love the mod, my only issue seems to be an error pops up when i enter a route and actually set the route, after i click "ok" on the error message it goes on to direct me on the selected route as normal.
peace out.
If it is a US or Canadian unit, download a fresh copy from the FTP and use a freshly formatted SD card to reinstall it. Follow the instructions in the readme precisely.
if it is a Euro unit or F500, you need to edit your sys.txt device type.
If you downloaded a red version of my mod, it is not my file and I can't make any guarantees about its function.
I have seen a difference in the phone operation. Ordinarily, when I audibly call a number, the screen would return to the map, where you may change the volume of the caller and hang up when finished. This mod does not do that, it remains on the "Call" screen. If you push the map button, the map is displayed, but the phone volume becomes so low you cannot hear the called person. The call must be cancelled and started again to regain the volume. even if i try to use the phone separately to hear the called person, because bluetooth is still enabled, the volume remains low.
My mod does not change phone behavior. Just entering Testmode even without installing files can cause odd behavior. Try reloading the mod and also hit the reset button.
I loaded the latest build last night. Worked fine going in to work this morning (I didn't select a route) bu I tried using both the Home icon on the top row and the Home icon on the Nav destiation screen. Both caused immediate reboots. I also couldn't get call home to work.
I literally went through every screen and set every option, actually changing a value and changing it back and accepting it. I think we need a sys.txt that has every option set to a default value. Something was missing that was causing the reboots.
Everything appears to be AOK after going through all screens (and I mean ALL screens). No idea which repaired the issue.
E
That is why it is clearly stated in the readme to go through ALL settings submenus. Some variables are only set properly once you do. When my unit was OEM fresh, it rebooted until I set a home address. Just nature of the beast.
I have posted new versions of the auto-installers that include an F500 sys.txt.
The data.zip is still dated 6.2.2009. The only other changes are a larger Wisconsin 3D-building file and a slightly tweaked Sam-TTS voice.
I am also uploading an EW version of the all-in-one that has all available Eurasian building files, Eurasian DEM file, EW specific speedcam database, the EW Testmode files, the v2.00050 hacked ezrider and license, F700-900 EW specific sys.txt, and an F500 EW specific sys.txt.
Due to the 3D files, it is quite large at over 200MB. I recommend deleting any unneeded countries' 3D files from the Mitacap\APL2\IGo\Content\Building\ folder before loading the SD card to the avic.
hey cm when i set a route as it begins to calculate an error prompt comes up it says ffu 0 command? how can i fix this?
You stated in another thread that re-downloading solved your problem. Did you change back to the red theme again? The only users reporting that issue are using the red-version that Superman posted.
I downloaded form the ftp site, and tried the nav system for the first time. I also got that wrror when I set a location to search for.
Using your software on the 700bt, the MSNdirect icon appears. Am I able to use this service now?
If so, where do I get the MSN direct #?
Thank...btw, great work on the gps software.
Noticed the 6.6.09 title for the new mod, but didn't see it in your FTP link... am I jumping the gun before it was uploaded? Do you have any release notes on additions and changes? Also assuming its ok to upload on top of your 5.30.09 build?
Thanks in advance...
B
I sthere a changelog for the new 6-6-09 build.
Also if I can make a request.
If the machine does not suppoer MSN direct, don't have the icon there.
I sthere a changelog for the new 6-6-09 build.Also if I can make a request.
You can change this in the settings to show it or not. Read his post..
Re: Cmh928 mod 4.5.09. Newbie Friendly all-in-one.
by cmh928 on Fri May 29, 2009 4:55 am
New version posted to the FTP. First post in thread has been updated.
Biggest change is that there is now only one version for download. Clcok and MSN settings are selectable under NaviSettings/Visual/CustomSettings. It is now possible to have both the MSN and History icons displayed at once. The MSN icon can be made to show while in-route as well.
IDT's Canadian speedlimit bugfix is integrated while retaining the Euro speedlimit sign option. IDT's latest speedcam warning mod has been integrated as well. Clicking an active speedcam warning box will disable further warnings and show a small icon to remind you. Clicking the icon will re-enable speedcam warnings. This setting is saved through power-cycles.
I tested the Amigo-style POI icons and the pulsing cursor, but they are not nearly as visible as the older styles. They may look pretty in still-shots, but they are hard to use at a glance while driving.
I removed MANY unneeded scripts to improve system response as well as making changes to clip-planes.ini and sys.txt to improve roadname visibility.
What is the EW.unziptosd ? Its 208 megs vs the build that was posted an hour earlier that is 78 megs...
Also, after numerous attempts, I'm getting time outs for the downloads...
Also, can I load this on top of the 5.30 build without any issues? assuming it will just do an overwrite?
Thanks...
B
Read the my post just a few above this and you will see the changes made. They are also in the changelog in the DLs as well as the first post on the thread. READ! EW is EUROPE only. Data.zip is unchanged since 6.2.09.
If people actually read the !readme! and FOLLOWED the simple instructions, there wouldn't be 99% of these questions and error message reports. Set all preferences in ALL NaviSettings submenus BEFORE using. People would see the place to turn off MSN, etc. and set all the variables needed by the new scripts at the same time. I have done all the hard work, people. Is it too much to ask that you take 5 minutes to read and follow instructions?
For cmh928
improvement for use in USA/Europe (France) :
in navigatemap_800_480.ui
big clock and tmc
road name picture clic sound
position
route name and housenumber(next and the third road name)
best font size icon in Euro SpeedLimit (3 digits)
in speedcam_800_480.ui
in France max speedlimit is 130 km/h
in speedcam.ui
new alert for "overspeed"
;Only warn on mobile if setting is yes
runifnot %navigation.curr_speedcam.category 1 'PLAYSOUND "!alert5"'
else_runif vSCWCustBeepMobile "1" 'PLAYSOUND "!alert5"'
else_runif %navigation.curr_speedcam.speed_limit.value < 131 'playsound "0_130kph"'
else_runif %navigation.curr_speedcam.speed_limit.value < 131 'playsound "1_130kph"'
else_runif %navigation.curr_speedcam.speed_limit.value < 131 'playsound "2_130kph"'
else_runif %navigation.curr_speedcam.speed_limit.value < 131 'playsound "3_130kph"'
i propose new icon for more readability
button_volume_mute
speedcamunmute_onmap
cmh928 was it possible to integrate these into the next update ?
Nope, but you can and host your own France version.
I'm pretty much done here. My unit is the way I want it. As always, the mods are done for ME. I have been nice enough to include options to suit others. I believe I'm the only one on here who has gone out of his way to do so.
This is something I do in my freetime and it is now causing me more headaches than my full-time job. There are givers and takers on these forums. No matter how much someone gives, the takers still demand more while offering nothing in return.
My mods run 100% error-free on my unit and most others' as well, but there are too many variables with past mods or pre-existing corrupt files on the Avics to guarantee anything. I feel I have offered far superior support for these issues than what Pioneer's PAID support has, but I am now done.
Grab whatever files you want from my folder on the FTP now. I will leave other people's folders available, but will be removing mine soon.
Again I want to thank you for all your work is really good. I already hosted versions of your updates that included my changes for France and European countries with the same regulations. My application was just a courtesy request. I give myself a lot on a french forum, without really having anything in return. It always asks me more
. I know what it is to spend much time on the AVIC.
I just wanted to share and not just take.
Again thank you for all your work.
cmh, I totally agree with your post. I have used every one of your mods and I have to say, I never had a problem with any of them. If it were not for you and other modders, I wouldn't been able to do this on my own. I bought my F700 in December, replacing my D3 and when I hooked it up, I really didn't like it until I found this forum. Now, it seems like I change it every other day. Thanks again.
It sad to hear. Thank you for your hard work. Nice to knowing you.
I have trouble making myself understood, I do not criticize your work, quite the contrary I admire.
Hello -
My observations include (for what they're worth):
1) What an incredibly brilliant piece of work (I've used every version without any issue worth mentioning);
2) What an interesting, informative and telling WWW historic-cycle (this thread is a study in software development by one person (a very competent eCitizen) who took on the conception, development/QA, testing, training, communication, deployment and enhancements to the point of what appears to be probable frustration/exhastion);
3) Although this may be WWW-incorrect, I'm prepared to pay to have access to a cmh928 newsletter/licensed support that will advise/provide mod updates particularly related to Pioneer 700/900 upgrades for the next 12/24 months (e.g., v.3 and/or new maps).
Self interest is a great modivater. I have learned and benefited from this experience, and hope communication can morph into a form that supports and benifits cmh928 and those interested.
BRW
What setting do I need to make so I can get the posted speedlimit for the street(hiway) I am on.
Again, great mod.
cmh928
Thanks for all the work you have done. I only bought the f-90 after reading up on yours and leet's post. i admit i only used the stock interface for 1-2 days before changing to yours and my god your version was far superior and user friendly.
So again thanks for the work / time you have poured into this... but a even greater thanks for sharing it with us.
exceptonal mods cmh. great job and thanks for sharing them!!!
