Complete 3.0 Install Guide
By Retell · Jul 18, 2009in Hacks/Mods💬 968 posts👁️ 380,894 views
Page 20 of 39
Posted Sep 16, 2009 · 21:57 UTC#476
Did the WinCE update with no errors at all on my F700. Reset with the same SD card and boot into testmode BUT it exits windows after about 6 seconds and the screen goes black.
During those few seconds it works fine though.
at this point the unit is useless it goes black after the pioneer bootup, did I brick this thing ?
PLEASE HELP !
Posted Sep 17, 2009 · 02:10 UTC#477
PLEASE HELP !
Ok, I downloaded the files from the link in the install guide (not the torrent)
loaded the CE update - successful
reboot and copy over the "My Flash Disk"
reboot again, the "Pioneer" boot screen comes up for about 10 seconds, then all goes black...
I tried using the 3.1 update from Pioneer, but it does not work either, it just goes black screen again.
Anyone know how to fix this ? :evil:
Posted Sep 18, 2009 · 02:45 UTC#478
PLEASE HELP !
OK, got it working. Made a really DUMB mistake. I copied the "My Flash Disk" folder into the "My Flash Disk" folder. Of course this will NEVER WORK!, you need to copy the contents of the "My Flash Disk" into the one on the F700 !. What threw me off was that, that folder has a different icon instead of a regular folder symbol. Dumb as that sounds, it's what happened.
I also installed the 3.1 update from the Pioneer website, worked without a hitch. Further note, I had all the files on 1 8GB SD card (SDHC), no need for multiple cards. The pioneer update needs to be on it's own card though.
Posted Sep 18, 2009 · 05:29 UTC#479
PLEASE HELP !
How'd you organize the files into 1 SD card? What folders for what files? I have a 8GB SDHC also so I want to put everything in one card to minimize hassle. Thanks.
Posted Sep 18, 2009 · 22:52 UTC#480
What am I doing wrong? Everything seemed to work fine but... My splashscreen loads and my music plays but my actual nav just gets stuck in the system loading screen. So frustrating! I don't know if it makes a difference but all of the files were downloaded to a mac then transferred to my SD card. Don't know if there is any mac conflicts with these files. Any help would be greatly appreciated. How do I get this thing to work? I am going to have to start from scratch?
Posted Sep 19, 2009 · 02:47 UTC#481
no special organization needed. just load them all on and follow the guide. only the factory 3.1 update needs to be on it's own
Posted Sep 19, 2009 · 12:06 UTC#482
Ok, a few questions about this update as I dont have the time to read 33 pages....
1) Is the GUI different or the same, can we have some pictures if it is different?
2} Will my theme mods still work with this as I have the Red Theme installed and I love it
3) What is the difference between this and the purchased version at Pioneer?
4) Where can you get the purchased version as I cannot find it on Pioneers site?
5) does this update have Canadian maps?
Thank you
Posted Sep 19, 2009 · 16:23 UTC#483
What am I doing wrong? Everything seemed to work fine but... My splashscreen loads and my music plays but my actual nav just gets stuck in the "system loading screen" and resets itself every 3 minutes. So frustrating! I don't know if it makes a difference but all of the files were downloaded to a mac then transferred to my SD card. Don't know if there is any mac conflicts with these files. Any help would be greatly appreciated. How do I get this thing to work? I am going to have to start from scratch?
Somebody please help...I have a completely useless unit at this point.
Posted Sep 19, 2009 · 17:41 UTC#484
Send it to Pioneer. They'll fix it for free. Doesn't get any easier than that.
Posted Sep 20, 2009 · 02:06 UTC#485
Reflash back to either the 2.006 firmware which you can get from Pioneers website or try reflashing the 3.0 firmware again from scratch. Either way should solve your problem
Posted Sep 20, 2009 · 05:46 UTC#486
i dont mean to sound stupid, but for the life of me i can't find anything called dump file? where do i find this file?
Thank you
Chris
Posted Sep 20, 2009 · 11:07 UTC#487
Thank you
Chris
It is the file in the torrent that you downloaded
Posted Sep 20, 2009 · 20:38 UTC#488
Hey everyone! First post for me!
I would like to thank the OP for the guide it worked great! I just have a few questions maybe you guys have encountered this after the guide. I have a F90BT btw and here are my questions:
1. After the install and everything is up and running I put in my SD card for all my MP3/WAV songs, all of a sudden at different times of different songs it just starts to skip thru folders and I cant stop it! When it finally decides that it wants to stop scanning thru my folders I change back the song to a different one and it wont do it again. There are some song it doesnt do it at all the entire length of the song and go thru the entire list but then there are times where it will do it right away and jump thru folders. Anyone know what could of caused this? It wouldnt do it on 2.0! I checked all the function options and it is all fine. I did a complete format and re-added all my songs to the SD card and same thing.
2. I know this has been brought up many times, but I cannot see any street names in 3D mode, I messed around with all the settings and zooms and it just keeps going back to the same view with no names. I change it to directional 2D and the names are there but then when I am on a call it goes to 3D with no names! very annoying! Any info would be greatly appreciated!
Posted Sep 21, 2009 · 16:35 UTC#489
I just finished updating my F90bt yesterday. Thanks so much OP. It went well. Now I have 3.0. The whole system is really responsive. Start up time is almost the same with 2.0. Map for 3d is really bad. No street name like others mentioned. I can't stand 2d. Hope there is a fix for street names. My hard wire bypass still works well. Bluetooth seems worse than before. Over all I like the update.
Thanks again.
Posted Sep 21, 2009 · 16:58 UTC#490
Try turning off "smart zoom", or at least reducing the range from 200-500.
Posted Sep 21, 2009 · 19:55 UTC#491
Yeah I set the range to 500 yesterday, found the quick fix on here last night! Thanks for the info, just need to figure out whats going on with my SD card!
Posted Sep 25, 2009 · 04:52 UTC#492
Thank you for creating this thread. I just updated with no issues!
Posted Sep 28, 2009 · 01:46 UTC#493
ok,
i have been trying this for over 2 days with no luck.
the closest i have came to getting my unit to work was it starting up and saying "please wait while unit is starting up"
i tryed a few other things and it got worse after that from restarting every 3 mins to where it is now at getting to the Pioneer screen then shutting down after 30 seconds.
all i want now is to back to my original stock set up.
but from reading other posts on other threads i guess you cant use your old backup with the new windows upgrade??
so how do i downgrade my windows?
anyone help with helping me just going back to stock and enjoying my f700 with its simple setup??
Posted Sep 28, 2009 · 01:49 UTC#494
ok,
Are you using the original update from Pioneer or the hacked one?
Posted Sep 28, 2009 · 02:10 UTC#495
I updated the AVIC-F firmware to 3.01 and Bluetooth stopped working correctly. It started having the same problems as you all, when it worked correctly before. I managed to get it working as before without losing the updated interface of the 3.0 firmware update as follows.
1) I deleted the My Flash Disk/USER/UserData/Setup and My Flash Disk/USER/UserData/iGO/save folders. I don't think this step matters only the next step, but someone else fixed their problems just by doing this.
2) Then I rebooted and replaced the My Flash Disk/APL/parrot.dll and My Flash Disk/APL/parrot.ini files with the same files from the free 2.06 update from the Pioneer website.
Now everything works as it should.
Posted Sep 28, 2009 · 02:15 UTC#496
ok,
i am useing the ones posted on the first post of this thread.
and followed all the instructions on the thread with no positive outcome so that is why i am just wanting to go back to the stock setup
Posted Sep 28, 2009 · 04:04 UTC#497
I had the same problem, but with the legit copy that I paid for. I then put in the one at the beginning of this thread and all is good. Did you make sure that you chose the format option?
Posted Sep 28, 2009 · 04:37 UTC#498
i did it first without the format then tried to do it again with the format...i have read all through this thread and others regarding this mod with little or no help to get it working again.
like i said i am just hoping to get it back to its original setup without the 3.0 update
Posted Sep 28, 2009 · 17:40 UTC#499
IDK what issues you guys are having but this worked 100% the first time, as well as the 3.01 update right off the bat.. so im guessing any x-series update will work for my unit now?
Posted Sep 28, 2009 · 22:43 UTC#500
is there a torrent out for 3.0?
I have the 700bt model.
Page 20 of 39
