http://www.r18civic.com/forum/picture.p ... ctureid=27
Here is 2 pics of my HDTV Receiver with my Navi. It works pretty good. Not as good as analog TV but its pretty cool. Simple install. I currently have connected to my AV2 input which is that white IPOD wire. Any way here is what I did. First parts.
1 HDTV Receiver: Access HD Model DTA 10550D Rite Aid $19 dollars with $40
coupon.
2 Rabbit ear antenna the type that snaps in a regular tv Not Desk mount.
$1.99 at a 99 cent store.
3 9ft coaxial cable. Same place same price
4 coaxial barrel connector. This to connect two cables together.
5 75 watt inverter or power supply adapter you need the 6 volt setting with 2
amps.
6 If your going to use AV2 you need IPOD cable the has 3 RCA outputs. L & R
speaker out and 1 video out.
7 TV in signal booster.( TV preamp) radio shack $30
1 Unscrew the metal antenna ears replace it with 12 G wire same length, do not take off insulation only at the base. The base looks like a T. Install the antenna along the headliner along the front windshield. tuck it in. Connect the coax adapter to the antenna and run it along side the molding into the dash where the receiver will be. Connect the preamp to the radio hot lead .Power when the car is started.
2. Modify your cigarette lighter inverter. Add a wire to the positive tip and ground side of the inverter and connect it to a hot lead of your accessory port behind the dash. and ground to ground. Plug in the HDTV power supply to the inverter and the HDTV receiver.
3 Plug in the IPOD cable to the TV receiver and run it to AV2. And follow the instructions of the HDTV. Scan for channels and enjoy TV.
*** 4. I forgot connect a ground wire from the receiver to the car if your hear a buzz or you see lines running across your screen.
If you want to use AV1. Get a switch box and stash it in the glove box to switch from your IPOD to your TV. Here are the pics I was watching the Tyra Banks show. This is temp set up. I'm picking up the switch box today.
