Some said try putting the antenna on the car metal not the glass, between the roof and headliner to hide it, they say you will get better reception that way, ima try it later sometime
Here is my digital tv tuner, but it came with a non-amplified antenna
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0301528484
I order this ground loop insulator to stop engine noise
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0327613134
I ordered 2 amplified antennas, ill put one in the front window and one in the back window
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0328735328
I ordered this to connect 2 antennas in one connection
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 2759.l1259
I applied for the coupon a while back and got it about the second week in April, I 've just yet to be on and comment on it.
The converter box I got was the Artec T3AP. It does not require a power inverter. I plugged the AC adapter into the wall and used a multimeter to determine which wire was positive and which one was negative. Since the AC adapter's output was 12 volts, I figured I could rig something up. I found that the wire with the white markings on it was the ground, and the plain black was the positive. I cut the AC adapter off and spliced the plain black wire into the cigarette lighter wire, and then grounded out the white wire. Everything is working fine too! Well for the converter box anyway. I put an HD Antennae in the trunk of my car and ran the coax wire from the back of antennae down the passenger side of the car under the trim, and then to my converter box which I secured discreetly to the underside of the passenger side of the dash, under the glove box. The antennae is powered off a 12 volt AC adapter as well, so I did the same trick I did above and ran some wiring for the antennae. When the power of the antennae is turned off, the reception sucks, the powered way is definitely the road to take.
However, I still can't figure out a way to get reception while I'm driving. It works perfectly if I'm stopped at a stop sign, sitting in my driveway, or even out in the Boonies camping and trying to track the big storm. So if you're planning on only using this when you aren't moving, such as tailgating, I would definitely go for it. If you expect to be able to drive and watch TV at the same time, as of right now I would say forget about it.
If someone finds an antennae that works while moving, please let me know, otherwise I guess this is where we sit as of now. Maybe we'll have better luck after everything goes digital?
