Baedarlboo,
Thanks for the response. I have tried the options detailed in the guide you indicated. However, no matter what I do it always ends up the same... At the end of the process, when i restart after copying all of the files into the myflashdisk directory, the system restarts, loads the splash screen the nothing. The flash screen sits there like it's waiting for me to do something. I don't know if I'm not waiting long enough for something to happen, or is it going to remain at that screen forever. That is the basis of my post, How long should it take for the unit to be working after the last restart? And part 2, is supposed to be doing something while I'm waiting (copy files, progress bars, etc)?
Bob
You said you ended all but didn't tell whether successfully. I suspect that you might had ended up without enough space to copy all the files and apparently, there is no warning for such thing within WinCE 5. If this is the case, delete some map and poi that you don't used from the SD and make sure that all fit in your "My Flash Disk", and it has only 1.7 GB of space.
This problem has been brought up for many times in the thread. Please search and read.
