Keeper Mod + Speedcam for newbs
By adamdenterkin · Jul 30, 2009in Hacks/Mods💬 54 posts👁️ 9,139 views
Page 2 of 3
Posted Aug 03, 2009 · 19:17 UTC#26
Great--I'll try it then. Thanks guys.
Posted Aug 03, 2009 · 20:14 UTC#27
Thanks also. I will try them.
One question will the mods show the my speed on the map screen.
Posted Aug 03, 2009 · 22:01 UTC#28
No it doesn't show it
Posted Aug 04, 2009 · 12:06 UTC#29
Is it something that can not be done with 3.01 or is it just going to take some time to find out how to do it.
Thanks for answering previous question.
Posted Aug 04, 2009 · 13:50 UTC#30
I believe it is very easy to show the speed, I just ran out of room in the mod (plus I have a speedometer about 6 inches away, so it is not to much strain to look over)
Posted Aug 04, 2009 · 14:26 UTC#31
OK. Not a problem but the older you get it becomes easier to look at a number. I have found using previous mods for 2.0 that my speedometer is 2 Mph slower then the actual readout on the NAV unit. It just would be nice to have and in a large font. I would do it my self but I do not know how to so I depend on you guys.
Thanks anyway.
Posted Aug 07, 2009 · 06:26 UTC#32
So this is what I have on my system now and runs fine. I just uninstalled all my mods and used this zip that I made a compilation and it works fine per my directions.
NONE of these mods are my own, I have only combined and mods made by others.
included you will find
1) Keepers latest mod with drop down menu (in talking with him he has given me the instructions to add back in the info button so that is the only coding I really did here)
2) The software bypass for those complaining above that theirs no longer works (i have hardware but this software will work)
3) Gadget B1s updated SpeedCam mod via Boris M - Read the Speedcam Version 3.0 thread in order to learn how to use this mod, I have added the spud file that I uploaded to that thread, it contains many of the already known speedtraps/cams in the US you may have to modify their speed limits to make them alarm you. (use the cursor and drop down menu in keepers mod press the 3rd option down which is POI then click the one all the way to the right which is CURSOR info)
4) Carver's Nag screen mod - this knocks out some of the annoying nag screens but not all of them.
Here is the Zip it does not include testmode V2.3 which you also need make sure you read the instructions and have back ups for your current 3.0 files.
Rapidshare LInk - http://rapidshare.com/files/262138182/4 ... d.zip.html
Took your mods and added Current Speed, Current Elevation and Posted Speed (if available) signs and branding icons with the branding icon fix (which is the 5th mod so I am now calling this 5 mods combined).
EDIT: File updated 8-10-09 @ 9:18PST to fix some peoples rebooting problems. Copy the DS-DIGI.fnt file to APL2/IGO if you were having that problem.
http://www.mediafire.com/file/mmzmfjjej ... iginal.rar
If you want just the font file you can get that here:
http://www.mediafire.com/file/kyo52tnwjzd/DS-DIGI.rar
Not navigating:
Navigating:
Posted Aug 08, 2009 · 02:57 UTC#33
I have the last keeper mod without the msn, but when I load this one in, it keeps rebooting. So I just replaced the data file with my old keeper release and all was back to normal. Any thoughts?
Posted Aug 08, 2009 · 03:16 UTC#34
I have the same problem with this new data zip, why some can use it and other can't..
Posted Aug 08, 2009 · 06:16 UTC#35
Mine keeps rebooting also, and the gps doesn't work. I am running 3.01 on my f90bt
Posted Aug 08, 2009 · 10:31 UTC#36
@ diaftia
This mod will working on europen unit with Km/h?
....... working NOT!!!!!
Posted Aug 08, 2009 · 20:29 UTC#37
I have the last keeper mod without the msn' date=' but when I load this one in, it keeps rebooting. So I just replaced the data file with my old keeper release and all was back to normal. Any thoughts?[/quote']
You guys are having this problem with my mods? Can someone confirm? Strange thing is its running fine on mine. Are you on US or EU units? I wonder of the speed mods have an dependency on what unit you use. Also, on the reboots, is it immediate on booting or after a while?
Posted Aug 08, 2009 · 20:41 UTC#38
I will the get the navigation confirmation page and when I click ok, it goes to reboot.
Posted Aug 08, 2009 · 20:44 UTC#39
US unit in MPH?
Posted Aug 08, 2009 · 21:15 UTC#40
I just copied all of these files to my unit again and it works just fine. IDT recommends deleting the save files. It's in My Flash Disk\USER\UserData\iGo\save, everything should be deleted except for favorites.dat if you have it. Try that and see if it fixes it?
Posted Aug 08, 2009 · 21:51 UTC#41
I'm in the us.........try again also deleted files in save, got error (fail to open file gfix/day/cs.bmp exiting application) still wouldn't go to nav screen
Posted Aug 08, 2009 · 23:25 UTC#42
That is so odd.. There is no cs.bmp. I even went and looked in Keepers original file as well as IDT's. I have rezipped the data.zip. Can you see if you get the error with this one?
http://www.mediafire.com/file/kvhkjuyyiaf/DATA.zip
Posted Aug 09, 2009 · 00:51 UTC#43
Finally no reboot, looks great working as should........whats the different between the two data zip....
I think i'm going to restore my flash disk because i've done a lot of testing i need to start from scratch.....
Posted Aug 09, 2009 · 03:54 UTC#44
I didnt change a single thing... lol. All I did was rezip it. Something must have gone wrong when I used winrar to compress it. I will upload a new set and update the threads. Thanks for testing for me! Sorry for the hassle.
Posted Aug 09, 2009 · 14:10 UTC#45
Any chance you could put a itenarary shortcut?
Posted Aug 09, 2009 · 17:54 UTC#46
dafia good work... I had been away for the week and just got home like the addition of the speed cams... Its nice that everyone makes compilations and no feelings are hurt!
Posted Aug 09, 2009 · 22:02 UTC#47
Thanks! I just try to make sure that I give credit to the people that deserve it when I post it back up. There are a lot of people doing great work on these boards and we are all benefiting a lot. So thanks for your's, keepers and Adam's great work as well. :)
This is really my first mod. I am trying to see if I can get the trip computer into this with an on/off switch in the menu. I am having a hard time adding in a 5th icon below the MSN one in keepers awesome menu system. We'll see how far I get. :)
Posted Aug 09, 2009 · 22:47 UTC#48
I have an F90BT and am running 3.010. I downloaded the files, the revised data zip, and it still keeps rebooting at the map screen. I just reverted back to my backup of the flash disk.
Posted Aug 10, 2009 · 03:34 UTC#49
I am completely perplexed as to why its doing this on some and not on others. Can you answer these questions for me?:
1. Have you ever modded before putting these mods on?
2. When you "reverted back to your backup of the flash disk" was that an unmodded backup?
3. If you are back to the original unmodded (ever) config can you try just doing the font (bnt.ttf) and the data.zip and see if you have the same problems?
Posted Aug 10, 2009 · 20:18 UTC#50
Hey guys i just notice in 4 mods combine when ur en-route when u come to a turn the green arrow kinda lead u thru the turn, 5 mods combine do not have this, any reason why?
For some reason or another i cannot use the 5 mod combine on my f900 with update 3.01, but i can use it on my f700 with update 3.01 although i had problem at first until diaftia rezip it but still can't use it on my f900.......
Page 2 of 3
