Hi my f700 nav constantly says system start up and when you press the map button it goes to the nav agreement page and freezes it says no map version in service information and constantly reboots every 2 mins how can I fix this?
f700bt sytem start up reboot problem
Mine just started doing this exact same thing two days ago. The 2.0 update has been installed since last October and working without problems so I don't think it is that. Have you had any other responses on this? I tried to go back are reload the 2.0 update but the system refuses to see the files on the SD card. I have no navigation and am wondering if somehow the maps got blown away. They should have been in some sort of FLASH on board and not subject to damage but clearly something bad has happened. Smells like a software issue.
When this first happened the system was coming up with the camera mode message on the screen (which I do not have installed) indicating the image on the screen is reverse. Turned off camera mode and that went away. All my station preset for FM were gone as well. That might be some sort of clue.
I installed this system last year. Updated it in October and haven't given it a second thought until now. Has this design turned out to be one of those problem prone things that the manufacturer is in denial about?
AN update.
I have been fooling with this for a little while this evening. Here are some things I have noticed:
1) The system will not boot the update files on the SD card from power up, or under any other circumstances for that matter. The SD icon is greyed out unless you place the SD car in the machine with a media file (e.g. MP3) on the card. Even then it will not list the media files on the card nor play them.
2) The wait for system to come p message on the banner page never goes away.
3) If you try to go to the Navigation menu from the start page you get the big disclaimer window and you cannot get off that page, regardless of how many times you OK the page.
4) The system resets periodically on its own, reboots and all the same symptoms persist.
5) AM and FM seem to work.
6) When trying to use the iPod connection, the iPod acts as if it has no idea what you just connected to it and give a message to that effect in it display.
This is looking fairly grim.
Anyone out there have any ideas on this one?
reloading it from scratch would probably be the simplest solution.
I had a similar problem, I solved it by not connecting the I-Pod, shutting the system down (KEY OFF) then rebooting it. I have not had the problem since. Let us know what you find...I am interested to find out.
I loaded up the Testmode SW and made a copy of My Flash Disk to the SD card. I took it back to my computer and looked around. One thing I noticed was that the size of the My Flash Disk is only 85.6MB. From some of the other posts I got the impression it should be much larger (>1.5GB). IS this because of the map files? I suspect my maps may be missing. I am going to try a reinstall of the 2.0 update first and see what that does. I'll let you know what I find.
OK that didn't go so well. I loaded up the 2.0 update onto the SD making sure to observe the exact order of folders and files as described on the Pioneer website. I brought it out to the head unit and it refuses to autoboot from it. The unit comes up normally as if it doesn't see the SD card at all.
I took a peek in the head units menu system and it sees the SD card. When I try to open it, it behaves as if it thinks it might have some content on it like MP3s but nothing is displayed.
Any ideas as to why my unit wont boot from the 2.0 update?
For those following along, Pioneer claims the order of the files and folders needs to be:
LPUE080
TTS
CK5000_330_rls.bin
flash_p4_lwp.bin
rtl_115200_8192_p4.bin
I double checked and the SD if formatted FAT32 and there are no other files on the card.
OK.....went through the insanity thing. You know the one where you do the same thing several times and keep getting the same outcome but try again homing for something different......
Reformatted the SD card to FAT 32
Re-downloaded the 2.0 update files direct from Pioneer
Decompressed them and arranged them on the SD as prescribed on the Pioneer site.
Popped it in the head and no good. Head refuses to recognize the SD card. Boots to spach screen and eventually to top menu. Navi is DOA. Can't get past the disclaimer screen.
Radio works. However I noticed it is having issue recalling my previous presets. That's odd. Every so many minutes it reboots with the same results.
Frustrating.
I did not notice that when in test mode the head does not reset itself. Ever. This makes me think that there is something very bad going on in the application software. But since I can't reload the 2.0 update the normal way, I am basically hosed.
Could I go in through Test Mode and drop the 2.0 update files onto the flash disk in the head ? I know it's Windows with all of its many DLL's and other magic fairy dust it likes to sprinkle all over the place.
It also puzzles me that it looks as if my maps are gone. This all just happened mysteriously. It was probaly a coincidence but it occurred right after popping the latest U2 CD into the head. Perhaps Pioneer or Microsoft really don't like Bono.
OK I lied. ....turns out after a period of time (longer than when it is running with the normal application SW) it will eventually reset its way out of the Test Mode (Windows CE desktop). Crap. I tried directly copying the APL folders from the update to the FLASH in the head unit. It didn't seem to make any difference.
Interesting tidbit. There is a very cool piece of software in one of the APL directories that I believe is called GPSView and it gives you a constantly updated display of the satellites the receiver sees, their relative signal strengths and so forth.
I have been thinking that maybe if I could get a copy of somone's working and updated 2.0 FLASH drive image from their head unit, I could simply replace my FLASH disk image in my head unit with it and all should be right with the world.
What do you guys think? I could either send a memory stick or maybe open up access to some disk space I pay for on the web. From what I have read it sounds like this image is on the order of 1.6GB or so. I am about out of ideas.
im monitoring this thread as your situation is similar to what i'm experiencing. i DO have all the map files i believe (1.6gb on my SD).
my system reboots every so often. i realize it's not a hardware issue because unlike turning off the car and turning it back on, the music (from radio or cd or ipod) should play automatically. my reboots are as if i hit the reset button, just stays in the opening screen.
When your unit comes up on the first page (the one with the nav, contacts and music icons) does it continue to display the "System is booting. Please Wait" (or whatever the exact words are) banner? Mine does that until it reboots which might be in as little as 3 minutes or so.
Driving to work this morning (about a 45 minute drive) it was rebooting over and over again. I times one of them at around 3 minutes, but it kind of looks like it varies.
I really think the HW is not the issue here. This smells like something in the OS got corrupted. In my case I believe it also maybe that I have somehow lost my maps.
Would you (Spaceman Spiff) be interested in having me either send you a memory stick or give you access to a server so I could get a copy of your flash disk contents. I am curious to see if your load works the same on my machine.
Mine always does random reboot while it's working normally for anywhere from 0-60 minutes (or more). Only once it reboots over and over again at the opening page. After 3 tries it booted up normally and continued working.
Driving to work this morning (about a 45 minute drive) it was rebooting over and over again. I times one of them at around 3 minutes, but it kind of looks like it varies.I really think the HW is not the issue here. This smells like something in the OS got corrupted. In my case I believe it also maybe that I have somehow lost my maps.
You want what's in my unit now? Or you want what I have on my SD card? I have a totally virgin copy of the flashdisk files I saved for myself after I did the 2.0 update. I reloaded all those files into my unit a week ago trying to solve this problem. It hasn't solve anything yet.
Tonight I'll have the hardware bypass undone. I'll see if this might solve the problem. Just trial and error here.
OK....I give.... What is the "Hardware bypass" you speak of?
Was your unit running normally right after the 2.0 update? If so I believe what I want is what you said was on your SD card (the post 2.0 backup of the flash disk). This feels like something in the SW has gone south. At some point my iPod works, radio works, CD works it just doesn't work for long and reboot occurs. The SD does not seem to recognize MP3 nor does it recognize the 2.0 update files. It does however recognize the toolkit files and poking around the Won CE files I found a GPS program that looks like the GPS is working.
Hardware bypass is by relocating the mute wire on the harness, you're now able to watch DVD and input GPS routes with the vehicle in motion (pretty much a parking brake bypass).
Yes my system ran fine after the 2.0 update. After weeks of normal operation, the system starts acting weird.
In order for me to reinstall all the flask disk files from my SD to the unit, I had to boot into TESTMODE and copy and paste all files from my SD to the flask disk. That's the only way to overwrite the system files.
OK so here is my present predicament. "Another GSXR 1K" made available the image of a virgin flash drive on a free storage site on the web. I downloaded those files, so far so good.
I booted the toolkit and when I attempted to copy the virgin files to replace my broken files I got a system error message regarding insufficient flash disk space. Well I got the idea of deleting each folder and manually copying the virgin version from my SD back to the flash drive in the AVIC. SO far so good......except I apparently had the ignition off and the power off delay in the truck timed out somewhere in the middle of that process and turned off the AVIC.
When I turned it back on, the toolkit starts to boot, but part way through that process the AVIC turns itself OFF. Not so good. Looks like I bricked it unless someone can come up with a way to recover from this. What a dumbass.....
For your issue I would highly recommend having the above mentioned user allow you access to the files and get a copy of those. Put them somewhere safe (for future reference) and then replace your flash drive files with the virgin ones. NOTE: DON'T ALLOW THE POWER TO THE AVIC TO TURN OFF DURING THAT PROCESS
Anyway here I sit. I will be looking for some additional clues on how I might recover. Otherwise a trip to the Pioneer service center is in the future for my unit.
Tender, you could try making a modified sys.txt file and point all the file references to the SD card instead of the "MY Flash Disk" and you can fully boot and run the HU off the SD card.
OK.....so I went out and started with a virgin copy of the "My Flash Disk" contents. I modified evey instance I could find (e.g SYS.TXT and other .txt files) to point to my SD Card (Storage Card in AVIC parlance). Moved these files to the top director of a freshly formatted SD card. Plugged the card in the HU and gave it a whirl. Not happening. The unit puts up the splash screen (in my case the blue pool of water with ripples) about maybe 10 -15 seconds later the unit turns off.
If I put the Testmode stuff at the top level of the directory, the sequence is similar accept that after the splash screen comes up, it flashes that screen once, pauses and then puts up the load status bar like it is going to load the TestMode software. It starts to load......then turns off. Shit.
After reading around the hack part of the site and looking over the service manual, it is not clear to me that once the My Flash Drive stuff is lost that it is even possible to load from the SD. I noticed in the manual that if the boot doesn't come up after about 20 seconds, they direct the tech to check a few things and then replace the Navigation Unit.
If someone has actually deleted their "My Flash Drive" files and had success with booting from an SD card with a copy of the AVIC files on it, I would really love to hear from you.
Many, Many (continued?) thanks to "Another GSXR 1K" for your help and consideration. I may be coming up on that time when I need to pull the HU and ship it back to Pioneer (it's still under warranty).
By the way "Another GSXR 1K".....I looked over the Leetcode thread. It loks to me like it works off the SD card well enough, but only if the unit has functioning files on My Flash Drive. Not quite my situation. One other thing, do you have the bike that goes with your username? I could have called myself "Another Triumph Sprint ST 955" In that case.
Can't resolve this so its back to Pioneer. I suspect after the stellar performance of this unit (sudden brain (flash disk) damage) that I might be looking real serious at the competitors products in future car audio purchases. Apparently Pioneer is not the juggernaut it once was in this market segment. Oh well.....looking forward to the 3.0 upgrade to see if they have addressed even more of the shortcomings of this unit. I will check in and let you know how this all turns out after I get the unit back from Pioneer.
A special slice of raisin pie to "Another GSXR 1K" for his diligence and helpful advice to try and revive my ailing unit. That is what makes forums like this so great. Thanks to everyone who helped and not so much to those who just looked, like passing by a traffic accident, and said nothing.
No problem Tender, I try to help folks out when I can. There has to be a way to get your HU running, it would/will just take some thought and fiddling around to figure it out. but like you said, yours is under warranty and just shipping it off may be the easier option.
I do have the bike, I currently have a 2006 GSXR 1000, it's a fun, fast toy, got that to replace a stolen 01 1000. I also have an 03 750 that I do trackdays with. Got that one for too good of a deal to pass on. Picked that up a couple years ago on the cheap.
I am also having the same issue! It's so frustrating, and the only thing I havnt tried is replacing all the sytem files. Will someon please send them to me? I'll make an account on that site under the email address "[email protected]"
if anyone has had any luck with replacing the system files when it has the problem where it will start to boot and then turn off please help a brother out, mine is doing the same thing now
Since this has just been a new problem in the last couple months, is it possible that it could be a virus via BT or a gps problem?
btw i have a 700bt screen reads start up in progress please wait, then resets within 3 mins
OK I got the system back to just restarting over and over. I got it to satop turning off after the splash screen by adding the APL folder to the Mitacap folder in the test files disk. then it copied it to the flash disk, atleast for me that was the file I deleted prior to having the shutoff problem. Now its back to having the system startup msg and then rebooting after 5 minutes. I have all the files from another gsxr 1k but I'm not sure where to put them as when I look at my sytem they are not the same. If anyone has some incite to this I would appreciate it and hopefully the test mode copy trick will help someone else.
UPDATE: I just spoke to pioneer canada and the first thing that the tech asked me was if i had bypasses the ebrake wire. he then gave me a number to there local repair center.
