peace out.
By cmh928 · Apr 05, 2009in Hacks/Mods💬 723 posts👁️ 101,422 views
Page 8 of 29
Posted Apr 12, 2009 · 16:38 UTC#176
Here are my latest pics. My new data file has everything Cmh928 has in his. I modified it to look like my previous mod but with all the additions. I also included Boris' POI file so you can search for POI's around an address. If you want to use my file when i post it, you will have to download all of CMH928's mods, follow those directions and just substitute my data file and sys.txt file instead of his. I also included my sys.txt file as well but i do not include the smaller arrow, that doesn't bother me. If you want the arrow smaller just copy and paste this under [map] in my sys.txt file:
3d_scale_carmodel=1
3dcarsizemin=3500
3dcarsizemax=5000
3dcarsizemul=30000
That's it simple, I hope.
Here is the link, it is the same as the one that Cmh928 posted below
ftp://avic:[email protected]/GNasr74
Posted Apr 12, 2009 · 17:02 UTC#177
Sorry for a stupid question; however, is there any way not to install the new GUGA theme when i install this? Also, are the pause/play buttons always on the map screen? Can they be turned off?
Posted Apr 12, 2009 · 17:06 UTC#178
one question I have is how do I get the 3d buildings to show up. I installed the aio but have YET to see ANY buildings.
BTW looking forward to the new AIO, are you going to post up a compleat list of thats been changed in this one before you put it up (hoping you added the remove zoom/tilt thing to it... lol)
Posted Apr 12, 2009 · 18:19 UTC#179
Just uploaded GNasr's latest to the FTP.
All the files you need to see buildings are in the AIO, but if there are no 3D buildings in the map data for your area, you won't see any. Plot a course through Chicago or any other big city, and they'll be there. The pause and play buttons are only visible in simulation mode, not while actually navigating.
The current data.zips posted on the FTP have the 3D tilt mod already. The AIO's will be updated when I finsh Samantha to my liking. If you already have an AIO downloaded, using your PC you can drop the new data.zip into Mitacap\apl2\IGo\ and it will auto-install it for you.
As said numerous times before on here.... To remove the Guga Theme, delete image.res under the mitacap\apl\ folder before you put the card into the avic.
Posted Apr 12, 2009 · 20:27 UTC#180
How can i take the pause/play buttons off in simulation mode?
Posted Apr 12, 2009 · 21:05 UTC#181
Gnasr's Data.zip in CMH's all in one is perfection. Thank you guys!
Posted Apr 13, 2009 · 00:03 UTC#182
Cmh I installed your software and I am very pleased with it - it works great! One question though, I did notice that now I do not see as many street names on the map when driving - maybe it is one of the settings I need to change or is it how this software is? Could you please let me know what I need to do to get it to show up more street names? Thanks again for a great piece of work! :D
Posted Apr 13, 2009 · 00:34 UTC#183
i added a file called clip_planes.ini into my ui pioneer/ common folder. I would attach the file but the forum doesn't allow the extension. What you can do is download my file and open the data.zip and extract the file i named and add it into your data.zip file and that should do the trick.
Posted Apr 13, 2009 · 01:25 UTC#184
I have a high resolution dem file that i would like to use but i read somewhere that it is too large to use and that you have to run it off of an sd card. do you know anything about this cmh928?
Posted Apr 13, 2009 · 01:42 UTC#185
i've read somewhere that someone was able to use it but he had to delete some maps to accomodate the size of the DEM
Posted Apr 13, 2009 · 03:09 UTC#186
your right i think they had deleted some of their canadian files. i was asking because it seems like dpdurst was using in his mod but he might have deleted some files as well.
Posted Apr 13, 2009 · 04:30 UTC#187
What files do you have to modify to overlay the POI icons on the map like that? That is pretty awesome.
Also, thanks to Cmh for making such an easy to use mod, and to everyone else that contributed to it. I've been using the vanilla 2.0 software for a couple of weeks, and it's amazing how much it's been improved.
Posted Apr 13, 2009 · 13:48 UTC#188
go to destination and hit the poi button then at the bottom hit manage poi. that is where you turn on and off the poi.
Posted Apr 13, 2009 · 16:22 UTC#189
CMH, have you added the newest data.zip and Samanta TTS mod to the AIO? Last I read, you were going for a test drive with her and would post soon. Thanks.
Mike
Posted Apr 13, 2009 · 17:57 UTC#190
gnars i tried using ur clip planes file but it still isn't where it used to be when I was previously using Mav's mod. Also, do you know what the settings were for the default tilt settings because the tilt setting is bugging me lol
Posted Apr 13, 2009 · 18:42 UTC#191
Here are my latest pics...
How do you get that horizon on yours? :oops: Tilted all the way, i still dont get a horizon.
Posted Apr 13, 2009 · 18:56 UTC#192
you have to edit your sys.txt file to provide a wider range of tilt angle. download my sys.txt and look at the code.
Posted Apr 13, 2009 · 19:01 UTC#193
unless your using a modded sys.txt file, you won't be able to have a horizon. If you are using my or a modified sys.txt, then look for
[interface]
defaulttilt3d=7800 - change 7800 to whatever horizon you like
Posted Apr 13, 2009 · 19:04 UTC#194
if that doesn't work, try unzipping your scheme file that you are using and copy the clip_planes file in there and paste it into your ui pioneer/ common folder in the data.zip. That might work.
Posted Apr 13, 2009 · 19:22 UTC#195
My file already has the clip_planes mod in it. More than likely it is related to the default 3D angle as well as colorscheme being used. more tilt=fewer names.
This is controlled in sys.txt. The clip-planes file deals with 3D buildings showing up in different colorschemes,
The important bit in sys.txt is under [smartzoom] min and max 3d angles.
You can also just turn smartzoom off and turn 3D Tilt buttons on to change the angle to whatever you like.
Posted Apr 13, 2009 · 19:31 UTC#196
Yes, it will fit if you dump a few maps. I tried it briefly and removed it. The cpu is already taxed to the limit if you have everything 3D cranked up and this just makes it too slow to justify it.
Posted Apr 13, 2009 · 19:54 UTC#197
Mike
Sheesh! Can't a guy take a day off for Easter!
I took my long drive yesterday and decided that no matter how long I work on Samantha, I'm not going to be happy with her. I now have 2 versions: The one included in the AIO that is hybrid TTS and actual samples, and the one in SamTTS-Auto that is pure TTS with my latest rule changes. The sampled voice is more natural by far, but the pure TTS sounds more consistent. Install the AIO. If you don't like it, grab SamTTS-Auto and try it.
Uploading now. As always.. Be patient and give them 30 minutes before you try to DL them.
Posted Apr 13, 2009 · 20:20 UTC#198
Mike
Easter? What's Easter?
Not pushing...thanks for all your hard work, helping out the poor schmucks like me.
Posted Apr 13, 2009 · 22:02 UTC#199
Just wanted to say thanks to everyone that worked on this complete package! Its amazing what you have done! The F series is NOW what it should have been!
Keep up the great work!
Frank
Posted Apr 14, 2009 · 00:05 UTC#200
i noticed this mod has the software bypass . i did the hardware bypass . will the installation cause a problem?
thanks
hammer57us
Page 8 of 29
