New Nav mod (Updated Mar 23, 2010) (Now 3.0 version)
By BorisM · May 24, 2009in Completed Mods/Themes💬 684 posts👁️ 133,910 views
Page 4 of 28
Posted May 28, 2009 · 13:40 UTC#76
Can you get the word "Favourites" changed to "Favorites" ?
Thanx,
Bud
Heh, it is spelled correctly as it is :)
This really should be handled by the LANG file anyway... Need to check if it has Favourites in it
Posted May 28, 2009 · 13:45 UTC#77
Updated the download link.
Posted May 28, 2009 · 20:50 UTC#78
Hi Stanislavovich. Great job on this skin! I wanted to ask you if it's possible for you to add a button to turn the smart zoom on/off like we originally had? I actually like to zoom in really close while in 3d mode and every time i go into another screen and then revert back to the map the zoom defaults back to the settings of the sliders. I actually zoom in alot closer than the closest # on the slider so it always zooms far away again.. I actually tried to put a default low zoom # in the sys. txt file but it seems those sliders override that cause i cant get the close zoom i want to default. Thanks
Posted May 28, 2009 · 21:31 UTC#79
You can add this to the sys.txt file and it will do it every time the unit starts up.
[smartzoom]
enabled="0"
Posted May 28, 2009 · 22:27 UTC#80
[smartzoom]
enabled="0"
So if the zoom # is 40 then it should look like this?
[smartzoom]
enabled=0
minzoom=40
Posted May 29, 2009 · 00:54 UTC#81
Thanks for the updated file Boris and Stanislavovich.'
I did a flyover on a route and let it run all the way through. When I hit the map button the screen went to overhead view. I couldn't get it to tilt back to where you can see the horizon. Once I re-booted it went back to normal. Ran another flyover and the same thing happened.
Can someone please try it and see if this problem is specific to my unit or not.
Thanks.
Posted May 29, 2009 · 01:44 UTC#82
Thanks.
I suppose you tried clicking on the airplane icon (this mod uses compass/airplane to switch between view modes)... Also, browsemap mode is designed to be viewed in 2Ð’ (although I think you still can switch)...
Posted May 29, 2009 · 01:57 UTC#83
Thanks.
I was in 3d mode, the one with the compass. From what I gather, the airplane is 2d mode and displays a overhead view.
Posted May 29, 2009 · 02:27 UTC#84
[smartzoom]
enabled="0"
[smartzoom]
enabled=0
minzoom=40
yep mine is actually enabled="0"
Posted May 29, 2009 · 03:15 UTC#85
A couple of things I noticed on the new mod
1. In some of the menus I press the return button on the top right and I get a swish sound but the menu never goes back one I have to hit menu button to get out of them
2. Street names. I have them turned on, in 2D mode they show up no problem zoomed in close or out a few clicks but in 3D mode I have to be zoomed in real close to get them all to show up, backing out one zoom setting removes 1/2 of them and zoom out one more click and they are all gone. Before the mod was put in place in the avic software I had them pretty much all the time in 3D mode no matter the zoom unless I'm totally way out there.
Posted May 29, 2009 · 06:12 UTC#86
have you tried to switch on "test mode" in Regional settings screen? if so please do not do that. that mode only for debug. it could substitute some functions.
Regarding the streets name. the customizing you mean allows to switch on/off the streets name during the driving, so in static mode it has no effect on display. But pay attention on that there are some things effect on that: font size, tilt level and zoom level.
Meanwhile I'll be anavailable for a week, so I ask BorisM to comment my mod or please wait a little.
See later.
Posted May 29, 2009 · 11:35 UTC#87
See later.
I don't think I have put in test mode I read earlier that is not good, but I'll double check.
The font size you control in your data.zip its not controlled in the program at least from what I found, the tilt level is the same as it was in the stock version and zoom level is what appears to be controlling it. I'll try to take some comparison pictures
Thanks, and have a great time off!
-- Update 7am- on the way to work the names showed up fine in town, better than they did in my area. I'll just let this ride for now. I think the name thing is the least of what I want to worry about. Thanks again for the great mod Stanislavovich, I will check the right corner menu thing and test mode since I haven't yet.
Posted May 29, 2009 · 17:52 UTC#88
Great Freaking Job! I love it!!
One question is there a way to change the MPH on the Navigation screen  (Right above ETA) to Time To Arrival? I like to know how many minutes to go versus having to do the math in my head!
Posted May 29, 2009 · 18:27 UTC#89
I'll double-check later today. I did not have this issue when I ran simulations, so I'll take another look.
Posted May 30, 2009 · 12:04 UTC#90
Is there a way to get the map to tilt up or down like the original Avic software? Darn round a bout caused the map to go haywire and its tilted at an angle that now I can't change and its really ticking me off.. Thanks
Posted May 30, 2009 · 19:35 UTC#91
I asked him to add map tilt buttons back, too... We'll see when he comes back from vacation...
Posted May 30, 2009 · 19:39 UTC#92
Whats the easiest way to mute the sound?
Posted May 30, 2009 · 22:09 UTC#93
Great Mod! I like this one the best out of the others I have loaded. Mainly as I am a control freak and this skin lets me to just that, Micro Manage.
So far my only request/want. would be a GPS Status Button on screen for both while you nav and not in nav. Also for the main screen while not in Nav is it possible to not have the whole back ground graphic on the left that shows the nav arrows speed etc? As I am a control freak this drives me nuts while I am driving while not navigating (which I do more then nav i guess) would just like more of that screen real estate is all.
I am going to try my hand at adding the GPS today, and most likely remove the graphic I spoke of. But I am sure I shall make my system not boot at all. that is what happens when I go digging where I should not. I done know how to code at all. I just cut and paste from everyone's else's great mod's. Doing so has given me some big problems. But I cant leave anything alone until it is fully broken :roll:
Posted May 30, 2009 · 22:37 UTC#94
Thanks so much...
Posted May 31, 2009 · 02:58 UTC#95
Can Anyone help me out, I need to move the Lane Arrows somewhere higher. I cant see them at all when i am on the high way and in 5th gear. " lane arrows [ ^ ][ ^ ][ ^ ] "
Thanks.
Posted May 31, 2009 · 05:16 UTC#96
check out this script
my question is how would i add a script that would only run if the selected option is yes, i've tried a couple combinations but can't get it to work, it won't even get pass the startup screen
Posted May 31, 2009 · 07:00 UTC#97
IDT, here is an easier to understand message box:
The Yes or No actions are the commands in the 2 sets of single quotes. A 'run sc_xxx" should work fine although normally you will see this script called from another script and this will just be used to set a variable that is used in a following "runif vxxx 1" command.
Posted Jun 01, 2009 · 05:12 UTC#98
I ran a fly-over from Chicago to Vancouver and did not see this happening...
I'll ask the author when he gets back...
Posted Jun 01, 2009 · 05:25 UTC#99
tried it and still did not work
Posted Jun 01, 2009 · 08:04 UTC#100
a dumb question,where is the "delete current route" buttom?can someone point that out for me? :shock:
Page 4 of 28
