Keeper 3.0 Mod - 07-29-09 UPDATE
By keeper22 · Jul 27, 2009in Completed Mods/Themes💬 141 posts👁️ 30,661 views
Page 4 of 6
Posted Jul 30, 2009 · 17:12 UTC#76
yup... found it before i checked your post had to check back and forth between the top 4 codes and bottom and finally saw that in the bottom there should be no "!" in there. Everything is all good now! love this mod skin even better then the 2.0 ones
Posted Jul 30, 2009 · 17:47 UTC#77
whoops sorry about that. thank you for the correction, I had not been out to my truck yet. I edited the original post as to not confuse anymore people.
Posted Jul 30, 2009 · 18:11 UTC#78
Nevermind - I thought you put the quickmenu mod in the OP, not down on page 4. I got it now. Thanks.
Posted Jul 30, 2009 · 19:02 UTC#79
Keeper do you plan to add the speed cams to your data.zip? just curious if you're eventually going to, if so I will just wait until you do it :D
Posted Jul 30, 2009 · 19:14 UTC#80
Here's Keepers 7/29/09 mod with the speedcams added. Its ONLY the data.zip - you need to put the speedcam.txt files and edit the sys.txt yourself, but the important parts in the data.zip are updated. Took me 4 seconds to do.
Here's a link:
http://www.megaupload.com/?d=FKAH9IGT
Posted Jul 30, 2009 · 19:50 UTC#81
The instuctuons to add this are already posted... You could have done it yourself. I would advice reading through the speed cam post and finding the .spud file and put it in as well. Has speed traps already on map and pretty accurate for my region.
Posted Jul 30, 2009 · 22:04 UTC#82
Yea I know how to do it, i'm a bit busy these days so I was just asking if he planned to otherwise I would do it myself. Sorry for asking
Posted Jul 30, 2009 · 22:22 UTC#83
I did all the work for you here
http://www.avic411.com/forum/viewtopic.php?f=34&t=26108
I made two versions one for the f700 which does not have MSN and one which is just the normal keeper mod. I tried to make this as simple as i could so i put everything you need inside the zip files. All you should have to do is move the files/subfolders from the zip to your unit and you will have keepers mod, speedcam mod and, warning message mod all installed.
Posted Jul 30, 2009 · 22:26 UTC#84
Hey All-
So I am trying to mod keepers file with the speed limit sign and current speed mod found here:
http://avic411.com/forum/viewtopic.php?p=138989
I like to use this because my speedo is off by a couple MPH. This keeps me honest when a cop is around. :)
I have gotten to step 3 and I am noticing that the code is different. Is this because of the difference between 2.0 and 3.0? I am not sure this is going to work just plopping the code in as they say due to the version.
EDIT: I think this may be because Keeper removed everything already! I think I am going to skip to step 4 and work from there. :)
Posted Jul 30, 2009 · 22:37 UTC#85
Hmmm maybe I should just start with yours. I have an F90 but dont use the MSN sub for now and I could use the speed cam stuff. :)
How do you guys get the X and Y coordinates? I am thinking about moving the speed limit sign to the right side to make sure there is room for Keepers drop down menu. I just don't know what to change the position to.
Posted Jul 30, 2009 · 22:43 UTC#86
Hey All-
HAHA this is what I was about to work on as well, My speedo is also off a few MPH(rim size) and I like to be able to double check my speed easily
Posted Jul 30, 2009 · 22:52 UTC#87
Hey All-
Hopefully I will have something soon for you! I just need to find out how to get the X and Y coordinates so the signs don't overlap with Keepers menu's.
Posted Jul 30, 2009 · 23:04 UTC#88
Hey All-
Could you setup your computer to emulate the avic and test the mods on the PC, I used to do that when I first joined the site and was working on changing images in the image.res
so you can throw the code into the files and then play around with the coordinates to get it in a good spot
Posted Jul 30, 2009 · 23:06 UTC#89
This is probably done with VMWare? I will do a search.
Posted Jul 30, 2009 · 23:19 UTC#90
I don't know if you can view changes done to igo but i know you can see the main menu :/ I havent used this in along time I might set it up now though while i'm at it
viewtopic.php?p=120609#p120609
Posted Jul 31, 2009 · 00:21 UTC#91
being in canada.... well Montreal to be exact, the speed cams dont work well.. there are places on the map where there are no cams at all.. beside I don't really care for them on the map anyways, some places have too uch too...... is there a way to turn them off?.. I can live with them, but if there is a option to turn them off it would be nice... BTW this is a awsome mod.... too bad you could not make a "update to firmware 3.0, with keepers mod all in one unzip to sdcard" lol now THAT I would pay money for hhehehehehehe
Posted Jul 31, 2009 · 00:23 UTC#92
For anyone interested here is the DATA.zip for Keepers mods with only the quickstart menu.
Posted Jul 31, 2009 · 00:24 UTC#93
wheres the zip?
Posted Jul 31, 2009 · 00:27 UTC#94
Sorry, but the file won't up load. If you need help figuring it out send me a PM.
Posted Jul 31, 2009 · 02:18 UTC#95
anyone else having an issue where in the 3rd "layer" of icons - they all just open POI search? (ie - the satelite icon opens the poi search, not the satellite info)
Posted Jul 31, 2009 · 02:55 UTC#96
If you would read the part where he wrote down what each does you would understand they are only for poi searches! It searches for poi around cursor, gps address, etc.
Posted Jul 31, 2009 · 03:20 UTC#97
I don't know how i missed that... I'm usually really thorough in reading these things. Guess I jumped to conclusions :-) Thanks anyway for putting me straight.
Posted Jul 31, 2009 · 05:53 UTC#98
I have been running one of keeper's mods on my 900bt for a few months (2.0), and I must say that I like it a lot. I also picked up some theme changes by god knows who that presents different menu icons. I usually enjoy modding things myself, I just do not have the time to tinker with these things at the moment. I will probably wait for another month before I grab keeper's mod. I am sure he will be doing some more tweaking to suit his desires. I particularly liked all of the different map color schemes included in keeper's 2.0 mod.
Posted Jul 31, 2009 · 06:47 UTC#99
Almost all of the code for the quick menu is in navigatemap_800_480.ui and right near the top so you should be able to find it pretty easy. All of the images i have created are in data\ui_pioneer\800_480 and have a k_ in front of them.
Good luck modding and please post any cool changes you come up with. Oh and you should not have to decompress any of the images I used.
Thank you very much for info! Unfortunately I'm having issues with TMC in my unit, so I'll have to revert back to OEM v2 software to make sure if problem is in software or hardware itself, in that case I can get it repaired as my Avic is still under warranty. I will continue with V3 software when TMC issue is solved.
Posted Jul 31, 2009 · 07:50 UTC#100
You have to look into your Sys.txt
first line should be
[device]
type="PIONEER746EW"
I assume your device thinks it is an US model at the moment
Had the same Problem when implementing US mods under 2.0
let me know if it works
Jörg
Page 4 of 6
