":3cfw19vh]pioneer will, and has already, blamed mine and all the other boot problems on the parking brake bypass. i'm not buying that because i know that's bullshit and there has to be something happening and i'm the type of person to try and figure it out.
i can accept a hardware malfunction but i would like to eliminate all options before having the massive hole in my dash for probably 2 weeks and paying the bastards to fix it.
can ANYONE think of ANYTHING else to try? i will try anything at all before i send this off. i'm actually about to pull the unit and check the fuses in the back because i haven't done that yet and try to disconnect the battery terminal again.
First off, why would you tell Pioneer that you did the bypass? That has nothing to do with anything.
Make sure your ground is COMPLETELY grounded. Make sure the positive connection is hooked up.
If it doesn't at least power up after both of those, it is something wrong with the device itself, in which case, you contact Pioneer, say your device stopped working, and you send in the DEVICE, not the harness, so how would they even know you did the bypass??
i didn't TELL them i did the bypass. if you call pioneer with this sort of problem, they are blaming it on a bypass, PERIOD. i've even read this on here quite a few times.
now about the problem...
the unit is powering on. but like i stated it is rebooting just when the screen the reads "please wait, system startup in progress" (or something) should come up. right after "Pioneer".
so back to my original question cause somehow you missed the point. I"m not trying to send it to pioneer, disregard what they said, i'm wondering if i have exhausted all my options to fix it on my own. if i have i will unmount, unplug, and ship it off. but i'm out of warranty and it will cost a minimum of $200 to get it fixed plus shipping charges. so far i have....
soft restart
hard restart
reinstall 2.0 update
tried to boot with test files (would not go into test mode)
i don't want to give up on it. i'm still awaiting suggestions and i'm pretty sure my ground and power lead are fine since it is coming on and starting to boot but is dropping out.
