Apple Theme Completed!!
By imBasketCase · Mar 07, 2009in Hacks/Mods💬 164 posts👁️ 39,381 views
Page 6 of 7
Posted May 27, 2009 · 02:17 UTC#126
how exactly do i put this on the unit i have the F90bt
Posted May 27, 2009 · 03:29 UTC#127
http://avic411.com/wiki
8)
Posted May 27, 2009 · 04:19 UTC#128
hey man i am new at this and im old. but i got this new toy. first can you help me with this. i got a card that is formated for the fat32. now when i hooked it up to my pc. the pc advised that i need a program to open it up. so there i am.......what next and then please help me hype up my f90bt>>
Posted May 27, 2009 · 04:21 UTC#129
hey guys im not too good at this stuff but it looks great. can anyone give me a step by step on how to do some of these kick ass mods??
HAHAHA trust me... ive been doing this for a while now... and even i dont even know where to start.
but a journey of a thousand miles begins with a jog
so the question to you is.. what do you want? and what do you want first?
hey
Posted May 27, 2009 · 04:22 UTC#130
hey
hey im sorry i posted late and it went down alittle ways. can you see it
Posted May 27, 2009 · 15:21 UTC#131
first off you better stop posting same topics on different threads,
Posted May 28, 2009 · 19:21 UTC#132
Hey all, I've just started getting into custom icons for my F700BT and I've got a question. I've got replacement .bmp files for the Nav/Contacts/AV icons that I want to use but I'm having trouble adding them to the Image.rec file. When I use 7zip to have the file open, I click the Add button but get "Operation is Not Supported". If I try to drag-and-drop the files into the archive I get a "Not Implemented" error. Any ideas what I'm doing wrong? Is there another program to open the .rec file? Or, if I extract the .rec file, what settings in 7zip should I use to re-compress it?
Posted May 28, 2009 · 19:53 UTC#133
Well if you have the file, you can 7zip.. its free. extract it. thats only if you wanna modify. Now if you just want it to work, my file should say "image.res" meaning that its ready to rock and roll, just drag and drop it into your system.
your gonna need the testmode files to boot it up, and of course back up your system by copying your whole flashdrive into the SD card first.
Posted Aug 03, 2009 · 19:12 UTC#134
Does this work on 3.0?
Posted Aug 03, 2009 · 20:49 UTC#135
Yes. The A/V part of the AVIC, which the Image.res covers, has not changed much from 2.0 to 3.0. The only thing that will need to be fixed would be the box that comes up on the Nav screen when a phone call is in progress.
Posted Aug 03, 2009 · 21:08 UTC#136
Do you have to edit a particular file?
Posted Aug 27, 2009 · 04:26 UTC#137
Can you give me the latest file please? I need one without the numbers you have when you were editing it.
Posted Aug 27, 2009 · 23:42 UTC#138
Could someone re-upload the file uploaded by superman posted on page 8 (for the red theme) ? The links have expired.
Posted Aug 28, 2009 · 00:46 UTC#139
Background: I am on a 90bt and this theme fully worked on the 2.0 firmware already. Once I changed to 3.0, problems started after reload:
I'm able to load the image.res, but not the data.zip file. Whenever I do, the unit boots up as normal, but after it gets to the main screen and says "system is booting up"...or something similar it will reboot. I've tried editing the data.zip file and only copying over the 800_480 folder over onto the stock data.zip and that lets me boot up, but gives me an error at the main screen that says "Failed to open file: ui_pioneer/800_480/loading.bmp, existing application". Now this is weird to me bc i've looked in this folder on the stock data.zip file and did not find it.
long story short: does anyone have a working data.zip file for the 3.0 firmware Red Theme? If so, post it.
it would be nice if it had the 3d Map view street names fix in it as well.
Posted Aug 29, 2009 · 10:25 UTC#140
Hello,
Just discovering this great theme but links are dead...
Could you please reload??
Thanks a lot!
Franck
Posted Aug 29, 2009 · 11:32 UTC#141
you should just copy the files you need instead of copying the whole 800_480 folder
Posted Aug 29, 2009 · 13:48 UTC#142
I did that as well. I even went one step further and only copied just the .bmp files that I knew I WANTED to change from the 800_480 folder and I got that weird error. And just double checking, for the people that have successfully done this, are you just right clicking and selecting compress after you highlight all the files in the unzipped data folder....or are you using 7zip and after adding all the files to the archive, just selecting zip. Because either way, neither work for me.
Posted Aug 29, 2009 · 14:04 UTC#143
recompressing them is not necessary
Posted Aug 29, 2009 · 18:06 UTC#144
Can someone reupload the red theme please??
Posted Aug 30, 2009 · 16:36 UTC#145
Is there any chance that the icon in the top left corner can remain as the stock one but made blue to match the blue theme and I was wobdering if there is a file that doesn't have then numbers on the buttons as well. Like this theme and would love to use it. Thanks
Posted Aug 31, 2009 · 02:03 UTC#146
I just did the 3.0 update and I rather like the fact that it seems to work faster than the last version. As a former Apple employee and forever Apple Geek, I was curious about this mod.
The blue apple theme download links found in this thread don't seem to work, any help on where to get them ? The install instructions seem simple enough.
Thanks for your assistance!
Posted Sep 03, 2009 · 16:10 UTC#147
how do i grab certain images from your image.res file? i like some of the images youve created like the new click wheel and main menu buttons, but i dont want to change everything that youve changed.
Posted Sep 04, 2009 · 16:28 UTC#148
I posted a link outlining how to do this step by step here:
viewtopic.php?f=21&t=25480&p=173258&hilit=free+themes#p173258
hope it helps.
Posted Sep 08, 2009 · 14:13 UTC#149
hope it helps.
what do i use to open the image.res file? when i extract the zip i gives me the image.res file, but i dont know how to open it or edit it.
Posted Mar 09, 2010 · 07:55 UTC#150
I noticed my main screen icons look different than these... its the gray one.
Anyone have the updated blue file? The rapidshare link is down for that one.
Page 6 of 7
