Complete 3.0 Install Guide
By Retell · Jul 18, 2009in Hacks/Mods💬 968 posts👁️ 380,894 views
Page 36 of 39
Posted May 26, 2011 · 21:39 UTC#876
There are 861 prior posts in this thread, many of which are now outdated. I have an AVIC-F900BT that did the usual boot screen to black brick and was determined to fix it. A HUGE thanks to everyone on this forum for the collection of info to get my unit up and running with an even better interface (2.0 to 3.0 upgrade in the process).
I wanted to update the instruction process due to post 1 being a little inaccurate with the new links and software but give most credit to Retell as OP and MyITGuy for providing the new software links and info for slight modifications for the instructions.
These instructions should solve most problems and get you up and running with 3.0. Some people have started adding info for a 3.01 update (Post 717) and 3.02 update but I have not yet gotten that far. Here we go!
Step 1: Download 2 rar files, 3.0 Update, part 1 and part 2*
http://www.megaupload.com/?d=K0WJSCUR
http://www.megaupload.com/?d=XDPTH67G
(*Thanks MyITGuy for the links, post #600)
Step 2: Unrar these files
Mac OS X - UnRarX - http://www.unrarx.com/ (This is what I used)
Windows - WinRar - http://www.win-rar.com/downloadnow.html
a. You will select 3.0 Update, part 1 to open
b. Unrar it to the desired location
c. You are done! While unrarring (if that's a word) part 1, it will also unrar all files in part 2 without needing to do anything additional.
d. You should now have a destination file with 4 items
1. My Flash Disk - Folder
2. Testmode - Folder
3. WINCEIMG.Bin - File
4. WINCEIMG.CKS - File
(Note: I came across a few posts where people said they had issues with the included Testmode and downloaded a fresh file to replace the included one. To save myself time, I went ahead and did this upfront without actually ever testing the one included. If you choose to do this as well, you can get another functional Testmodev2.3 here - http://www.filestube.com/7cdcc15b9238c0f503ea/go.html. Again, I never tested the included one and may be perfectly fine. If you download a new copy, just replace the old Testmode folder in your destination directory with the new one once you unrar it.)
Step 3: Make sure you have an SD card that is 2GB or larger, and format it using MS-DOS (Fat) formatting. Transfer the 4 items from your destination folder to the SD Card. (My Flash Disk, Testmode, WINCEIMG.BIN, WINCEIMG.CKS)
Step 4: Turn the unit on. When the Pioneer logo comes up, press and hold the menu, map, eject and the reset button at the same time. When your screen goes completely blank, let go of the reset button but continue to hold menu, map, and eject buttons.* This will bring you to a blue screen wanting you to press the reset button again. Ignore this message and enter the service combination. Press the volume knob in this sequence and you will see * signs for each push at the botton: Up, Up, Down, Menu, Left, Right.
(*Thanks Chuck88, post 813)
Step 5: Insert your loaded SD
Step 6: Select Update CE
Step 7: Select Update SD Format
Step 8: Wait till it says restart in the bottom center.
Step 9: Press the reset button.
Step 10: Once testmode boots (You will have a WindowsCE screen):
a. Select "Start"
b. Select "Windows Explorer"
c. Double-click "My SD Card"
d. Double-click "My Flash Disk" folder
e. Click "Edit" and select "Select All"
f. Click "Edit" and select "Copy"
g. Press the up folder icon twice to get you back to the main Windows Explorer screen
h. Double-click "My Flash Disk"
i. Click "Edit" and select "Paste"
j. A window will open asking if you want to over-rite existing files, select "Yes to all"
This process will take about 30 minutes.
Step 11: Press and hold restart and eject for 5 seconds.
Step 12: Enjoy your new 3.0 :D
Again, this is a compilation of info and not my work. I'm not capable of doing what half of these people do, I'm just a guy that can read directions. I was getting tired of the people going from the start to the finish to ask about dead links without looking at the meat in the middle Yes, I'm talking to you! You're an idiot. Read!!! We can't spoon feed you, you still have to do some of it yourself once in a while. Please do not contact me with your problems, I probably can't help you. If it didn't work, either it really is broke or start again with step 1.
Thanks very much for this post. I was able to revive my f700 which kept going system startup for ever and nothing was working. The only place I had trouble was in step 10 I could not select all files as top line I could not select very small buttons File/Edit etc. I read some more and had to recalibrate my stylus ( Control Panel/Setting ) - by using a tooth pick I managed afterwards.
Posted Jun 03, 2011 · 01:15 UTC#877
For the Avic F500BT, how do I get it to the blue screen to update it to 3.0, I don't have the "EJECT" button. CLOSED!!!!
TomP
Edited Jun 21, 2011 by llptbird
Posted Jun 26, 2011 · 21:57 UTC#878
When I click on the link it gives me and F bomb and an @ symbol?
Posted Jul 03, 2011 · 16:06 UTC#879
Have not actually completed this update yet, but the files are downloaded and extracted. I just wanted to say thank you to all who contributed to this post. I suppose this means re-doing all the basic hacks, but for 3.0 it's gotta be worth it.
Posted Jul 07, 2011 · 14:55 UTC#880
Just found this thread. I have a f90bt in my 05 mustang. I beleive it has the pioneer manufacturers cnd-200 revision. This 300 version will work correct? Also are the 3.0xx updates then just downloaded for free at pioneers website or are there torrent files for these too? Or are they in the latest linked downloads that TheBeej418 links too?
What does the 3.0xxx revisions do exactly as well?
Thanks for any info, didnt want to sift through 99 posts if i didnt have too =)
Posted Jul 17, 2011 · 02:56 UTC#881
Thanks for all this info!
I'm having an issue though --- I can get to the part where I choose Update via SD (Format) --- and when I insert the SD card and and click the knob, the unit read "Read Progress: 100%" and just gets stuck.
Doesn't move from here. I can't get into Test Mode.
Any ideas?
This might be a late response but I just joined the forum. I had the same issue and it was resolved by formatting the SD card. Delete everything on it and right click on the SD card icon. Select format and follow instructions.
Posted Jul 17, 2011 · 03:01 UTC#882
This is not working for me, and I'm not doing anything wrong! I'm getting to the part where I start copying the files. It keeps on saying there is not enough room. I'm not skipping any steps. I've formatted and tried deleting the contents of the My Flash Disk before copying the new files over. I have a black screen BRICK right now, but would liked to fix it so I can sell it. I am not messing up or missing steps unless this is just a junk unit. I'll throw it away before I let Pioneer fix it! Any ideas?
This might be late but I just joined. I had the same problem and I realized that I was missing a step. I was copying the SD card files to the " My flash drive" on the device. What I needed to do is copy the content of my flash drive folder on the SD card to the My flash drive on the device. That fixed the black screen issue.
Posted Jul 19, 2011 · 08:06 UTC#883
Works in F920BT?
Posted Jul 19, 2011 · 11:57 UTC#884
Go get Retells torrent version. It's 3.02. Diaftias mods as well
Posted Jul 21, 2011 · 23:24 UTC#885
Could you please throw a magnet link for that torrent?
Posted Jul 22, 2011 · 12:57 UTC#886
cant from work, its locked down. BUt i iwll when I get home tonight. its in another 411 post as well. do a search....
Posted Jul 24, 2011 · 11:25 UTC#887
I have had my European F900BT for a couple of years, and hacked into it soon after purchasing using a mod by Stanislavovich from 4PDA with great assistance from Boris and others, and a few tweaks from me which I posted.
I was very satisfied with it, indeed I still am, but face a problem in that I seem to be unable to update maps as I did not upgrade to v3 and therefore need IGO8 rather than IGO8.3 maps.
I am therefore going to bite the bullet and upgrade to v3 using your technique, and then use one of the many v3 mods that appear to be available on this site, and download up-to-date IGO8.3 maps.
To date have downloaded the rar files and extracted them to a folder on my laptop. However, as I will only be using the Navi in the UK and France I propose to delete all the US maps, POI and building files, and replace them with equivalent UK and France files. Do you agree that this would be ok? Presumably I should retain the existing basemap file.
I am grateful for your help in putting this together.
Colin
Posted Aug 14, 2011 · 02:48 UTC#888
Did the upgrade, got error message Application AV has performed an illegal operation and will be shut down. What does that mean?
Posted Aug 19, 2011 · 01:01 UTC#889
Just want to say thank you! My unit had resorted to a black brick, and this thread brought her back!! It was my first hack/mod, and now I want to play around and see what else can me done. Appreciate everything!!
Posted Aug 19, 2011 · 02:56 UTC#890
i have the same problem i do the code fast and try to get the winceflash update but it kicks me out by 33 percent
Posted Aug 25, 2011 · 00:46 UTC#891
I just performed the 3.0 upgrade, but the unit is not in my vehicle. I am using my 12v bench tester. I have the red and yellow wires attached to the positive, and the the ground attached to the negative. This allows me to test radios. I have three F700BT's I picked up pretty cheap. I followed the directions to the letter. At the end when it was done, I ejected the SD card, held the reset button for 5 seconds. The splash screen came up, then went black, and stay that way. Did I do something wrong?
Posted Aug 28, 2011 · 16:37 UTC#892
Do I have to change devic type in system.txt?
Also will a micro sd card in an adapter card work ok?
Posted Sep 12, 2011 · 12:49 UTC#893
I've tried reinstalling this 3 times, but consistently get the "System is starting up" message on the screen. I'm not even sure where I got my 3.0 image from at this point. Could someone upload the one they used on their system to megashare or something? That would be so awesome. Really would love to get this working ASAP.
Posted Sep 22, 2011 · 23:08 UTC#894
HELP!!!
When I get into the service menu, my screen will go black after 20 or so seconds. Even once I get to Update via SD (Format) and I click it, it will start reading the files and then the unit will just go black. This happens every time, even if I go into the service menu but don't click anything. When I reboot the unit (without trying to get into the service menu), the screen just stays black, nothing comes up. I have 2.006 installed on my F900.
Once I reboot the unit I can successfully get back into the service menu, but then it goes to black screen.
I had the same problem with my AVIC F700BT when I tried to upload 3.0... I followed the directions, on this forum, then did it again and the update took. It took twice for me to upload the files via test mode for the update to take, then voila no black screen. You should refer to the dude who uploaded the files onto megaupload, his directions were money. And from there I updated to 3.2 directly (No you do not need to update to 3.1 to get 3.2 despite what people tell you, mine installed just fine from hacked 3.0, without fooling with 3.1.)
Posted Oct 17, 2011 · 18:53 UTC#895
Will this update work with x920bt or is it just for F series?
Posted Oct 23, 2011 · 21:45 UTC#896
Windows - WinRar - http://www.win-rar.c...ownloadnow.html
(Note: I came across a few posts where people said they had issues with the included Testmode and downloaded a fresh file to replace the included one. To save myself time, I went ahead and did this upfront without actually ever testing the one included. If you choose to do this as well, you can get another functional Testmodev2.3 here - http://www.filestube...0f503ea/go.html. Again, I never tested the included one and may be perfectly fine. If you download a new copy, just replace the old Testmode folder in your destination directory with the new one once you unrar it.)
Step 10:
a. Select "Start"
Step 12: Enjoy your new 3.0 biggrin.gif
I followed these instructions about 20 times through, i cant figure out how to get them to work. right now my system will only boot into test mode. i was on version 2.0000 when i started. how do i fix this? if i try to let it boot without the crad that has test mod it just stays on the flashcard forever. please help anyway you can.
Posted Nov 09, 2011 · 02:31 UTC#897
What is the service combination???
Also, will this work on the F90Bt...Im assuming it will.
Edited Nov 09, 2011 by coop1103
Posted Dec 11, 2011 · 00:44 UTC#898
I am stuck too... When I finish copying the files over do I take the memory card out and then press and hold reset+eject for 5 seconds or do I do this with the card still in the system?
Edited Dec 11, 2011 by garz
Posted Jan 19, 2012 · 22:26 UTC#899
Anyone else have the files? Megaupload was shut down today as I was downloading them
Posted Jan 24, 2012 · 23:49 UTC#900
same...someone must have them to reup! Please?!
Page 36 of 39
