havenet said:
Would you please describe the installation of the 528t pulse timer (connections, etc)? That sounds like exactly what I need!
Since you suggest it requires a pulse timer, I assume that a straight grounding of the parking brake will not work? Have you confirmed that it will only work it the ground occurs AFTER boot of the system?
THANKS!!!!!!
Yes, I initially just grounded the parking brake wire and occasionally I'd either get the error message or the video/navi would not show up. So here's how to wire up the 528t.
Red goes to Constant 12v.
Black goes to ground
the blue loop of wire cut and isolate the ends.
Black/white goes to the accessory wire
Yellow goes to ground
orange goes to the parking brake wire of the avic.
What will happen is when you go to start the car, the accessory wire will get power for a second and then lose power when the start goes to crank. That will cause the 528t to activate for the amount of time that the dial is set to. once it deactivates it will reconnect the yellow and orange wires, grounding the parking brake wire and allowing you use the full navi and video display. Mine has been wired like this for almost a year now and not once have I had a problem since I put the 528t in.
