Thanks for everyone's work on this, the pictures look awesome, however I wasn't able to get this to work, hopefully I am not doing something dumb (definitely not ruling this out through). I have a US model F700BT with 3.0 (not 3.01). I followed the instructions, and after bootup I got the nag screen, and after hitting ok it would reboot. I tried rebooting a few times but no luck, same thing. So I removed the new CommonLib.dll and put the old one back in. After this I was able to get into the menus, however when I press the map button, it would also reboot. One thing that was strange - if I started at the menu and went into my favorites and set a route, it would work. I could get to the map and I saw some of the mods, however even after getting into the map, if I pressed the map button again it would reboot. I replaced the DATA.ZIP with the original and everything was working normally. Not sure if anyone else has seen this - any suggestions?
Thanks!!
wm
Use this download. DATA.zip had a problem when being compressed but all is working now.
I am still having problems loading this. I have the same problem as above.
Keeper 3.0 Mod - 07-29-09 UPDATE
Hey Keeper - Looks like a great mod from the pics...thanks for the effort. Question though; I've got a F700, and don't have the MSN Live functionality. If I load this MOD, will it still show the icons for MSN Live, and they just won't function? Or, is there a way to just strip them out of the code?
I'm not as computer savvy as most of you guys are, so I don't want to dive too deep into changing code around unless it's pretty obvious on how to remove it. Thanks!
Yes it is very easy to strip the code out, as a matter of fact, someone has already done it for you. I believe it is the other thread that say keeper + speed cam
Thanks!!
wm
As I was trying up instructions on how to do this mod I came across the problem. I left a font file out of the original package. Some of you have it some of you don't which is why some of you are having the problem and some are not. ![]()
Copy this font into MyFlashDisk/APL2/IGO:
Well I was happy where this mod was so I was not going to do anymore, but then I tried IDT's amazing work and decided I needed to incorporate some of his labor. SO I will be updating soon with a number of new features once I iron out the bugs.
Keeper:
I love your quick menu, it's amazing. I have one question which I don't think has been asked yet, but when you are on the map screen (and no route has been entered), how do you switch from 2D to 3D or North Up? I noticed you removed the button completely from your screen. I'm just curious because I would like to remove the button, but am unaware of any other way to change the viewing mode.
Ok... It seems as if no one else is having my same problem... But every time I load Keepers data.zip file onto my system I get an error message when I start iGo. It pops up with a message saying it cannot open gfx/day/cs.bmp or something like that. I am running FW 3.0 on an F90BT. Any ideas?
I've tried Keepers data.zip and also the 5 mods in one version, but none work.
Keeper:
Tap the compass. That changes map direction.
do u have the DS-DIGI bmp image file in the IGO folder? that was the problem i had i got that same error message..
if u done a lot of moding i suggest u do a flaskdisk restart.........
Yes.... there are actually two fonts needed depending on what version you are using. If you are using Keepers original file then you need bnt.ttf. If you are using one of mine you need bnt.ttf and DS-DIGI.TTF. Both of those files are in a link below and should be copied to APL2/IGO. It wont hurt having more fonts there so just copy them and you will never have to do it again if another mod uses the same font:
i think the problem here is your using a modified scheme that's looking for the CS.bmp, i don't think keeper's data.zip has the modified gfx folder, this is why we suggest deleting save folder to avoid conflicts,
Hello, I want to know how can I do to have only the arrow drawn on the street like in the picture "avic1.jpg" (green arrow) on Page 1, because I would not apply the mod completely, which file should I change?How? Thank's! ![]()
You need to change this in the sys.txt
[2d]
show_guidance_arrows=1
show_guidance_strip=0
to this
[2d]
show_guidance_strip=1
and then save the file.
How would I go about "upgrading" from Diaftia's Hybrid mod? Is it a simple copy/replace of some files?
Do you mean change from Diafitas mod to this one?If so you need to relace the data file in MFD/APL2/IGO with the data file for this mod.You also need to delete All the files in MFD/USER/USERDATA/IGO/SAVE.Also make sure that the mod you are changing to does not require any additional fonts.
Although this mod is pretty old now and I worked with Keeper to get all of our stuff working together. If you like the smaller quick menu check out my version 1 mod too. If you like the new menu (which is based off the Keeper redesign and has larger buttons for ease when driving) then check out my V2 mods. If you like the solid backgrounds that are in the screen shots in his first post then go into the visual settings and turn off transparent backgrounds.
