I installed 3.0 and also the speed/map mod. All of the map mods are awesome, mute voice, 6 shortcuts, etc. I have the break wire grounded, but when I get up to 10mph DVD locks out status watching while driving is prohibited, as well as improper connection of brake wire detected. I know the mod is in correctly, since the NAV mods work fine. I also validate that the brake speed in the .ini file is set to 256.0 I have also seen multiple other thread with the same problem without a fix? Any ideas? I did not ground the mute wire on the harness. I have a 900bt.
Any ideas gladly accepted. Also have an issue with no name showing up when I receive a call, only the number. I tried adding a 1 in front of the number, but then it displays the 1 in front of the number, still no name? Does anyone know if you can manually add/remove contacts from test mode since there is no way to add/edit contacts, and you have to install all contacts into the AVIC.
jdude
