Complete 3.0 Install Guide
By Retell · Jul 18, 2009in Hacks/Mods💬 968 posts👁️ 380,894 views
Page 31 of 39
Posted Mar 26, 2010 · 00:27 UTC#751
I've now been able to get the wince update to go to was 64%, but it usually it gets to 28% before going black. My truck battery did go dead, but even with the truck running it fails. Not sure if it my weak car battery or something with the radio system?
Posted Mar 26, 2010 · 01:53 UTC#752
can someone please confirm as to whether or not there is supposed to be something within the "Dumpfiles" folder that we are to copy to the "My Flash Disk"?
Posted Mar 26, 2010 · 04:31 UTC#753
Whats up everyone....I have the f900bt...I've very familiar with these units and I'm looking to offer some services. I'm looking to offer an upgrade to 3.02 on f700, f900, f90, x710, and x910. I did it to mine and it's simple. I have a friend who is in with pioneer and I used to be a technician. I'm looking to get $50 per unit, I have all necessary files and will walk you through step by step. It's not a gimmick, I promise you, I'm just looking to make a little cash while helping you out and saving this money from going to shitty pioneer. Email me back at [email protected] and I'll send you pics of my upgrades so you know I'm for real. Or you could always pay $120 to get the 3.0 version which is a rip off..Trust me..shoot me an email at [email protected] and you will not be disappointed! Thanks guys.
Posted Mar 26, 2010 · 04:32 UTC#754
HighAltitude if you would like me to do it for you...send me an email.
Posted Mar 26, 2010 · 05:42 UTC#755
Its not a matter of doing it. I can do it, I just don't know from the files I have whether or not there is supposed to be something within Dumpfiles folder? Mine from my backup has a file, the one I downloaded does not. Other than that I think I have everything. I understand you're trying to help, but if I had 50 bucks I wouldn't be trying to piece together the correct files on my own, I would order the pioneer cards. Things are a bit unorganized and wide spread throughout the forum. Finding the right stuff is a challenge.
Posted Mar 26, 2010 · 12:57 UTC#756
Id like some help pm me or email me rford426@gmail
Posted Mar 26, 2010 · 18:55 UTC#757
has anyone been able to review the comparison of the files that I did on pg 49? I want to do this but the file difference worry me.
As for the dump files, I took a look at my 2.0 upgrade and there are no files in it, and my unit works. The 2.006 and 2.008 upgrades didnt even seem to have dump files associated with them.
I'm now comparing the 2.008 upgrade to 3.0 and thats where I have issues. the overwrite appears to want to overwrite files that I think need to be there, and add files that werent there to begin with. If someone familiar with these files can review this I would greatly appreciate it.
Thanks,
Don
Posted Mar 26, 2010 · 19:14 UTC#758
Make sure you get good files that aren't corrupt...idk what was up with mine but sticks got me all squared away
Posted Mar 26, 2010 · 19:21 UTC#759
i dl'ed the 2 rar files from megaupload, extracted the 1st one which automatically extraced the 2nd. Are these correct files or corrupt files?
Posted Mar 26, 2010 · 19:38 UTC#760
couchpotato...I'll run you through it for $50 via paypal...I used to be a technician and have all the necessary files. I just helped rford out.
Posted Mar 26, 2010 · 19:40 UTC#761
i saw your post and sent you an email with my concerns about the 3.0 update. email me back so we can take this offline.
Posted Mar 26, 2010 · 20:16 UTC#762
wOOHOO, got this done! The key in my case was holding the 4 buttons and hearing the "pop" noise. Once I heard that, and got to the wince upgrade section it went to 100% and said all was good and to restart. I guess I wasn't holding all 4 long enough for the pop or something. I have now also upgraded the maps, poi,dem, building etc. to the 2009.6 maps. My firmware says, map v.200.300, and v.300.300 (or close that)
BTW, despite getting NO response as to whether or not there should be files in the "Dumpfiles" folder I copied the files I had from my backup to there. Not sure if it should be empty or not.
The only things I've noticed now is when I go to search an address it defaults to a completely different state about 800 miles from me, and I can't seem to find out how to delete the present "home location"
Posted Mar 26, 2010 · 20:24 UTC#763
50 bucks, huh? Or everyone can follow simple instructions and READ all of the posts listed on this thread and do it yourself and SAVE your money and donate it to the fine folks that have countless time and effort making the mods.
Posted Mar 27, 2010 · 09:24 UTC#764
That folder is supposed to be empty.
Posted Mar 27, 2010 · 09:26 UTC#765
That would be correct. Its a multipart RAR file so by extracting the first one, it knows to automatically move on to the next file.
Posted Mar 27, 2010 · 09:28 UTC#766
Exactly...how much do you wanna bet that he's using the files I provided :evil:
Maybe I should start charging for each download =P
Posted Mar 28, 2010 · 03:21 UTC#767
Mine loads everything 100% reads it, writes it, CE upgrade complete, restart,Splash Screen, Black Screen!!!
Now I cant even get in to test mode before it was going into test mode then i would do the reset and eject for 5 seconds then it would restart up splash screen then black.... Idk what to do
To fix the above, power on with reset held. Then reflash using the official 2.06 update and it'll be fine.
I get the same thing on my F500BT. I'm using the 3.020200 EW dump that someone posted.
I've tried the following:
1. Flash wince, result: black screen. Does not power up.
2. Flash wince from 2.06 update, it gets stuck on blue wave. Analysis shows that it's missing loading.bmp from the 800_480 directory. Replacement with data.zip with 800_480 does not work.
3. 2.06 wince, APL2 from 2.06 update causes crashes and does not boot.
4. 2.06 wince, Igo8.3.2 from other sources functions as a GPS only. The coreplayer, BT and other functions do not work since it looks like those programs and services are not loaded. This means that the Igo directory is loaded on boot and the ezrider.exe has hooks to the other services.
I find it quite odd that the error logs show that the Pioneer upgrades don't have the 800_480 icons in the data.zip that's included.
I'm going to experiment some more... if all else fails, I'll just run Igo Amigo 8.4.3.115042 with the Dimka skin. It'd be nice to have BT and voice...
Posted Mar 29, 2010 · 16:17 UTC#768
Ok befor i get gung-ho and make my self a paper weight.
I have DL'ed ITguys rar's In step 9 it says to copy flash dump to the card. Where is that file. I am showing DumpFiles and Extradumpfiles.
Or am i just supposed to Copy the DL'ed My Flash Disk and overwrite "MY" my Flash disk on my avic
thanks for the clarification. I scanned through the posts and thought i remembered reading something about step 9 somewhere but i will be damn if i can find it again
Posted Mar 30, 2010 · 05:25 UTC#769
Copy everything that was extracted to the SD Card.
Then when you put it in the AVIC, you copy the contents of the My Flash Disk Folder to the My Flash Disk Drive.
Posted Mar 31, 2010 · 03:12 UTC#770
Yeah the wording of "copy flash dump to My Flash Disk" is a bit unclear. I had the same issue. I wasn't sure what "flash dump" was supposed to mean. Basically like MyIT said, extract the contents from the DL'ed zip file to the SD, then copy them onto the AVIC into the corresponding locations.
Posted Apr 06, 2010 · 20:08 UTC#771
just did the 3.02 from the X910 on my F90BT and it worked perfectly. Going to do the latest bluetooth stack next
Posted Apr 12, 2010 · 14:45 UTC#772
Will I be able to watch movies from my ipod for the Avicf700bt series when I finish updating all these mods??
Posted Apr 14, 2010 · 07:34 UTC#773
Step 9: Delete all of the files off the SD card and put the testmode folder, DATA file, and the flash dump from torrent on.
I do not have a DATA.zip in the files I just downloaded - is this the data FOLDER not a zip file?
Posted Apr 15, 2010 · 16:33 UTC#774
OK, So I re d/l'ed everything on my PC instead of my Mac. Used Winrar and now it doesn't reboot by itself!! In fact everything is perfect!THANK YOU ALL FOR YOUR HELP! I couldn't have done any of it without all this information I received! 1 question I do have, what iPods are compatable with this 3.0? Will I be able to watch movies from my iPod on it, if not, are there any mods/hacks that will allow such usage? THANK AGAIN!!! you guys rock!!!!!!!!!!!!!!!!
Posted Apr 18, 2010 · 22:06 UTC#775
Hi Guys i tried to download the 3.0 update from itchbot and it states the the site no longer works is there another place i can download the 3,0 update from?
Thanks.
Page 31 of 39
