC#35
Okay guys. I noticed that this new +1MB files has all the TYPE fields as 5 and some 3's. No speed settings.
The files from the other thread; Red_Light_Camera_us and Speed_Trap.txt have TYPE's of 7 and contains speed settings. I am assuming the TYPE means something :)
So now I am confused to which file is better? How does it know the difference from a Speed cam or Red Light or are they the exact same thing?
Posted Mar 23, 2009 · 15:16 UTC#36
:BUMP:
Just trying to see which files are the most current to use :)
Page 2 of 2
