peace out.
By cmh928 · Apr 05, 2009in Hacks/Mods💬 723 posts👁️ 101,422 views
Page 7 of 29
Posted Apr 11, 2009 · 20:45 UTC#151
Hi,
I really want to try Cmh's Mod but before I do it, is there ANYTHING I need to worry about?? Are there any glitches in this mod that would affect audio / video / GPS Navigation? I ask because sometimes I use the navigation for very critical tasks since I am not from around here so its vital to me that it works 100%.
Just wondering before I do this or do I have a "green light" to go ahead and do it from you guys?!
Thanks,
Mo
this mod rocks and is newbie proof just follow his instructions and make sure you backup your original file
Posted Apr 11, 2009 · 22:29 UTC#152
hey cmh928, i need a little help. i finally figured out what the problem was when i modified your mod. I kept the elevation and current speed coding, but I cant use the speed limit code i have and i have to stick with yours. I am using your mod from 4-10-09 and i would like to move the speed limit sign to where i had it in the picture, that way i can use your code and still get what i am trying to do. I thought i only had to change the x and y values but i keep rebooting. any chance you could take a look. thanks for your help. this is what i previously had:
;Display Posted Speed Limit
;Display Elevation
;display current clocked speed
and this is what you have without showing the elevation and current speed code:
;<> Start
;<> End
Posted Apr 11, 2009 · 23:18 UTC#153
CMH, I put your all in one mod on my F90BT, it works great, thanks a lot. One problem though, I can't see the clock the way mine is set in the dash. Is there anyway to move the clock to the upper right corner? Or how can I do it? I am new to this as I just got the F90 installed today and don't really know what I'm doing with the code modding and all. I did back up first thanks to the great directions on this site and your mod was automatic, very newbie friendly.
Any help on moving the clock?
Posted Apr 12, 2009 · 01:56 UTC#154
Moving the clock is one of the easiest mods you can do. Finding a new place to put it where it doesn't interfere with something else might be a challenge. It is a button as well as a clock.
Read up on how to mod x,y values and how to enter Testmode to copy files. I doubt you'll find anyone willing to make your custom mods for you.
Posted Apr 12, 2009 · 01:59 UTC#155
;Display Elevation
;<> Start
;<> End
GNar74,
I love your clean interface! Please let me know when you have added CMH's latest mods to your data.zip file
Posted Apr 12, 2009 · 02:02 UTC#156
Gnasr,
You need to do away entirely with your current speed limit script. The important thing is that the new version uses layers. You need to copy the ENTIRE layers to the same place that I had mine in nm8x4. You can mod the x,y values I have in my layers after you get them copied over. From where it says to where it says for both of the speed limits. If any .ui calls a layer that doesn't exist in nm8x4.ui, you get a reboot.
Posted Apr 12, 2009 · 02:15 UTC#157
Gnasr,
That is exactly what i did. I got everything to work, i just went one by one and just finished. It was the euro speed limit sign that was giving me the trouble. I was inputting the same x,y for the euro as the us sign and they were actually different. This time around everything worked out very easy. I prepared a version with all your shortcuts and a version with just my shortcuts. I also added Boris' poi settings to allow you to search for a POI around an address. This mod is really great and the extra settings are so worth it that I had to give it a try. All your changes are taking up a lot of my time but i am getting the hang of this and it is becoming easier. I really have to thank Cmh928 and illdietrying for teaching me so much. And all your mods have been great so far, keep up the good work. Thanks Cmh928!
Posted Apr 12, 2009 · 02:17 UTC#158
GNar74,
just finishing up some cleanup to it and i will offer 2 versions, one with my original shortcuts and one with all of cmh928's shortcuts.
Posted Apr 12, 2009 · 03:03 UTC#159
Glad to hear it, GN. Let me know once you've test-driven it and I'll post them to the FTP for ya. Make a new readme and pix if needed, too.
I just uploaded the newest data.zips to the FTP. I will post AIO's updated with them as soon as I take the new samantha for a long testdrive.
Posted Apr 12, 2009 · 03:17 UTC#160
Thanks for the Mod. Looks great! I am having one issue, however. I did the step by step and everything worked great the first time, however I was going through the new options and choose a night theme for the map that started with a z or x. After that it popped up an error that said could not be found, has to close. I could no longer access the navigation. I tried rebooting but now it just loops and never loads completely, just gets to the loading screen.
I have tried putting in the data, sys, and image files again but I have not been able to get it back up again. I did make a full backup, but would like to get the mod fixed.
I did a quick search but can't find the night themes. I am assuming that I just have to find the correct theme then the mod will boot up properly.
Posted Apr 12, 2009 · 03:22 UTC#161
I spoke too soon. one problem. I am trying to hide the speed limit when i am in route so iadded what you told me to add a while ago when i had the same problem and it worked then. this time when i added visiblemodel="navigation.has_route&navigation.current_speed_limit.valid" it is working backwards and shows the speed limit when i am in route and hides it when i am not in route. Should i be writing visiblemodel="navigation.has_no_route&navigation.current_speed_limit.valid" Thanks
;<> Start
;<> End
Posted Apr 12, 2009 · 03:45 UTC#162
well i tried visiblemodel="navigation.has_no_route&navigation.current_speed_limit.valid"
and that didn't work. I hope you have an answer for this one cmh928, because i have no idea why it is doing that. Thank you
Posted Apr 12, 2009 · 04:17 UTC#163
I've looked at various values for the clock and see the differences. Forgive me if these are dumb questions, I am really trying to figure out how this thing works. The question I have come up with is will copying someone else's navigatemap_800_480.ui into the CMH all in one work? I think I've figured out how to insert it with 7zip. Does changing that .ui file change everything or just the appearance of the map screen? I really like the lower beeps and Samantha voice and everything else. And it is just so simple to install.
One problem I just had happen with the all in one, untouched, is that my route info box disappered. It does not show up when any route is active. I am going to reload the all in one and see if that fixes it.
Posted Apr 12, 2009 · 05:33 UTC#164
Having a few issues...the parking brake bypass didn't work. In addition, there were a few other things like the compass changing the map from day to night. I also don't think the beeping noise was changed. Any suggestions? We download the all in one file. I did notice that some files were still zipped within the folders. Could this be the problem? We have the 900BT, if that makes any difference. The parking brake bypass is what we are most interested in.
Posted Apr 12, 2009 · 05:38 UTC#165
Thanks for pointing out the info.ini file. I changed a couple of mine.
recalulate="Where are you going?"
ask_recalulate="Off route! Recalculate?"
offroute="Doh!"
traffic_jam="Look out. Bad drivers ahead."
overspeed="Slow down Johnny"
Posted Apr 12, 2009 · 05:47 UTC#166
Fixed my issue. I had to reload and update again, this time with the extra schemes :D
Posted Apr 12, 2009 · 07:13 UTC#167
The AIO doesn't have the newest data.zip. I stated that 3 posts ago. Compass brings up RoadList on the last version. Beeps are softer not removed. Even with the software bypass, you still need to ground the P Brake wire. Do some more reading on here. Files stay zipped when installed. DO NOT UNZIP FURTHER THAN JUST SHOWING 2 FOLDERS.
Posted Apr 12, 2009 · 07:14 UTC#168
Just installed this today, I must say, it's very well done, I wish there were a quick way to preview all the color schemes for the maps.
The beeps are still as annoying as ever, especially with steering wheel remote doing the volume changing.
It was easy enough to re-mute them, but really, they need to be *MUCH* quieter or removed completely.
Thanks a ton for the effort!
Posted Apr 12, 2009 · 07:26 UTC#169
The opposite of "navigation.has_route" is "!navigation.has_route". Notice the exclamation point.
visiblemodel="!navigation.has_route&navigation.current_speed_limit.valid" should do it.
Posted Apr 12, 2009 · 07:29 UTC#170
How high do you have your amp gains set? I have mine set so that 60 on the volume out of 64 is the onset of clipping. This reduces background noise as well as making the Loudness contour behave as it should. If 30-40 on your volume is already loud, that would be why your beeps are still loud.
Posted Apr 12, 2009 · 07:36 UTC#171
You can't just drop a .ui from one data.zip to another with few exceptions. The scripts called by one file need to exist in the other. You can use a file as a guide to modify the one you have, but not just replace it. Screw it up and you'll get a reboot loop and have to try again.
The Route Info box is meant to disappear if you set FullScreenCockpit to on. Check that in NaviSettings.
Posted Apr 12, 2009 · 14:52 UTC#172
Thanks i missed that, but you are why I don't panic. Thanks for the suggestion i will try it out. I was loosing it and couldn't figure it out. I just looked at my old file and just noticed the !. DUH. Anyway it is a good thing you started your own thread and that you are helping people out. The newbies should really thank you for making their lives easier.
Posted Apr 12, 2009 · 14:56 UTC#173
the route info box does disappear in cockpit mode check your settings. And as you can see it isn't as easy as just dropping in a ui file. I have been posting questions everytime cmh928 comes out with a mod so i can change it to suit my navigate800_480.ui file. The best thing to do is look through numerous ui files and see what they do and try a copy and paste. That is how i do it. It is trial and error and many rebooting cycles. You can also adjust the x,y values to suit, but you should still follow others files. Be careful because whatever changes you make to x,y, you don't want to have 2 buttons in the same place on the screen as well. good luck.
Posted Apr 12, 2009 · 15:01 UTC#174
I silenced them. The beeps were too annoying. What i did was replace the wav file with a silent wav file and just named it the same as the old wav file. this made the beeps silent and actually made the response time better. Anyway just read the first post in this link viewtopic.php?f=34&t=17249&hilit=+silence.wav
Posted Apr 12, 2009 · 16:14 UTC#175
I just finished and everything works properly. I will post the link when it is up. Thanks a lot cmh928
Page 7 of 29
