parts list:
1. usb to cigarette lighter charger adapter
2. cigarette lighter well plug
3. 2.5" external laptop hard drive (must be powered via a usb y-cable and be formatted with the fat32 file system.)
4. wire and terminals.
notes:
The problem with doing this has always been that the avic's don't supply enough power via the usb to spin up an external hard drive. I over came this problem using a $5 usb charging adapter and a 2.5" external usb hard drive with a y-cable. The head on the usb y-cable with the long wire is for data and the one with the short wire is for drawing power for the drive. The hard drive will have to be unpluged and pluged back in each time you start the car and after the unit has booted. As such, I would mount it some place easy to reach. I mounted mine next to the center console. The hard drive MUST be formatted fat32. Since, the fat32 file system can only recognize up to 127gb i wouldn't waste money on too big of a drive. I bought an 80gb hdd and ended up partitioning it down to 32gb as it was recognized by the avic much faster.
my system:
f700bt pioneer avic
hd radio tuner
80gb 2.5" ext hdd
8gb sd card
4 channel alpine v12 amp
2 6x9" 200 watt rockford fosgate fanatics
2 280 watt pioneer 6.5"
