Posted May 11, 2006 · 20:30 UTC#1
Can anyone tell me exactly what steps are required to bypass the lockouts on an AVIC D2?
Anonymous said:Can anyone tell me exactly what steps are required to bypass the lockouts on an AVIC D2?
havenet said:Will this bypass allow for Navigation input or DVD playback or both? I am more interested in allowing for Nav input but I am hearing that this lockout is also dictated by the GPS gyro which is an additional lockout and is unaffected by the ebrake bypass....is this true.. If not "whew!" if so, is there a way to bypass it as well??
havenet said:Would you please describe the installation of the 528t pulse timer (connections, etc)? That sounds like exactly what I need!
Since you suggest it requires a pulse timer, I assume that a straight grounding of the parking brake will not work? Have you confirmed that it will only work it the ground occurs AFTER boot of the system?
THANKS!!!!!!
THANKS!!!!!!
havenet said:Thanks for the information guys! At the moment, I'm still wired as per the installer at BestBuy who refused to ground it for me. I am getting a message BEFORE the default safety message. It states that my parking brake has been miswired (or something to that effect) and that I need to check it out. It looks pretty much identical to the safety warning screen in font and color. I hit OK then I get the safety message and have to hit ok again. Any idea what's needed here??
Question#2: I read in the manula that the coloration of the nav screen should go with a black background at night once the headlights come on, but mine doesn't. I have automatic lights but tried turning them on manually to see if that had an effect, but nothing. THe manual states that if this doesn't occur then an orange wire is miswired...what do I need to do? BestBuy is an hour away. (BTW I've checked the settings and the nav is set to "Nightitme" so it should change over along with the headlights)
Anonymous said:I am getting my Avic d2 and nav traffic put in monday. When I asked about doing the bypass, they told me I would have to have a PAC TR7 module to bypass it, and it module is $30 plus $100 to install. ??? Sounds crazy to me after reading this thread and since all the web info says the module is only for Alpine bypassing...?
Anonymous said:Insert just, any wire into an empty hole in the harness and tie that to ground?
Just want to be crystal clear when I go in - I suck at car stereo installs.
Thanks guys, this information is awesome.
Anonymous said:What about Speedwire then, I should do nothing about it?
