I have a f700 that is just stuck on the main pioneer boot up screen. I so far have tried doing numerous updates found on here, as well as the update offered from pioneer. I think maybe I need like a full functional back up file. I can get into test mode, just cant get past start up screen.. Any help would be greatly appreciated!
F900BT reboots over and over - Very weird - HELP!!
Its caused by software corruption guys not a hardware problem -
http://www.enkrypted.com/4.01.zip
Unzip this to an SD - update WinCE (Format) then copy the files from the SD to the my flash disk....... hold the reboot button for 5 seconds then you're all set. 4.01 rocks!
You have the easiest fixed problem. Need to know which firmware level you had on there. 2.0 or 3.0 then follow my reboot loop fix that's pinned up top. Files are also pointed to.
i have a f90bt with the lastest update no map version when it starts up it get stuck in blue screen i push the menu botton it go to the top menu then nothing i delete these files: gpspara0,1,2,3 i dont no what to do next and i didnt backup my unit please some one help
Read top pinned threads. Specifically the one entitled reboot loop fix
i want to thank you very very much i download your files Avic Problem Solver Files and per your directions i put the files on my unit it rebooted and now works great YOU ARE THE MAN thanks again
tundragirl22
Glad to hear it.
Hey bro , just wanted to thank you for the tip and the live files . I thought my deck was a goner , everything went smooth and it's working again . Let hope it stays alive enough that I could buy a new deck
. Thanks again .
Enkrypt3d,
Thank you, Thank you. I have searched for the past week, tried multiple download sites, RAR's, Torrent's, Zip's. But your post #177, is by far the best solution to fixing a US constant reboot problem. I was able to repair my Pioneer unit in less than 30 minutes.
I would also like to thank all of teh people who have posted fixes on this topic. I bought a used avic-F900BT this weekend and I had NO idea what was getting myself into. The guy connected teh unit to a batter so I could see that it would turn on, read discs, etc. I got the unit home and installed it in my truck and played around with getting it setup and everything worked great. I went out for my first test drive and the unit immediately started to reboot constantly. I would work long enough to change the radio channel and would reboot again. I thought i had a connection problem at first but soon realized it was not a connection issue. I jumped on google and did some searching and I found my way here. I ready through this post and I was able to download the testmode to and SD card adn deleted the files as directed and it worked perfectly. Thank you again!!!
There seems to be no maps.. I have the problem too. Have you got the right maps? When the pioneer have no maps, he cant find his GPS position..
