2007.07 maps?
By blazer037 · Feb 27, 2009in Hacks/Mods💬 116 posts👁️ 22,715 views
Page 2 of 5
Posted Mar 02, 2009 · 01:03 UTC#26
Boris,
Do you have the updated map for the District of Columbia?
All I have should be in the post... DC should be included in US maps on the first page...
Posted Mar 02, 2009 · 10:55 UTC#27
Hey Boris... This might be noob, but i havent gotten a chance to try it yet, these maps seem awesome and all and i only downloaded CA. thinking these were gonna be pretty small... but it turns out, they are like nearly a gig or something.
Well this fit into our systems fine? and im guessing we can only fit 1 or two states huh?
Posted Mar 03, 2009 · 06:06 UTC#28
so I just downloaded California and Nevada...
How do I go about updating my maps?
I assume Test Mode...
but do I unzip the CA and NV maps, and copy them over?
And which directory do I copy them over to?
Posted Mar 03, 2009 · 16:57 UTC#29
Map files (.FBL) are about the same as stock ones. Still, you need to back up your existing map files (just in case) then copy new FBL files into MAP folder. Entire US/Canada fits with room left over.
Posted Mar 03, 2009 · 17:44 UTC#30
I'm assuming we have to rename the new one the same as the old .fbl file correct?
Posted Mar 03, 2009 · 18:21 UTC#31
Not really, iGO will look at all FBL files, determine if you have a license for them, then use the latest map for any given region it has.
Posted Mar 04, 2009 · 04:48 UTC#32
OK, what do I need to get UK 10/2008 map to run?
EZRIDER hack?
Licence file?
And if so, where do I get em?
I have searched, but I can't grasp this. Mental block methinks..... :shock:
Posted Mar 04, 2009 · 16:33 UTC#33
They should both be posted somewhere in this forum ;) Probably in using Euro maps on AVIC thread...
Posted Mar 04, 2009 · 17:33 UTC#34
Thanks Boris, but I eventually found what I needed, think I'm spending too much time on my mods and my head's getting crammed!
Dropped Licence and EZRIDER into Avic and now I've got 2008/10 maps running :D
Posted Mar 04, 2009 · 17:47 UTC#35
Cool. Wish we had maps that new :)
Posted Mar 04, 2009 · 18:25 UTC#36
After thinking about it I reckon it will be hardly noticeable TBH Boris, that's assuming the only difference between maps is actual changes in existing roads/highways, addition of new roads/settlements etc.. As far as I can tell the appearance of the new map is the same as the old one, but that will be down to the skin and theme.
Anyways, it's gotta be better running newer rather than older maps, so I'm happy it's done now :D
Posted Mar 04, 2009 · 18:34 UTC#37
Indeed... Maps do not have any appearance data in them. Still, there's enough road construction going on to make new maps useful. Also, I'd expect things like speed limits, house numbers, etc. to be improved with each release.
Posted Mar 04, 2009 · 18:34 UTC#38
Posted Mar 04, 2009 · 18:48 UTC#39
....... I'd expect things like speed limits, house numbers, etc. to be improved with each release.
Ahh, something I never thought of........ you're a clever man :wink:
Posted Mar 04, 2009 · 20:03 UTC#40
It is noticeable me for me, I'm now using the 2008.10 UK maps and they include 2 new major road changes that were not in the stock maps.
Posted Mar 05, 2009 · 01:55 UTC#41
how would we know if we have the latest DEM files and building files?
Posted Mar 05, 2009 · 05:02 UTC#42
Are the POI files working for anyone? So far I've only done Minnesota, but the POI file didn't work. The map works fine however, basically i looked for a restaurant today near my current location and the nearest one was 40 miles away. I looked at some of the other POI's and realized they were in Wisconsin, so I threw in the SD card and used my backup POI file and all is good again. Would kind of like to get the new file working though, any ideas?
Posted Mar 05, 2009 · 09:21 UTC#43
Not loaded mine yet, I'll do it tonight and see if they work for me, but remember I'm in UK
Posted Mar 07, 2009 · 04:11 UTC#44
So are the 2008.1 the latest ones for our version of IGo?
Posted Mar 07, 2009 · 05:55 UTC#45
i think it's 2008.4
Posted Mar 08, 2009 · 07:27 UTC#46
For US, yes.
Posted Mar 10, 2009 · 21:20 UTC#47
Try here for 2008.10 european maps:
http://rapidshare.com/users/55KH8G
Password: ppcwarez
I just tried the danish map and it seems to work alright - so i guess I'll spend the evening downloading the rest of them...
I try to get Germany 10.2008 work. I replaced Map, Pois and worldwide lic.
Does not work, no german map is displayed :?
Same Problem with 5.2008
Did i forget something?`
Posted Mar 10, 2009 · 23:07 UTC#48
Password: ppcwarez
1. Make sure you're using iGO 8.0 maps, not iGO 8.3.
2. Try a different license file. I've posted a whole bunch of them....
Posted Mar 10, 2009 · 23:08 UTC#49
For US, yes.
i thought it was the 2008.04
Posted Mar 11, 2009 · 00:05 UTC#50
For US, yes.
Never seen those anywhere...
Page 2 of 5
