Added new data.zip files and pictures choice of 2 looks now. See first page for info
My Completed Tweaks F700BT
I'm using all your files and I like it a lot!
Keep up the good work! ![]()
hi dpdurst your mode looks beautiful ,do you think that you could do to it a pair of changes.
change the format of the current speed and the clock to digital , leaving it of the same size and to change the color of the compass to make it more visible.Thank you for the good work
Hi,
got your fabulous package installed yesterday and wanted to give you some feedback on my experience:
After the initial install I had no TMC anymore, got this fixed by changing the first row of your SYS.TXT to:
[device]
type="PIONEER746EW"
like in my original SYS.TXT
after reboot there was (to my relief) TMC available again, but the road signs looked to ma as an European somewhat funny, so i changed the following in your SYS.txt
tmc_events_icon_set="$tmc.spr"
small_tmc_events_icon_set="$smalltmc.spr"
/just removed the 2 which propably pointed to the US road signs.
There is at the Moment only one question open: I copied the Eurasia.dem into the DEM folder leaving the two original files WesternEurope.dem and Eastern Europe.dem in there. My 3D still looks very bad in the upper half of the screen when zooming out a little bit. Do you have any idea on whre the Issue is? Do I have to remove the old files? You said "no" a few posts above, I changed only the german Map, do I have to change more?
Thank you for your Help and I hope you keep on showing Pioneer how to design a proper System
Jörg
Hi,
Jörg
The Dem files are what they are, there is no control in the program on how they make the terrain look. In the US there is a low and hi res Dem file, not sure that applies to Euro terrain.
Thank you for the info on the .dem files, will look around if there are different ones.
Unfortunately I did not get the new voices working: Copied them into the "VoicesFolder", but they do not show up in System settings.
Anybody got an idea?
Thanks Jörg
Page 1 has the new updated version of my Pioneer tweaks. This version has the Euro style speedcam/redlight warning and also the Euro style speed limit warning. Also some other screen changes. data6.zip is the current release
Looks great, will give it a try
Jörg
Hi have installed your DATA6 and think it looks great.
only one thing missing compared to the previous version: There is no direct access to the Sattelite reception screen by clicking the Icon any more.
And one other thing I noticed: To me it feels that with your Mod implemented the touch screen is not very responsive. Feels a bit like pre 2.0. I may be wrong with that, but that would mean the screen was even worse at the beginning.
Any othe opinions?
CU
Jörg
Any othe opinions?
CU
Jörg
Button for satellite works fine, just tried it...
Any othe opinions?
CU
Jörg
You are correct, must have been my fat fingers ![]()
Sorry
Jörg
Hello all. I am in the middle of installing this bad boy and decided to install your tweaks. I have a problem that I can't seem to get around. I followed the instructions for installing the mod. When I startup the unit it works fine. But when I try to go to the "settings" section the system settings and the nav settings are greyed out and I cannot access them. When I try to play a cd or the radio I get no audio. I am using external amps. Any ideas what could be going on? Is it something I did wrong with the mod install or is it my hardware install? Also, I did the mod install out of the car on a workbench using a 12V power supply. Could that have been the problem? Thanks guys.
I may have figured out what I did wrong but would like confirmation. I did not ground out the parking brake wire. Do I still need to do that even with the software bypass built into the mod? Thanks.
There are no software mods built into my data.zip. You will have to do that yourself or do the hardware mod. More than likely that is your problem.
yes, i am not sure if someone has already asked this, but could you possibly put up directions on how to put this on my navigation unit. thank you
Directions on how to access the unit with testmode is in the hacks area. You may want to do some searching first. The other location you can find the info is http://gpssoftware.us
well i have gotten to the point were you back up the data so far, but when you add on the new files, do i keep the data on their, or should i store it somewhere else first?
i need help, i tried to install this program after i figured out what to do, and everytime i try to access the i press the ok button to the warning screen before the map mode, the system starts itself over again like you are just starting up your car. what do i do to fix this issue. please help!i am posting this here since it has to deal with this program, and am also posting in the troubleshooting area
If its rebooting then you didn't copy either all the files or they are not copied correctly. did you install the hacked ezrider.exe and new license file as well?
please stop double posting
i did install the hacker file and i am not sure if i copied the license file. i made a backup of my files and put it back on. i deleted the mosd that i made. i am not sure if the files just aren't in the right order, or if something is still missing
Find cmh's "reset to oem" file in his post and follow his instructions. It is easy to do.
Thanks dpburst. I fixed it and it was the parking brake lead. I have another question for you. After installing the unit and all, I noticed that I no longer have the option to change the mute settings for when the navigation kicks in ie change the unit to go from full mute, to att, to disable in the "AV settings" sections. The button is greyed out. Is this part of your mod? I ask cause I want to disable to mute. Thanks.
Nope not part of my mod. My mode only changes how the main navigate screen looks/operates and nothing more than that
Thanks. I will post in the troubleshooting section. Oh and by the way, your mod looks awesome. I am loving it. ![]()
