For some reason the files in the Igo folder are corrupt where all the file names are garbage, the system wont let me delete them. I can copy new ones into the folder but doesnt help yet, anyone have any ideas?
f700bt sytem start up reboot problem
You'll probably have to format the flash drive and load it from scratch. THere is a utility in the control panel that does this.
OK, today I got the stereo back into operation. I had corrupt files in the igo folder and wouldnt let me delete or rename or move the files or anything. Anyway I got monkeying around in the control panel and I found an icon that says storage manager, it let me dismount the "My FlasH Disc" and then format it and viola i could now copy all the original files on to it Provided to me by another gsxr 1k, Thank you so very much and his files are already the 2.0 version right after that I restarted it and it worked perfect so far.
Hey Guys,
Been lurking since my install in march. I did the hardware bypass and customized the splash with info/files found here. Its a great community.
Anyway about a week ago, my F700BT's VR stopped working. Yesterday, the touch screen began to be very slow or not responsive. As the day went on, the unit started randomly rebooting. I did the 2.006 update and it went well, but the problems persist.
Again, when not rebooting or hanging on a touchscreen input, most of the functionality works(am/fm/navsat reception).
Ive tried soft and hard reboots.
I've read enough over the last 4 months to understand how to reinstall the software. I do not have the files(aside from the 2.006 update I did yesterday).
I am dreading sending it back to pioneer on monday. Last ditch suggestions?
THANK YOU!
-cat
Can anyone let me know what to do to fix this? Mine is doing the same thing, it will reboot every 3 min, and it says System startup in progress. Where can i get the files to install and how do i install them?
I had the same issue. Luckily I had purchased the upgrade to 3.0 prior to the issue starting. I stuck in the sd card turned on the car and the unit automatically booted from the sd card and loaded the os from there. If you have the 3.0 upgrade on sd card I would recommend doing this. It saved my unit.
