Applying CE hacks and mods
By Amber00Dak · Jul 06, 2009in Hacks/Mods💬 26 posts👁️ 3,315 views
Page 1 of 2
Posted Jul 06, 2009 · 01:56 UTC#1
Been reading a ton of stuff here lately and im well aware that almost all mods are software related.
So far I have downloaded Testmode and MiTACAP and with the SD card loaded into the unit I was able to access the systems "Windows" root. But I am a little lost as far as what order or additional things I need to download are. I havent found any good step-by-step directions, just alot of vague bits and pieces.
I want to do a parking break bypass on our F500BT and im pretty sure after reading quite a bit that the hardware mod alone wont work. So can someone help me out here and give me the break down on what the order is and what is necessary to get these certain DATA.zip files altered/edited so I can use these hacks. Thanks
Posted Jul 06, 2009 · 02:12 UTC#2
data.zip is inside myflashdisk/apl2/igo folder,
you have to extract the data.zip to be able to do your hacks, it's best to use 7zip
there are some modified data.zip in the forums and i think it would be the easiest way to do the hack,
BE SURE TO BACKUP YOUR FILES BEFORE DOING ANY CHANGES
let me know if you need any help
Posted Jul 06, 2009 · 02:33 UTC#3
Thanks so much for trying to help. Ill try to keep my questions simple...
this is located within the units files and accessed when in Testmode? or is this a file I need to find within the MiTACAP and Testmode files I downloaded?
extract them from the unit or I need to download something else? where can I find 7zip?
I found the thread that mentions changing the value to bypass the parking brake restriction, but as far as modified data.zip files on the forums, what do you mean?
how do I backup files?
thanks again
Posted Jul 06, 2009 · 04:33 UTC#4
this is located within the units files and can only be accessed through testmode
once you've copied the file from the unit to your sd you have to copy it to your computer and extract it there
thanks again
that would be the software bypass,
for the modified data.zip chack out this thread http://avic411.com/forum/viewtopic.php?f=34&t=22695&start=675#p170252
backing up your files means copying files from your unit to your sd card
Posted Jul 06, 2009 · 16:46 UTC#5
Hey I'm new to this as well, right now all i want to do is just the bypass. What i don't understand is how to get to this DATA.ZIP in order to change the values.
What i don't get is WHERE i change the values.
do i do it on the deck in test mode or do i change the file on my computer than copy it over using a SD card.
secondly
I tried using the TEST MODE on my deck but it didn't work.
Loaded the files on a freshly formatted SD card and it doesn't do anything at all
I have the F700.
Thanks.
Posted Jul 06, 2009 · 16:53 UTC#6
secondly
I have the F700.
Thanks.
you have to change it on your pc
Posted Jul 06, 2009 · 16:56 UTC#7
secondly
I have the F700.
Thanks.
Okay i have the data zip. and I have changed the value how do I get it on my deck?
Thanks.
Posted Jul 06, 2009 · 17:09 UTC#8
hey I'm new to this as well, right now all i want to do is just the bypass. What i don't understand is how to get to this DATA.ZIP in order to change the values.
secondly
I have the F700.
Thanks.
Thanks.
reverse the process, go into testmode and copy that to igo folder, MAKE SURE YOU HAVE A BACKUP
Posted Jul 06, 2009 · 17:21 UTC#9
Yup I do have a back up. But heres the thing...
I took the file from a fresh copy that i downloaded and modded that one. i tried looking in TEST MODE how to replace the data file but i have no clue I spent a good 10 min's in my car looking around in test mode but i didn't wanna go messing around to much without knowing.
so once in test mode what do I do?
Thanks.
Posted Jul 06, 2009 · 17:24 UTC#10
Thanks.
go to myflashdisk/apl2/igo, that's where the data.zip should go
Posted Jul 06, 2009 · 17:29 UTC#11
I know where it goes. my problem is I don't know how to move it.
Right now I have the modified DATA.ZIP on my SD card. ( I assume i need it there to copy over in test mode )
and I know where its suppose to go but I don't know how to get it there in test mode.
So once in test mode is there a program I should be opening up? or should I just be trying to navigate to the iGO folder and some how copy it over to there?
(sorry for annoying you with this questions)
Thanks.
Posted Jul 06, 2009 · 17:32 UTC#12
Thanks.
use the copy /paste function in edit tab
Posted Jul 06, 2009 · 17:44 UTC#13
ah my fingers are much to fat for that :lol:
i just used the program called "total control" ( at least thats what I think it was called )
but it ended up not working. I tried to bypass the E-break by changing the values from 16 to 128
as explained in this guide viewtopic.php?t=17715
but it didn't seem to work. I'm going to review everything and try again but in the mean time do you know another way to do the bypass with software?
Posted Jul 06, 2009 · 17:49 UTC#14
as explained in this guide http://www.avic411.com/forum/viewtopic.php?t=17715
use a stylus,
what i would suggest is to tyr using a modded zip file,
Posted Jul 06, 2009 · 17:57 UTC#15
I will try that just to be sure.
I want to try another mod in there that so i can test if its because the e-break wire isn't grounded, or I'm just missing something.
If you don't mind could you link me to a Data.zip with some minor mods that i could test out? or just another value I can change to test things out.
Thanks.
Posted Jul 06, 2009 · 18:09 UTC#16
Thanks.
i would suggest just doing the hardware bypass,
but if you really like the software bypass, change the value to 256
Posted Jul 06, 2009 · 18:30 UTC#17
and just to confirm it copy's to the folder called "flashmemory"?
Posted Jul 06, 2009 · 18:41 UTC#18
Posted Jul 06, 2009 · 18:47 UTC#19
yup okay so its not me than. it wont work. :S
I dunno why it isn't but I think it might be the grounding on the E break needs to be done.
also is there a guide to doing it the "hardware way"?
Posted Jul 06, 2009 · 18:58 UTC#20
search and you'll find
Posted Jul 07, 2009 · 16:31 UTC#21
What did you mean by "hardware mod alone won't work"? Hardware mod is better in most cases if not in all cases.
Posted Jul 07, 2009 · 17:32 UTC#22
i mean that just grounding the parking brake wire wont work, once i start driving i get an error message stating the parking brake is improperly connected.
ill.die.trying....thank you for the help. i got the software mod completed and it works great. greatly appreciate the help
now i just need to figure out how the unit is supposed to power on and off and be consistent about it.
Posted Aug 24, 2009 · 02:12 UTC#23
Hey guys, I have searched but couldn't find the answer still.. Regarding the software bypass, what exactly are you supposed to edit? I know how to transfer the files between testmode and the PC and all of that stuff. However, i have the stock Data.zip archive opened through 7-zip so i havent unzipped yet.. but im wondering which file am i supposed to change the values in? thanks in advance!
edit: i would really like to figure this out soon since I just recently purchased the f500bt and had it hardwired.. however, now whenever the gps is on (when the car is on), i cannot edit the gps address, watch videos, or anything even with the parking brake up
Posted Aug 24, 2009 · 02:36 UTC#24
apl2/igo/data/project_config/pioneer.ini
control f parking_brake or simply scroll down, then change value to 256.0. save. copy back to sd. copy and paste from storage to apl2/igo. yes to replace.
Posted Aug 24, 2009 · 02:37 UTC#25
no prob
Page 1 of 2
