just updated the first post
the ftp link is asking for a username/password.
just try it again
just try it again
just try it again
Just tried accessing the FTP and I prompted with an FTP username/pw too.
just try it again
works for me now. thanks man. i'm excited. physically.
i just updated the link, please try it again and report back
FTP link works now and the install was seamless. Booted my avic and everything works great.
Thanks IDT
I can't wait to go outside in 30min and load this up as soon as I punch out.. ![]()
Just so you know that I am on 3.01 and it looks like some things are a little different. Now all I did was plop all the files onto an SD card, copied them over, booted it up and started a route home. I did not actually drive anyplace. The only thing I noticed was there are some things missing based on your screen shots while on a route. The two individual boxes showing what I think is distance and time to destination are not there. The box to the right of where those are supposed to be showing current street was off to the right by itself with the larger box showing next street below it. Everything else at a cursory glance looked good.
Hope this helps!
Hope this helps!
could you check if full screen map option is on? if it is turn it off then let me know if problem still persist
Does this have Speedcams turned on too?
Seems it does.. now i just have to replace the car pictures to my car or something that looks like my car at least.. maybe back to a arrow.
yes plus speedcam voice
So the DATA.ZIP, SYS.TXT, and DS-DIGI file go to the apl2/igo folder? And the reason to delete everything? in the saved folder?
hey idt once again your tha man. hey is there gonna be a trip on the next one or should i get the trip from the other thread. im not lazy just like your mods. i put someone elses 3.01 mod on but i like yours. great bro great shit!!!!!!!!
Looks pretty pretty good..
Will this also work on the APU 3.0 (thats "Authentic Pioneer Upgrade"
) for our F series??
....I am willing to toss a little $$$ your way for an F500BT on IDT V3.0 steriods... WOoooOOHOOoooo
Is this Modding only for IGO 8.3 or can be used with 8.0?
info: my USA unit is uptodate but APL2 is with hacked ezrider+Europe maps
yes
to avoid conflicts
yes, probably on the next one
AFAIK it would work on the official 3.0,
for that to work on your F500, you just need to edit the sys.txt included, copy the top part of your originial sys.txt and replace the one from the downloaded sys.txt
does it have the hacked 3.0 update?
Hope this helps!
Hey IDT-
I figured it out. It's actually because of the units of measure. I remembered in your screen shots that you used KM. When I switch from miles to kilometers they come up on te screen correctly.
what about the tilt feature, i had another sky mod on and if i tilteled my screen down once, the arrow would go off screen?
i will look into that
Hey, IDT, I thought I'd share some glitches with mine:
I set up all of the warnings for the speedcams before going down the road to check this out. I set the audible alerts, visual and voice. When it approached a known speedcam location as was downloaded by the speedcam.txt and .spud files, as soon as it got within range the unit would immediately start to reboot BUT if I put in my own cam it would read it and do all of the **normal** alerts just fine so it seems to have something to do with the original, unedited speedcams. Also, even if I shut it off and restart the speedcam sound defaults to "disabled" every time but everything else stays to the settings I choose.
The speed limit that I chose by the slider bar (example 50KPH/31MPH) for a particular camera it will read that number in "Miles Per Hour" and not KPH..I am here in the states
It would be nice if I saw just one speed selection --in US units--.
I also had to add my clip_planes.ini file because I am running all of the previous schemes. I also had to add nightguidanance_arrow(bmp & spr) so that these would work.
Getting close!
Thanx,
Bud
i'll look into it
the reason for having two values is because with the original set up, even if you have it set at 50mph the voice alert would still read it at 30mph, the warning voice is dependent on your unit settings, so for the example you have 50KPH/31MPH will say 50KPH if your units is set to km and will say 30MPH if your unit is set to MPH, i don't know if my explanation is clear but all it is is your speedcam is dependent on your unit setting
